el_chriso 0 Posted January 4, 2015 Report Share Posted January 4, 2015 Following an "incident" at a recent track day I have decided that I want to upgrade my standard brake system. I was thinking about a 312 setup, but I might be tempted to go bigger, maybe a Porsche setup? Anyone got any suggestions? I'm running TT fat fives so I'll have plenty of room to play with I would've thought. Cheers Link to post Share on other sites
Swivelonit 119 Posted January 4, 2015 Report Share Posted January 4, 2015 I went for Leon Cupra R Brembo's, these are a 323 mm disc and 4 pot calliper. this was an upgrade from the 312 mm set up that was fitted as standard to my MK 4 Golf. They just fit behind 17" Team Dynamic Pro race 3 wheels but I have to use 15mm spacers when I fit my Team Dynamic Pro Race 1.2's Bealieboy and cactusjackslade 2 Link to post Share on other sites
Bealieboy 1,625 Posted January 4, 2015 Report Share Posted January 4, 2015 (edited) Looks like a nice bit of kit! What was the incident El chriso? Sent from my iPhone using Tapatalk Edited January 4, 2015 by Bealieboy Link to post Share on other sites
cactusjackslade 146 Posted January 4, 2015 Report Share Posted January 4, 2015 I went for Leon Cupra R Brembo's, these are a 323 mm disc and 4 pot calliper. this was an upgrade from the 312 mm set up that was fitted as standard to my MK 4 Golf. They just fit behind 17" Team Dynamic Pro race 3 wheels but I have to use 15mm spacers when I fit my Team Dynamic Pro Race 1.2's Will this setup fit the mk3 golf too?? Link to post Share on other sites
Swivelonit 119 Posted January 4, 2015 Report Share Posted January 4, 2015 I would imagine so, it is just a matter of getting the correct carriers if not, the 312 set up I removed bolted straight onto a MK 2 Golf. The Brembo's are readily available, check out LCR forum of ukmkiv's, Briskoda etc they are always appearing for sale. I run Ferodo DS3000 pads in mine and only on track. cactusjackslade 1 Link to post Share on other sites
Swivelonit 119 Posted January 4, 2015 Report Share Posted January 4, 2015 According to this thread they do fit but you need to run 17" wheels. http://www.edition38.com/forums/index.php?showtopic=523548 cactusjackslade 1 Link to post Share on other sites
cactusjackslade 146 Posted January 4, 2015 Report Share Posted January 4, 2015 According to this thread they do fit but you need to run 17" wheels. http://www.edition38.com/forums/index.php?showtopic=523548Brill thankyou Link to post Share on other sites
Big J 283 Posted January 4, 2015 Report Share Posted January 4, 2015 I was going to go down the brembo route with mine but I've bottled it incase I get too limited on wheel choice. I'll be going 312mm in the end with the option of porsche boxster calipers as an upgrade if I fancy like it.Sent from my iPad using Tapatalk Link to post Share on other sites
IbizaPartyBoy 34 Posted January 5, 2015 Report Share Posted January 5, 2015 The Cupra R 323 Brembos fit behind TT comp 17s easily with no wheel spacers on a mk3. you can even upgrade to bigger bells n rotors if you want.. like the 330 2 piece Cupra upgrades you can get. Less weight, better performance and look slutty.. The boxster calipers are a bit wider iirc?? needing spacers on more types of wheels.. All you need to bolt the Cupra Brembos to a mk3 if some washers or spacers to pack out the carriers by 6mm.. I used 3x normal 2mm spacers per bolt either side.. Then just bend the dust guard thing behind the discs back by about 1 mm as it touches the mk4/ cupra platform discs.. cactusjackslade 1 Link to post Share on other sites
VR6king 18 Posted January 6, 2015 Report Share Posted January 6, 2015 Cheaper and works great just like brembos, always done them on my VR6 Turbo. Standard Calipers as you all know are Girling 54s. You guys can upgrade to Girling 60s which are Dual Pistons and will stop your car dead on the spot! The Girling 60s come out of variety of early Audis such as the (90-91 Audi Quattro). They fit perfectly on the stock slotted rotors and spindles they both have the sams fitment. Save $1000s of dollars guys. VR6CABBS, The Duke, daveyboy and 1 other 4 Link to post Share on other sites
VR6king 18 Posted January 6, 2015 Report Share Posted January 6, 2015 These are stock ones for the (90-91 Audi Quattro) that are going into my Passat B3 VR6 Turbo. Brand New cost $54.00 a piece. Cannot tell the different between breaking of Brembo! VR6CABBS and D11PS 2 Link to post Share on other sites
