VR6Joni 1 Posted November 14, 2009 Report Share Posted November 14, 2009 Thought I'd post my current progress with remapping a Motronic on here for you guys. It still requires a bit of work, but hopefully others are gonna contribute! Link to post Share on other sites
VR6Joni 1 Posted November 14, 2009 Author Report Share Posted November 14, 2009 VR6 Motronic remapping at home courtesy of VR6Joni!What you will need:EPROM programmer, I doubt one exists that will not program a 27C512.A few 27C512's as it's annoying waiting 20mins to blank them!A UV Eraser.A 28 pin DIP socket.Soldering skills.A fairly technical mind!A laptop.VAG-COMA wide band AFR controller.First of all read which ECU you have with the VAG-COM or look at the label on it. It should look something like this:021 906 258CP. The CP is the important bit, this is the code revision which also means the maps will be at different locations in the memory. I have details of where the maps are located for AF or CP revisions up to press and will distribute them on request (PM me). This will make life much easier although I had to work out the locations for myself on my CP ECU so it is possible to do on other versions, just needs a bit of extra work.Remove the ECU! I'm sure there are several guides online, if you need to use them you probably shouldn't be doing this anyway.You can learn from my errors though! Which were the connector latch pulls further out then you may expect and no matter what you might think the ECU will come out with the bracket attached. Once it's out you need to take the the EPROM off the PCB, it's the 28 pin though hole device as pictured. You really should use a rework station for this which has a soldering iron and hot air blower in one unit. I was too eager to wait until I was in work so just used a bog standard hot air gun on LOW! in combination with a soldering iron. I find its easier if you remove excess solder first using a solder sucker. Take note of the orientation of the chip, it should be pin 1 (pin 1 is indicated by the notch on one side of the chip) closer to the centre of the PCB. Once the EPROM is removed, remove excess solder and fit the socket. Now your ready to MAP and REMAP.Original EEPROMSocket FittedNewly Mapped EEPROM in placeNow you will need to set up your EPROM programmer and read the memory with the included software and save it as a binary, make 2 copies, one as an original backup and one to modify. I save a different copy at every stage of the REMAP.Now you will need to download a copy of WINOLS Demo and TunerPro. With TunerPro you need a MAP definitions file called a .XDF, this contains information for the various MAPs in the binary file taken from your ECU's EPROM. The XDF is basically just a list of MAP labels, memory location and conversion factors etc. I have XDF's for the CP and AF ECU's at the moment these may be compatible with other versions though.Install TunerPro and run it, then open a XDF file, the correct one if possible. Then open your .bin file, you should then be able to open various MAP's and you should be looking at a pattern of numbers in a table, if they are random or all the same your probable gonna have to modify the XDF to suit your ECU revision, if it looks like good data ignore the next paragraph.If you need to modify the .XDF file install WINOLS and run it. Create a project with a known binary eg. AF and allow it to find all potential MAPs. Then create another project with your ECUs binary. You should see 2 sets of very similar potential maps, what I would recommend you do is write the address of each known map down in order and look where they are in the potential maps list. Eg. you could find fuel wide open throttle (12x12 MAP) is between a 4x8 MAP and another 12x12 MAP, which just happens to be idle fuelling and WOT map 2. You should be able to see this pattern in your binary with very similar numbers if not the same. Continue this process until you have found all the MAPs that you wish to edit. Note down all the locations and then modify the XDF file to suit. Hopefully now you should have what looks like valid data in TunerPro.Now its time to remap.I'm assuming you've probably done some significant mods by this stage and want to make the use of it so I'll start with WOT maps. If you've done something serious like turbo or supercharge your VR you may well have used Crazy/SensibleDaves (Big thanks to Dave for this) potentiometer mod to get you going, I used an active electronic