Days Won
4
FishWick last won the day on August 23 2020
FishWick had the most liked content!
About FishWick
Essex
vr_rado reacted to a post in a topic:
DIY turbo guide
wessel429 reacted to a post in a topic:
Vr6 on throttle bodies
£420!!! Jesus!
They stopped making the GT3582R? Is it a GTX now? Such a great snail on my VR6. Perfect torque band for a road car, which doesn't kick in so quickly it strips the teeth off 5th gear, which is something to consider when choosing a quick spooling turbo. I tried a couple of GT30Rs as well, GT3071R & GT3076R with 0.82 T3 housings. Both of them were done by 5800rpm. 35R carries on past 6K. Maybe with a 1.06 housing the smaller units would fair better up top, but it's a lag compromise thing, as is a huge front mount vs air-water cooling.
95VWR reacted to a post in a topic:
Supercharger FAQ - MAF vs. MAFless discussion
Woodie1991 reacted to a post in a topic:
DIY turbo guide
Please identify this coil pack!
FishWick replied to ssaunders's topic in Engine Maintenance and Problems
The coils are fired from the Emerald's internal amps, hence bypassing the ICM. Did the same with my DTA, worked fine. It's a standard coilpack mate. -
ibs reacted to a post in a topic:
Where can I buy MSD coil packs from?
Sounds like it's either going lean or could spark issues. Have you got an AFR gauge in the car?
Fair enough mate The MSD coils are huge though! Yes they weren't as reliable as the stock coils. 2 failed on me. Gave up on importing them after that and I noticed no difference what so ever using them either. People use them because they can run a bigger spark, but it makes no difference. Stock coils with suitable plugs gapped properly is all you need. Just like you burn a house down with a match, if the air/fuel ratio is correct, you only need a small spark to ignite it The Bosch coilpack worked well for me over 60K miles with a turbo. It doesn't crack like the original VR6 on
I ran the MSD coils and they weren't really worth the hassle imo. I ended up using one of these, which fits into the stock coilpack's ally cradle with some very minor modifications. https://shop.vems.hu/catalog/bosch-motorsport-ignition-p-113.html
mattvr6 reacted to a post in a topic:
New mk5 r32 owner (manual)
Bealieboy reacted to a post in a topic:
Whats your EGT?
850-900 isn't too bad, just watch it doesn't climb too far past 1000 on boost. Try adding a bit more cruise timing if you want the egts a bit lower. For example, on my VR Turbo with flat top 8.5:1 forged pistons, I was able to run 40 deg advance at low loads at 80ish mph. That knocked the EGTs down a bit. Stock timing is around mid 30s up there, but is 10:1 CR. There's a fine line with EGTs. Running rich can increase them, running too lean can increase them, you just need to find the sweet spot with the right AFR and timing.
Stealth Racing recently mapped a standard MK5 engine to 290hp. Admittedly it was in a Corrado though, and they did say that was a little higher than what they normally see, but it's possible. 300hp is a stretch without cams and probably a short runner intake. The standard intake is the main bottle neck on this engine.
As nice as a GT35 is, if I did mine again, I'd go with the EFR 7670 as it's a better turbo for packaging. By the time you've spent money on a decent external WG and DV for the GT35, the EFR works out a lot cheaper! Very good turbos from what I've read too.
RBPE reacted to a post in a topic:
Engine rods/piston advice!
Traction is a problem in the wet, even with a diff, but it's by no means unusable on the road. Just have to be smooth with the throttle and roll into the boost rather than nailing in 1st and 2nd! Having said that, 3rd & 4th and even 5th can break traction on the move if the torque curve is spikey. I had my standard VR6 box rebuilt at 130K (new bearings, syncros etc) and then did a further 60K with a turbo and it survived just fine. I was only putting 350lbft through it though + some mechanical sympathy. Avoid nailing the gas on uneven road surfaces because it's the shock of regainin
If I was to do it all over again, I would get Mahle 142S pistons with 23mm wrist pins and find a machine shop that can replicate the factory honing - with a torque plate. That will give you a nicely sealed and very strong bottom end.
VR6Pete reacted to a post in a topic:
Low/High Comp Piston
No chance with a 12V! Many people have tried over the years and I think 240ish was the most, which consisted of a 3.1 block, cams, big valve head etc etc.
Low comp on NA will run fine, but engine braking will suffer a bit and it won't feel as lively at the bottom end.
Agreed on the 0.82 for a more user friendly torque curve. 1.06 has a better top end though and there's approx. 500rpm spool up difference between the two, so 3500 vs 4000rpm to see full boost. 4000rpm is a little late for my tastes, but with the 1.06 it'll pull to the redline harder, but you've only got a 3000rpm window. I also tried a GT3071R and a GT3076R, both 0.82. Both are gearbox killers (5th especially as it's the smallest gear) and both run out of puff far sooner than the GT3582R does. Figure out what kind of torque band you want and choose from there. Don't just buy on a whi
Standard engine? They do run pig rich from cold and 10 doesn't sound too far off from memory. Are you letting the AEM warm up for a couple of minutes before cranking it over, as it takes time for the O2 heater to get it up to temp?