VR6CABBS 1,311 Posted January 6, 2015 Report Share Posted January 6, 2015 These are stock ones for the (90-91 Audi Quattro) that are going into my Passat B3 VR6 Turbo. Brand New cost $54.00 a piece. Cannot tell the different between breaking of Brembo!Where they from pal? Link to post Share on other sites
VR6king 18 Posted January 6, 2015 Report Share Posted January 6, 2015 Where is what from? The Calipers brother? Link to post Share on other sites
VR6CABBS 1,311 Posted January 7, 2015 Report Share Posted January 7, 2015 Where is what from? The Calipers brother?Yes mate. The calipers. :-) Link to post Share on other sites
VR6king 18 Posted January 8, 2015 Report Share Posted January 8, 2015 They are from 91 Audi Quattro. Girling 60s they are. Order them from (Partsgeek.com) VR6CABBS 1 Link to post Share on other sites
Bealieboy 1,625 Posted January 8, 2015 Report Share Posted January 8, 2015 I've had a look at partsgeek but can't see the caliper. Have you a part no please? I can only find calipers suitable for 276mm rotors,.Sent from my iPhone using Tapatalk Link to post Share on other sites
VR6king 18 Posted January 8, 2015 Report Share Posted January 8, 2015 I've had a look at partsgeek but can't see the caliper. Have you a part no please? I can only find calipers suitable for 276mm rotors,.Sent from my iPhone using Tapatalk i will for sure send the part number is just a minute brother give me a sec. Bealieboy 1 Link to post Share on other sites
VR6king 18 Posted January 9, 2015 Report Share Posted January 9, 2015 I've had a look at partsgeek but can't see the caliper. Have you a part no please? I can only find calipers suitable for 276mm rotors,.Sent from my iPhone using Tapatalkhere you go brother. Type in (19-B1906) and they will come up. c00k and Bealieboy 2 Link to post Share on other sites
Bealieboy 1,625 Posted January 9, 2015 Report Share Posted January 9, 2015 Thanks v muchSent from my iPhone using Tapatalk Neil20vtc 1 Link to post Share on other sites
djiceman 131 Posted January 11, 2015 Report Share Posted January 11, 2015 Sorry I think I'm being a bit simple, I've been on that site and they only have front rights available.... Is that all you lot are seeing?Sent from my iPhone using Tapatalk Link to post Share on other sites
CALICO 130 Posted January 11, 2015 Report Share Posted January 11, 2015 R32 brakes fit behind 17's Link to post Share on other sites
VR6king 18 Posted January 12, 2015 Report Share Posted January 12, 2015 Sorry I think I'm being a bit simple, I've been on that site and they only have front rights available.... Is that all you lot are seeing?Sent from my iPhone using TapatalkSorry brother! The part number (19-B1906) are the right ones, and the part number (19-B1907) arr for the left ones brother! They are available in stock. They are each $50.23 a piece! Link to post Share on other sites
djiceman 131 Posted January 12, 2015 Report Share Posted January 12, 2015 Thanks mate, do they fit under 15" alloys?Sent from my iPhone using Tapatalk Link to post Share on other sites
VR6CABBS 1,311 Posted January 17, 2015 Report Share Posted January 17, 2015 Sorry brother! The part number (19-B1906) are the right ones, and the part number (19-B1907) arr for the left ones brother! They are available in stock. They are each $50.23 a piece!Only got the right side in stock... Gutted... I wonder if they get more stock or will they be discontinued!! What rotors are you using pal?. And what pads? Are they standard fit brake lines? And there's loads of options for the year of your car which it states audi cab on most of them? Are they all the same?? Link to post Share on other sites
VR6king 18 Posted January 17, 2015 Report Share Posted January 17, 2015 Only got the right side in stock... Gutted... I wonder if they get more stock or will they be discontinued!! What rotors are you using pal?. And what pads? Are they standard fit brake lines? And there's loads of options for the year of your car which it states audi cab on most of them? Are they all the same??Last time i checked they had both Right and Left front Calipers with the carriers as well. Both part numbers are different for left and front. The rotors i am using are slotted 280mm. The pads you can get them for the make and model of that audi for example. Most audi of 90-92 used these. But they also have a complete kit on (ECSTuning.com) for $215.07. Link to post Share on other sites