version to guarantee a linear output. Adjust this to minimise adaption values in measuring block 6 using VAG-COM, you'll have to clock up a few miles for these to appear. Otherwise adjust it so that AFR is good on initial startup and driving.Now you have a drivable car its time to generate some logs, I log ignition timing with VAG-COM and the AFR with Logworks2 software which was included with my Innovate LC-1. Find an airstrip, start logging, stick it in third at idle engine speed and floor it to the redline making sure AFR's stay at none engine killing levels, repeat this logging procedure a few times.For Fuel WOT maps:With your results generate an error factor value table throughout the rev range, I do this by taking a reference point I.e. when you change into 4th, using that point in time write down the AFR's logged next to the engine speeds from the VAGCOM log and work your way backwards referencing the times on the AFR log against the times in the VAGCOM log. Once you have an error factor table copy the Fuel WOT MAP from TunerPro into a spreadsheet and multiply the values by the corresponding engine speed error factors. Then copy the results back into TunerPro, I converted them to an integer in the spreadsheet using the following formula:New Map Value =int(OldMAPValue*ErrorFactor)Example spreadsheet used to calculate corrections requiredI found that just changing Fuel WOT MAP 1 works, so what MAP 2 does if a mystery, answers on a postcard please! Or a PM will do.Ignition is a bit more of an art, I look at the timing in the logs and simply adjust timings to try and eliminate detonation. You can tell that knock has been detected as you'll see that the ECU has retarded the timing away from the map values, it does it in quite large steps and is obvious as you see timing jump away from the MAP values by about 5 degrees at a time. (see 5800rpm on example spreadsheet)When you are happy with the changes that have been made save the binary and program a new EPROM with the binary file saved in TunerPro. Plug the new EPROM into the ECU, put the ECU back in the car and take it for a blast, once again logging everything. Repeat the steps above as many times as it takes until your happy, blank the EPROM in the UV eraser as soon as you remove it as when it comes to making smaller tweaks it gets annoying waiting, hence having a couple spare.Original maps as viewed in TunerProMy slightly tweaked MAPsExample AFR Log Benvrg 1 Link to post Share on other sites
FishWick 21 Posted November 16, 2009 Report Share Posted November 16, 2009 Good stuff!!I feel this is a sticky worthy thread :-) Link to post Share on other sites
UnitedMotorsport 55 Posted November 16, 2009 Report Share Posted November 16, 2009 Excellent. Is the checksumm in this causing you any problems? Link to post Share on other sites
VR6Joni 1 Posted November 16, 2009 Author Report Share Posted November 16, 2009 Ok, now its possible to drive flat out you might also want your engine to idle nicely.I determined idle fuelling levels by taking note of the fuelling adaption levels in block 6 using VAGCOM, basically with my setup I hit the idle adaption level limit without any tweeking (I believe this is about +/- 0.3). On initial setup I set up partial throttle adaption level to as close to 1.00 as possible, i.e. 14.7 on the AFR gauge when driving under partial throttle. This was done by tweeking the MAF potentiometer, I'd highly recommend using a multi turn potentiometer as a single turn pot is very sensitive.Once you have a good partial throttle adaption level (near to 1.00 as possible) and remapped the WOT you should only be left with a problem with the idle adaption level, I saw idle adaption levels of ~0.7 which threw up a fault code. Initially I took a full 30% off the idle fuelling levels, this was way too much and the idle adaption levels went to ~1.3 which gave me another fault code. I found that about 85% of the origional fuelling levels gave me acceptable results (i.e. didn't throw up any fault codes) Link to post Share on other sites
