dox
About dox
Nantwich Cheshire
02A Clutch Slave Cylinder {Questions}
dox replied to BigStinky's topic in Engine Maintenance and Problems
When the seals on the slave fail the fluid ends up inside the bell housing and the drips on the floor (mine did this, prior to this sometimes the clutch pedal stuck to the floor), when the seals fail in the master the fluid returms to the reservoir. it could also be a cracked clutch fork inside thebellhousing. you could still have air in the line -
I can only find AYL engine code for the Galaxy on ebay, the side shot on this listing shows 2 VVT solenoids so VVT on both cams http://www.ebay.co.uk/itm/AYL-V6-2-8-Motor-204PS-VW-Sharan-SEAT-Alhambra-FORD-89Tkm-MIT-GEWAHRLEISTUNG/181944855944?hash=item2a5cc22d88:g:vdUAAOSwHQ9WWYKi
Did ford use these engines in the Galaxy? Worth trying the Ford dealers?
Mine arrived on Friday, a neighbour took it in for me as I've not been around much thanks
Price for one posted please?
In America they got the VR6 engine in 2WD form in a MK4 VR6 (non 4motion), do their inlets fit our engines (the throttlebodys are different for sure so would need adapting). Has anyone looked into it previously?
Aftermarket immobiliser?
What cost a litre of oil every 1K miles or a £3-4K pro rebuild? If it drives OK and passes the MOT emissions why bother?
MK4motionVR6 reacted to a post in a topic: results from my VR6 dry / wet compression tests
Bealieboy reacted to a post in a topic: results from my VR6 dry / wet compression tests
If the oil stem seals are the originals (20 years old) then they will be hard, cracked and worn. There are three piston rings, compression, oil control and a scraper, you can have good compression and burn oil too if the oil control rings are worn, broken or gummed up with carbon. The compressions are quite good suggesting the bores aren't oval.
vr6 intermediate timing sprocket HELP
dox replied to kerrly's topic in Engine Maintenance and Problems
He says the bottom chain has snapped -
Or put a piece of rag in the chains to jam the sprockets? Don't hold me liable if you bend valves if the engine's no longer timed -
Stripped some 312s today Note the dark line between the backing and the friction material - its actually a crack. After a light tap with a screwdriver, note the rust that was beneath the friction material forcing it off
VR6Pete reacted to a post in a topic: Brakes Failed...!
So what did you find wrong with the brakes then?
