  • Replies 384
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
Finally got the engine back few more bits and it can go in :-)
Boost pipes are all cut and made ready to go on not much left now :-)
I'll throw a few pics up of what has been done :-) And that is how it's sits waiting for paint :-)
Posted Images
Nope new but I never used the lube for the bottom of the studs so guys from arp say its probably that but they were good as gold and have offered to send a replacement set free of charge better not mess it up this time I'm going to use a dial style torque wrench if i can borrow one rather than my click style just incase that was a factor luckily for me the stud cam right out and was only finger tight still
Right looking for some advice got my self my intercooler and measured space in front of rad it's tight but it goes with some modifications to the slam panel my only problem is I'm gonna replace the heat exchanger with a thermostatic controlled oil cooler and nee some ideas on we're to put it think I'm gonna go with a 19 row as its a thermostatic type it shouldn't over cool the oil ideas on we're it can go ?
Here's the spec options
I have a t3/t4 manifold with bolt on external
• Exclusive CEA (Competition Engineered Aerodynamics) compressor wheel machined from a 2618-aluminum forging
• Higher efficiency and faster transient response for maximum power and performance
• 62mm inducer compressor wheel
• Compressor cover options:
- "E" compressor cover 3.0" inlet/2.0" outlet
- "S" compressor cover 4.0" inlet/2.5" outlet
- "Ported S" compressor cover 4.0" inlet/2.5" outlet
• Exclusive CEA (Competition Engineered Aerodynamics) 66mm, 76 trim turbine wheel
• Turbine housing options:
- T3 .63 or .82 A/R with 4 bolt (2.5") discharge
- T3 .63 A/R with 5 bolt discharge (with or without wastegate hole)
- T3 .63 or .82 A/R with 3" V-Band discharge
- V-Band inlet .82 A/R with V-Band discharge
- T4 Tangential .58, .68, .81, or .96 A/R with 3 5/8" V-Band discharge
- T4 Divided .84, 1.0, 1.15, or 1.32 A/R with 3 5/8" V-Band discharge
- Buick .63 or .85 A/R
- GMC Syclone/Typhoon .85 A/R
• Available with either a Hydrodynamic 360° thrust bearing system, or an Air-cooled, dual ceramic ball-bearing center housing rotating assembly (CHRA)
While I'm waiting on some ideas on the above here's some pic
First off I removed the front panel radiator and all
Took a couple of pics of the inlet
Here's one of how absolutely tight as you like the inlet is to the alternator ( but it does fit with no touching or rubbing )
Then me oil cooler turnt up ohh hello mocal
Got the sandwich plate fitted and my god another very very tight fit but she's on none the less
And a lot more god dies are on order as we speak
