Poriordan 97 Posted October 19, 2013 Author Report Share Posted October 19, 2013 Maidenvr6 yh deffo mate as you always do cheers anyway and gone for a spec stage three clutch cactusjackslade Link to post Share on other sites
J4Y VR 36 Posted October 20, 2013 Report Share Posted October 20, 2013 Get your clutch fork reinforced aswell Link to post Share on other sites
Poriordan 97 Posted October 20, 2013 Author Report Share Posted October 20, 2013 How do I go about that mate Link to post Share on other sites
Poriordan 97 Posted October 20, 2013 Author Report Share Posted October 20, 2013 Well couple of bits done today Little detail changed the way the rear badge was mounted And finally finished front wheels with some lacquer and refinished badgesWhat u recon ? VR6Pete 1 Link to post Share on other sites
VR6Pete 1,456 Posted October 20, 2013 Report Share Posted October 20, 2013 I'd also do release arm too, only a Tenner. They are prone to cracking. Club Chairman Poriordan 1 Link to post Share on other sites
Poriordan 97 Posted October 20, 2013 Author Report Share Posted October 20, 2013 Ok thanks for the advice Link to post Share on other sites
MaidenVR6 26 Posted October 21, 2013 Report Share Posted October 21, 2013 Spec stage 3+ isnt a bad clutch for 300-400 whp. A friend of mine have had his 3+ since 2008. Only 10 psi/stock 10:1 cr. And since the others are so kind to give you a upgrade tip on bent clutch forks, take a look here to get an idea:http://forums.tdiclub.com/showthread.php?t=248789&page=2 Link to post Share on other sites
Poriordan 97 Posted October 21, 2013 Author Report Share Posted October 21, 2013 Spec stage 3+ isnt a bad clutch for 300-400 whp. A friend of mine have had his 3+ since 2008. Only 10 psi/stock 10:1 cr. And since the others are so kind to give you a upgrade tip on bent clutch forks, take a look here to get an idea:That's good to here and thanks for the link http://forums.tdiclub.com/showthread.php?t=248789&page=2 Link to post Share on other sites
michael5556 247 Posted October 21, 2013 Report Share Posted October 21, 2013 If you want software that is reliable then be patient and wait Too true! Good things come to those that wait. Link to post Share on other sites
Poriordan 97 Posted October 21, 2013 Author Report Share Posted October 21, 2013 Who do I wait for tho ahahha Link to post Share on other sites
shawy 3 Posted October 21, 2013 Report Share Posted October 21, 2013 you guys should check the syvecs gp ecu you can add cal switch with 8 maps for turbo carshas all sendor layout and has warning cut off for oil pressure temp ,water etc can control solenids and magnets for dccd and I think it should control the haldex quite easily by tps rpm wheel sensor speed and brake pressurealso controls boost like a ruler .. can control upto 8 cylinders ,awesome ecu worth its weight in gold .. Link to post Share on other sites
cactusjackslade 146 Posted October 21, 2013 Report Share Posted October 21, 2013 Well couple of bits done todayLittle detail changed the way the rear badge was mountedAnd finally finished front wheels with some lacquer and refinished badgesWhat u recon ?Lookin good m8 Poriordan 1 Link to post Share on other sites
MaidenVR6 26 Posted October 22, 2013 Report Share Posted October 22, 2013 Really like the Porsche rims. Poriordan 1 Link to post Share on other sites
Poriordan 97 Posted October 22, 2013 Author Report Share Posted October 22, 2013 Cheers guys Link to post Share on other sites
VR6Pete 1,456 Posted October 22, 2013 Report Share Posted October 22, 2013 those wheels look stunning Link to post Share on other sites
Poriordan 97 Posted October 22, 2013 Author Report Share Posted October 22, 2013 Cheers mate Little update me new starter came today and finally me clutch hip hip horrayI got it fitted so just need to go and get my clutch fork reinforced as people suggested above And so we proceed Link to post Share on other sites
J4Y VR 36 Posted October 22, 2013 Report Share Posted October 22, 2013 Do you use new clutch bolts? Sent from my GT-I9505 using Tapatalk Link to post Share on other sites
Daverse 175 Posted October 22, 2013 Report Share Posted October 22, 2013 Their stretch bolts so you really should Sent from my GT-I9300 using Tapatalk Link to post Share on other sites
Poriordan 97 Posted October 22, 2013 Author Report Share Posted October 22, 2013 I haven't :0 Link to post Share on other sites
J4Y VR 36 Posted October 22, 2013 Report Share Posted October 22, 2013 Order them up at the dealers. Sent from my GT-I9505 using Tapatalk Link to post Share on other sites
Daverse 175 Posted October 22, 2013 Report Share Posted October 22, 2013 or get ARP's but not really worth it imo unless your dragging it and are going to be changing the clutch again soon Link to post Share on other sites
Poriordan 97 Posted October 22, 2013 Author Report Share Posted October 22, 2013 Ok cheers guys also slightly of topic but I managed to fix my drivers seat with a new back surport (frame ) as mine wasn't staying in position Yhhhh budy Link to post Share on other sites
J4Y VR 36 Posted October 22, 2013 Report Share Posted October 22, 2013 Xbox man just like me!!! Sent from my GT-I9505 using Tapatalk Link to post Share on other sites
Poriordan 97 Posted October 22, 2013 Author Report Share Posted October 22, 2013 Ahahah u know this . Play station ain't got sh*t on xbox J4Y VR, palmer and VR6Pete 3 Link to post Share on other sites
Daverse 175 Posted October 23, 2013 Report Share Posted October 23, 2013 Bah humbugs Sent from my GT-I9300 using Tapatalk Link to post Share on other sites