VR6Joni 1 Posted November 16, 2009 Author Report Share Posted November 16, 2009 Excellent. Is the checksumm in this causing you any problems?Ah, I was wandering when this would come up, yes and no is the answer. Yes in that it throws up a fault code, but no it doesn't seem to have any adverse effects.I have managed to get TunerPro to generate a checksum for the whole EEPROM, but this is wrong. I.e. I cant get it to match an original map. I can only assume that there is multiple checksums, one for the code and one for the map data, at some stage I will get round to finding the EEPROM ranges for each checksum and post my findings.That is of course if anyone else doesn't beat me to it.This is only a side project of mine so I don't spend too much time on it. So the checksum issue may be a while. Link to post Share on other sites
UnitedMotorsport 55 Posted November 16, 2009 Report Share Posted November 16, 2009 The checksum on these OBD1 ECU's wont stop the engine from running, it just throws a fault ode Link to post Share on other sites
VR6Pete 1,455 Posted November 16, 2009 Report Share Posted November 16, 2009 Good stuff!!I feel this is a sticky worthy thread :-)Indeed it is.... Link to post Share on other sites
VR6Joni 1 Posted November 16, 2009 Author Report Share Posted November 16, 2009 The checksum on these OBD1 ECU's wont start the engine from running' date=' it just throws a fault ode [/quote']I had a look earlier and think I may have sussed it on my 258CP code unless it was a fluke, I believe the checksum is just before the ECU software version number which is at EF00 (sum of 0000-EEFF) in my version, however I couldn't make it work on another couple of binaries I have (258AF and 258AP) but the software version number is at a different location but even when I modify the checksum location and range I can't get it to match. I'll test my 258CP attempt next time the engine is in a runable condition.If anyone else has any idea's of checksum ranges and locations that would be very useful as I'm quite new to Bosch software. Link to post Share on other sites
VR6Joni 1 Posted November 24, 2009 Author Report Share Posted November 24, 2009 Ok, I have now sorted the checksum issue. I was correct as above. Obviously the engine doesn't need to be running to throw this fault up. Doh! Link to post Share on other sites
redeye 0 Posted March 8, 2010 Report Share Posted March 8, 2010 check this link out some good info http://www.ecuconnections.com/forum/viewtopic.php?f=2&t=404&start=0 Link to post Share on other sites
FishWick 21 Posted March 9, 2010 Report Share Posted March 9, 2010 Looks like a great forum, good shout! Link to post Share on other sites
RBPE 198 Posted March 18, 2013 Report Share Posted March 18, 2013 Lot's on Nef Moto too regarding Bosch tuning.http://www.nefariousmotorsports.com/wiki/index.php/NefMoto_ECU_Flashing_Software Link to post Share on other sites
RBPE 198 Posted January 19, 2014 Report Share Posted January 19, 2014 I hybrided an R32 NA map with a 20vt map to take into account the variances between the ECU's (i.e. R32 change-over barrel on the VRIM v's the 20vt SRIM, different cam controls etc) and have the major map areas for them both here. Not perfect English as some bits are just straight from the translator machines but cut and paste is easier than translator! I'll put up some screen shots of fully English translated VR6 maps I have (12v/24v & R32) in the near future if that's of help to anyone? Here are a lot of the main areas you will find when tinkering with winOLS - (the map areas change depending on what ECU it is, i.e. different levels of cam timing such as the AUE v's BDE etc): ABKVP: Booster pump controlACIFI: Output for each individual cylinder injectionADVE: Activation of the DV-E by means of the DLRAEKP: Output EKP controlAEVAB: Output injection EV-suppressionAEVABU: Output injection cut-off by monitoring functions (EGAS)ALE: Discharge detectionALSU: Output function LSUANSWE: Controlling connected intake camshaftARMD: Moments based anti-judder systemATEV: Control tank purge valve (period)ATM: Exhaust gas temperature modelATR: Exhaust gas temperature controlAZUE: Output ignitionBBBO: Start operating range with fuel in oilBBDLS: Operating range digital idle stabiliserBBDNWS: Diagnosis function: camshaft operating statusBBGANG: Detection of actual gearBBKD: Calculation of kick-down informationBBKHZ: Control of CAT heatingBBNWS: Operating status: enabling the cam shaft controlBBPHSYN: Operating range; phase synchronizationBBSAWE: Conditions for fuel cut-off/cut-inBBSTT: Conditions; Engine start (operating range)BBTEGA: Operating conditions for purge canister control/fuel adaptationBBZMS: Operating range ZMS protectionBGARNW: Calc. Size requirement camshafts adaptationsBGCVN: Calc size calibration verification number CVNBGDVE: Values for DV-E control from the learning and checking