c00k 435 Posted January 7, 2015 Report Share Posted January 7, 2015 (edited) You can get Vag-com or VCD's (vag com diagnostic system) from ross-tech with a genuine cable and it will just plug in and work. But there not cheap. Google Ross-tech if interested. But there's a cheap option, but requires half decent computer knowledge. I work with computers as my trade and daily job, so it not too hard for me. Plus I can try and help. But you get a cheap OBD2 cable from eBay. Download a version vag-com, or I can send you a version of vag-com. But it will only work in demo mode because you don't have a genuine cable. This is where the computer knowledge is needed. You need to trick vag-com into thinking you have a genuine cable. I worth my script and code to do this. But I could send you my version over. But I would have to explain how to set it up. As if done incorrectly it won't work. I've been running mine for about 4-5 year. Demo mode won't let you use the measuring blocks. And you can only scan error codes. Not delete them. Full version or tricked version you can do everything. Edited January 7, 2015 by c00k J4Y VR 1 Link to post Share on other sites
dave_424 48 Posted January 7, 2015 Report Share Posted January 7, 2015 You can get Vag-con from ross-tech and a Guinean cable and it will just plug in and work.But there not cheap. Google Ross-tech if interested.But there's a cheap option, but requires half decent computer knowledge. I work with computers as my trade and daily job, so it not hard for me. Plus I can try and help.But you get a cheap OBD2 cable from eBay. Download a version vag-com, or I can send you a version or vag-com.But it will only work in demo mode because you don't have a genuine cable. This is where the computer knowledge is needed. You need to trick the vag-com into thinking you have a genuine cable. I worth my script and code to do this. But I could send you my version over. But I would have to explain how to set it up. As if done incorrectly it won't work. I've been running mine for about 4-5 year.Demo mode won't let you use the measuring blocks. And you can only scan error codes. Not delete them.Full version or tricked version you can do everything. I would be very interested in a tricked version, I don't want to register my vag-com since it can only be registered one 1 or 2 computers and i'm constantly changing laptops or re-installing operating systems. So I have downloaded VCDS lite from rosstech and have a cheap cable, I can scan and clear codes and also access some of the measuring blocks, datalog etc. but not everything. I need the full version to check my timing chain stretch Bealieboy 1 Link to post Share on other sites
ibs 308 Posted January 18, 2015 Author Report Share Posted January 18, 2015 Bit of an update with my car. It's been back in my garage since last week and i only got round to working on it today. It's all run in so the idea was to do an oil and filter change and get it booked in for mapping. Well today certainly did not turn out like that. Firstly I decided that I will run the original oil cooler with the mocal one as I am not at the moment and in order to do that I will have needed to get the front end back off. So I drained down the coolant and got the front end off....Next I drained the old oil out. I need to get me a socket for the oil filter housing as I have not got one. I also changed the gearbox oil again, it was done a few weeks ago but I decided to do it again anyway as I had loads left over. Also got my broken scuttle panels off and thought this would be the right time to get my bonrath single wiper conversion fitted so I did that aswell. That was my day done! Bealieboy, daveyboy, cactusjackslade and 2 others 5 Link to post Share on other sites
Bealieboy 1,625 Posted January 18, 2015 Report Share Posted January 18, 2015 Looking good ibs, got room for anything else under the bonnet? Looks a bit busy in there. Link to post Share on other sites
ibs 308 Posted January 18, 2015 Author Report Share Posted January 18, 2015 Got to find some room for the meth injection next lol. Just ordered a devils own 6-30 psi kit. D11PS, daveyboy, Russvrt and 1 other 4 Link to post Share on other sites
VR6CABBS 1,311 Posted January 18, 2015 Report Share Posted January 18, 2015 quality mate. I was wondering wear you'd disappeared to. Lol. Looks a beast mate. Can't wait to see it!! ibs 1 Link to post Share on other sites
ibs 308 Posted January 19, 2015 Author Report Share Posted January 19, 2015 The Leon Cupra R bembo calipers have been hard work getting the right bits for them. But I have finally got everything I need. Just waiting on the TT wheels to be refurbished then I can get everything put on. I went for matt lewis racing braided hoses for LCR brembo calipers, but they also had to send me out separately 2x fine pitch banjo fittings to fit the calipers. Disc and pad combination that was recommended to me was the Ferodo DS2500 pads, EBC Ultimax discs and ATE super blue racing brake fluid. I'm not doing anything on the rears yet but later on I plan on doing the mk4 rear caliper upgrade and then buy the same disc and pad combo. VR6CABBS, daveyboy and D11PS 3 Link to post Share on other sites
ibs 308 Posted January 21, 2015 Author Report Share Posted January 21, 2015 I need some advice guys I was having a look at the underneath of my car yesterday and I could see the sump has been leaking oil from where it butts against the bottom of the block. I did put on a new rubber seal but it is not doing the trick. Should I use some gasket sealer aswell as the rubber gasket? Or is there any other advice you can give me? Thanks Link to post Share on other sites
