just2zang 0 Posted May 27, 2004 Report Share Posted May 27, 2004 All u need are the s3 caliper carriers that fit straight onto your existing vr calipers. The caliper will need a couple of washers to space them properly onto the discs. Roughly 3mm. Also u will need some longer bolts (high tensile steel)which u can purchase from wicks to bolt the calipers on. Although they will bolt on with the standard ones(not recommended). Oh and of course u will need to get yourself some s3 disks. 8o) Link to post Share on other sites
ingham 5 Posted May 27, 2004 Report Share Posted May 27, 2004 what size are s3 discs ? Link to post Share on other sites
VR6Rob 0 Posted May 27, 2004 Report Share Posted May 27, 2004 312mm Link to post Share on other sites
antera309 3 Posted May 27, 2004 Report Share Posted May 27, 2004 Have you done this conversion to your car? Link to post Share on other sites
Macca 1 Posted May 27, 2004 Report Share Posted May 27, 2004 This sounds awesome, are u sure its possible? just never heard it before Link to post Share on other sites
acf8181 0 Posted May 27, 2004 Report Share Posted May 27, 2004 guessing 17" wheels would be essential tho?but if anyone with a late (OBD2) car does this, i'll be interested in buying your 288mm calipers off you [ Edited Fri May 28 2004, 12:27AM ] Link to post Share on other sites
just2zang 0 Posted May 27, 2004 Author Report Share Posted May 27, 2004 u use the stadard vr6 calipers using the hub carriers to mount the discs correctly for 312 disk. I got them off nik saran for £50 and says they fit straight on! Link to post Share on other sites
antera309 3 Posted May 28, 2004 Report Share Posted May 28, 2004 Please let us know how the conversion goes, just2zang. I'm sure lots of people would be interested in doing this. Link to post Share on other sites
Geastb 0 Posted May 28, 2004 Report Share Posted May 28, 2004 u use the stadard vr6 calipers using the hub carriers to mount the discs correctly for 312 disk. I got them off nik saran for £50 and says they fit straight on!Where do you get the hub carriers - Nik Saren? Is there a website? What size wheels do you have? Would 16" be ok or do i have to go 17"?[ Edited Fri May 28 2004' date= 09:42AM ] Link to post Share on other sites
ChrisP 0 Posted May 28, 2004 Report Share Posted May 28, 2004 ACF - pm me, I have the 288mm setup for sale, completeRe this conversion, ask Speedo on here, he has already done it. The calipers are the same as 288mm late VR ones BTW, its just the carrier that is different Link to post Share on other sites
Geastb 0 Posted May 28, 2004 Report Share Posted May 28, 2004 Anyone got any late VR 288mm calipers for sale? Would like to do this conversion! Link to post Share on other sites
ChrisP 0 Posted May 30, 2004 Report Share Posted May 30, 2004 yes, email me at clp_reds@yahoo.comhave 288 setup and 312 setup also Link to post Share on other sites
eViL 0 Posted May 30, 2004 Report Share Posted May 30, 2004 Don't forget you can use the Mk4 1.8T 288mm set-up too.Like me. Link to post Share on other sites
six appeal 53 Posted May 30, 2004 Report Share Posted May 30, 2004 This conversion is too easy! Got to be the cheapest way to upgrade your 288mm disks. Although I would recommend making a proper spacer (easy to do) rather than a few washers.Most 17" and some 16" wheels fit over them, but best to check before you buy! Link to post Share on other sites
FishWick 21 Posted May 30, 2004 Report Share Posted May 30, 2004 u use the stadard vr6 calipers using the hub carriers to mount the discs correctly for 312 disk. I got them off nik saran for £50 and says they fit straight on!Nice trick. Using the extra leverage of the 312 discs with the existing VR calipers. A cost effective upgrade!I would think 288 setup calipers would be better as they have 30% more pad area?K Link to post Share on other sites
acf8181 0 Posted May 30, 2004 Report Share Posted May 30, 2004 anyone know if a ford galaxy v6 used vw brakes? Link to post Share on other sites
Geastb 0 Posted May 31, 2004 Report Share Posted May 31, 2004 Chris you have mail! Link to post Share on other sites
VRmonster 1 Posted May 31, 2004 Report Share Posted May 31, 2004 so will this work with the 280 calipers from an earlier car? Link to post Share on other sites
six appeal 53 Posted May 31, 2004 Report Share Posted May 31, 2004 No mate you need the 288mm Link to post Share on other sites
VRmonster 1 Posted May 31, 2004 Report Share Posted May 31, 2004 so would the 288mm calipers work on the earlier car, ie. will the s3 carriers fit my hub? i mite just save up and get some hi-spec 330mm and 4 pots.[ Edited Mon May 31 2004, 11:16PM ] Link to post Share on other sites
just2zang 0 Posted May 31, 2004 Author Report Share Posted May 31, 2004 I got to save up to buy the disks and also some suspension which might take ages as my superchargerd setup is playing up a little and i am proper skint :-(. I heard something funny today " u can tell who the vr6 drivers are.. they don't even shave cos they can't afford the razors, all their money goes on their cars..." Link to post Share on other sites
speedo 0 Posted June 2, 2004 Report Share Posted June 2, 2004 Yer. i done it and very impressed I am using original 288 calipers, and 4 motion carriers & discs.Had a friend machine a set of 5 mm spacers and bob`s ya auntie ...much`o improv`o 8o) The only snag i had was that you have to file down a tiny part of the carrier, as you are moveing it 5mm in one direction, and it catches the disc slightly....... Link to post Share on other sites
ingham 5 Posted June 14, 2004 Report Share Posted June 14, 2004 Yer. i done it and very impressed I am using original 288 calipers' date=' and 4 motion carriers & discs.Had a friend machine a set of 5 mm spacers and bob`s ya auntie ...much`o improv`o 8o) The only snag i had was that you have to file down a tiny part of the carrier, as you are moveing it 5mm in one direction, and it catches the disc slightly....... [/quote']got any pics? Link to post Share on other sites
VRmonster 1 Posted June 14, 2004 Report Share Posted June 14, 2004 so is the spacer for the carrier, or the wheels? Link to post Share on other sites
speedo 0 Posted June 14, 2004 Report Share Posted June 14, 2004 I will post some pics tomorrow ( if i remember)The 5mm spacers go between the hub and carrier, you also need the 4motion bolts, as the original bolts are obviously not long enough.. Link to post Share on other sites
