  • Replies 384
Popular Posts
Finally got the engine back few more bits and it can go in :-)
Boost pipes are all cut and made ready to go on not much left now :-)
I'll throw a few pics up of what has been done :-) And that is how it's sits waiting for paint :-)
Posted Images
PT6262 T3 0.82AR - Specify the CEA turbine wheel, PT changed this a while ago, older stock will not have them but newer will. If you got it from Ross-sport off the bay they should have the new stock sent anyway as they do a lot in Evo circles.
I will never recommend 440's, far too small. As UM have shown they can support half decent power at high base fuel pressure but when you do this on something like a Walbro 255, the 65-70psi mark is where they start to seriously drop flow rates. The tests about on the net are usually higher voltages too to take into account.in planning.
If you're struggling with ECU a cheap(ish) way to do it might be MSnS? There are some on CGTI that will supply you with it and go through a few things - just a thought. Also I believe the main Megasquirt bloke in the UK has already pieced everything needed for VRT's. There are also VRT 12V settings available to stick on a base map.
http://msruns.com/viewforum.php?f=88&sid=213ab05be7cbfe14b4a46382b8fbbbbb
http://forums.vwvortex.com/showthread.php?5698069-VR6-Turbo-Ignition-Map-Thread