Reaperx 181 Posted January 21, 2015 Report Share Posted January 21, 2015 I would just use sealer on it but that's my preference. I have used the sealant on hundreds of sumps at work and never had a leak yet. VR6CABBS 1 Link to post Share on other sites
ibs 308 Posted January 21, 2015 Author Report Share Posted January 21, 2015 I would just use sealer on it but that's my preference. I have used the sealant on hundreds of sumps at work and never had a leak yet. So just use the sealer without the rubber gasket? Link to post Share on other sites
Reaperx 181 Posted January 21, 2015 Report Share Posted January 21, 2015 That's what I do bud but to be honest most parts companies don't supply gaskets anymore. That's why I end up using sealant. Link to post Share on other sites
ibs 308 Posted January 21, 2015 Author Report Share Posted January 21, 2015 That's what I do bud but to be honest most parts companies don't supply gaskets anymore. That's why I end up using sealant. Cheers i'll give it a try. Link to post Share on other sites
cactusjackslade 146 Posted January 21, 2015 Report Share Posted January 21, 2015 It's upto u really, can try sealer... Was it a genuine sump gasket or aftermarket? Iv had multiple aftermarket rubber gaskets leak on rocker covers etc in the past.. Brought genuine ones in the end.. No more leaks... The quality of rubber on genuine gaskets is much better.. Plus they are usually the right shape to start with too.. Which tends to help lol. Link to post Share on other sites
vr6guy 29 Posted January 22, 2015 Report Share Posted January 22, 2015 Elooo Have been reading the build and enjoyed all the comments and pics Just to say with your cutting out issue (not sure if you have sorted it yet) I had same problem and it was down to a split boost pipe... I know yours are new but just sharing Link to post Share on other sites
ibs 308 Posted January 23, 2015 Author Report Share Posted January 23, 2015 EloooHave been reading the build and enjoyed all the comments and pics Just to say with your cutting out issue (not sure if you have sorted it yet) I had same problem and it was down to a split boost pipe... I know yours are new but just sharing Thanks mate, I'm pretty certain mine is being caused by the fuel pressure. The last few times I drove it before I put it back into the garage it did not cut out so I'm guessing I had got the fuel pressure just right. vr6guy 1 Link to post Share on other sites
ibs 308 Posted January 23, 2015 Author Report Share Posted January 23, 2015 It's upto u really, can try sealer... Was it a genuine sump gasket or aftermarket? Iv had multiple aftermarket rubber gaskets leak on rocker covers etc in the past.. Brought genuine ones in the end.. No more leaks... The quality of rubber on genuine gaskets is much better.. Plus they are usually the right shape to start with too.. Which tends to help lol. I think it may have been a aftermarket one. I will try with just some sealer and if not then I will get a genuine gasket. cactusjackslade 1 Link to post Share on other sites
ibs 308 Posted January 23, 2015 Author Report Share Posted January 23, 2015 I guess I know what I will be doing this weekend... D11PS, daveyboy, Russvrt and 2 others 5 Link to post Share on other sites
Bealieboy 1,625 Posted January 23, 2015 Report Share Posted January 23, 2015 A session on that falling down water? ibs 1 Link to post Share on other sites
c00k 435 Posted January 23, 2015 Report Share Posted January 23, 2015 Think I'm going to be building my own methanol injection soon, and using the devilsown pump Usrallyteam website sell loads of brilliant parts ibs 1 Link to post Share on other sites
Mk3highline 287 Posted January 23, 2015 Report Share Posted January 23, 2015 Which kit did you get? Have you got the pre turbo nozzle Link to post Share on other sites
UnitedMotorsport 55 Posted January 23, 2015 Report Share Posted January 23, 2015 The stalling problem is caused by the item right behind the left headlamp. Link to post Share on other sites
dave_424 48 Posted January 23, 2015 Report Share Posted January 23, 2015 The stalling problem is caused by the item right behind the left headlamp. Yep looks like a vent to atmosphere blow off valve. @United Motorsport, I have been trying to get hold of you about software etc. for a turbo golf v6 4motion I am building, sent a couple of emails through your website. Let me know if there is a better way of contacting you Dave Link to post Share on other sites
ibs 308 Posted January 23, 2015 Author Report Share Posted January 23, 2015 (edited) Which kit did you get? Have you got the pre turbo nozzleI got the 6-30 psi kit as advised by them. No pre turbo nozzle. Just 1 nozzle to go on the air intake. Edited January 23, 2015 by ibs Link to post Share on other sites
ibs 308 Posted January 23, 2015 Author Report Share Posted January 23, 2015 The stalling problem is caused by the item right behind the left headlamp.Someone mentioned that earlier on during the build. I should have taken more notice. Could you advise any further please. Should I get rid of it completely or replace it with a recirculating one?Thanks Link to post Share on other sites
Mk3highline 287 Posted January 23, 2015 Report Share Posted January 23, 2015 I got the 6-30 psi kit as advised by them. No pre turbo nozzle. Just 1 nozzle to go on the air intake.Basically you just need another nozzle think its the 0.7 When you get chance speak to the chap at devilsown he did it on one of his cars too ibs 1 Link to post Share on other sites
