  • Replies 291
Popular Posts
Update time! Larger update tonight. Turbo adapter, t3 to t4. Bolts and exhaust studs. New genuine rubber boot, new number plate lights and new wiper caps. New wiring loom for the standalone, Bo
It's been a while since this was updated. Been working on loads of carbon parts for it. They are obviously not finished yet but you get the idea. Sold the schimmel and the rocker cover. Just didn
I'm backkkk So lots has happened since February Anyway I will let the pictures do the talking lol New paint via JH pro/route 32. First wash from new paint New wheels for it. Test fit Old vs n
Right, it's now working. It's running almost perfect. Power steering pump needs looking at, and brakes still need re-bleeding.
The running issue was wiring. Which is why vagcom couldn't pick it. It now picks it up. Starts first time, every time. Its on around 16 on the a/f gauge which is a bit lean at idle, I think. Maf has been taken apart and cleaned and it has made a world of difference.
Anyway, here is some pictures...
All the codes have been cleared and non have come back up. :)
Cleared it up, moved some wires etc. clean as its gonna be with a daily.
Making something...
Dont know which I prefer, black or red. Also considering white.
Thanks people.
Haha yeah she will kill you. If you get caught I will take it off your hands again!
Took it out for a little boost run round the block. The noise!!!! :wub:
Instagram pictures
New track rods as the were screwed.
Also having some issues with the headlight loom...
Need too sort that out.
The fans have been ordered
Fan control unit has been found.
Power steering pump is needed.
Sort out the other track rod.
Mot time. It should all be done for the Gti festival at the pod in October.
Thanks guys
Been busy.
These were brand new 7 months ago. Fallen apart. Been driven three times.
As you can see these were destroyed.
Fitted this in the centre console.
Finally got the fans fitted.
Finally got the spots in the new grille thanks to my brother.
Then this happened.....
What a mess. Had a slight wobble in the steering column so fixed that. Also refitted the dash with the mk2 clocks. Will be testing these next week. I just wasn't happy with the mk3 as they will never fit properly or look good.
Also got this made by a talented chap.
I also sorted out the wires for the guages. These shall be refitted today.
Thanks people
More updates.
Wired the heater up today as it has a whole mk3 heater unit. Also wired up the gauges. And speakers for the front.
This is how it stands.
Upsetting when I look at it like this lol.
Made these for the dash. Using the mk3 tweeter holders. Mounted my alphasonic tweeters. Dont like the look of them but they sound pretty good.
Think I will have to paint them black though. As they stand out a bit.
Swapped the oil cap too a black plastic as I want a fan of the polished one. Also got rid of the rubber ring around it.
Thanks people
  • 1 month later...
Went backwards for a week too solve my wiring issue. But that's all sorted.
Started cleaning...
It had the wrong power steering fluid in so I fitted a newer pump and the correct fluid.
Here is a quick video
http://i1085.photobucket.com/albums/j438/michael5556/96B82201-8FD7-4A1B-9FCA-6108D12AF41B-3032-0000026BD090D012.mp4
Thanks