routinesBGGNSOL: Calc. Variable; target gear-influenced engine speedBGLBZ: Calculated charge deficit of the batteryBGMIL: Calculated size; controlling MIL (Malfunction Indication Lamp)BGMSABG: Calculation of exhaust emission mass flow – bank dependentBGMSZS: Calculation of mass flow into the intake manifoldBGNG: Calc variable; engine speed gradientBGPIRG: Calc. Of interval residual gas fractionBGPLGU: Calculation of the base boost pressure – turbo engineBGPUK: Size calculation ambient pressure corrected (downhill recognition)BGRBS: Calculated size wheel acceleration from wheel speedBGRLP: Calculated variable rlp; predicted air chargeBGRML: Calculated value of relative air mass according to SAE J1979 mode $01 & $o2 PIDBGSRM: Charge detection intake manifoldBGTABST: Calculated variable; cut-off timeBGTEMPK: Charge detection temp compensation calculation for intake manifold modelBGTEV: Calculation variable; mass flow from TEVBGTOL: Calculated size (motor) oil temperatureBGTUMG: Calc. Variable; ambient temperatureBGVMAX: Calc variable for (vmax) speed controlBGWDKM: Calculation of throttle angle modelBGWPFGR: Calc. Var; back calculated pedal value for FGRBKV: Pressure control for brake boosterCAN: Can signal listDATR: Diagnosis; Exhaust gas controlDATS: Diagnosis; Exhaust gas sensorDBKVP: Diagnosis; booster pumpDBUKSUE: Diagnosis; intake manifold amplifierDCDACC: Diagnosis; access to tester dataDCLA: OBD II Classification tableDDCY: OBD II Fulfilment condition “driving cycle”DDG: Diagnosis; Engine speed sensor/tachometerDDSBKV: Diagnosis; pressure sensor for brake boosterDDVE: Diagnosis; EGAS Actuator DV-EDECJ: Diag; Power stage CJ9x (CJ4x/9x)DEGFE: Diag; of input variables for charge detectionDEKPE: Diag. Power stage of fuel pump relayDEPCL: Diag; Electronic powertrain control lampDFFTCNV: Diag. Freeze frame table, conversion to bytesDFPM: OBD II, Fault path managerDFPMEEP: Diagnostic function; error path manager EEPROM storageDFPMNL: Diagnostic function; error path management at the overrunDFPMOVF: Diagnostic function; error path, memory overflowDHFM: Diagnosis; Plausibility test MAFDHLSHK: Diagnosis; Sensor heating after CATDHLSU: Diagnosis; heating LSUDHR: Diagnostic function; Main relayDHRLSU: Diag; Heating control LSUDHRLSUE: Diag; heating stage for systems with Cjxxx diagnostic ES-blockDIMC: OBD II Inspection/Maintenance readyDIMCAGR: Diagnostic inspection maintenance code Exhaust gas recirculation system monitorDIMCHLS: Diagnostic inspection maintenance code; LS-heating monitoringDIMCKAT: Diagnostic inspection maintenance code; CAT monitoringDIMCLSV: Diagnostic inspection maintenance code; Oxygen sensor monitoringDIMCSLS: Diagnostic inspection maintenance code; Secondary air system monitoringDIMCTES: Diagnostic inspection maintenance code; Tank ventilation systemDKATLRS: Diagnosis; Catalytic converterDKRA: Diag. Function; Knock controlDKRNT: Diag; knock control, zero test (OBD II)DKRS: Diag; Knock sensor (OBD II)DKRTP: Diagnostic of knock control, test pulse for OBD IIDKUPPL: Diagnostic function; Clutch switchDKVS: Diagnostic; Plausibility test fuel supply systemDLDP: OBD II, Tank ventilation diagnostic function; moduleDLDPE: Final stage diagnostic; pressure pump of tank diagnosticDLDR: LDR DiagnosticDLDUV: Diagnostic; Diverter valve for turbo engineDLLR: Diagnostic; Idle speed control, recognition of blocked actuatorDLSAHK: Ageing monitoring for Lambda sensor downstream of CATDLSH: Diagnostic; Readiness for operation of CAT downstream sensorDLSHV: Diagnosis, detection exchanged Lambda probe behind catalytic converterDLSSA: Signal ouput from lambda sensorsDLSU: Diagnostic; Continuous Lambda probe LSUDLSUV: Recognition exchanged oxygen sensors before catalytic converterDMDDLU: Diagnostic routine misfire detection forming the difference for rough runningDMDFON: Diagnosis misfire detection fuel-on adaptationDMDLU: Diagnose misfire detection; rough runningDMDLU_C: Diagnostic routine; misfire detectionDMDLUA: Diagnostic routine; misfire detection rough running spacing/distance measurementsDMDMIL: Error handling of misfire detection, triggering the MIL and rectificationDMDSTP: Diagnosis; Misfire detection; stop conditionsDMDTSB: Diagnosis; misfire detection; segment time educationDMFB: OBD II MIL externally determinedDMIL: OBD II, MIL ControlDNMAX: Diagnosis, plausibility test maximum speed is exceededDNWKW: Diag; Alignment between camshaft and crankshaftDNWSAUS: Diagnosis camshaft control (outlet side)DNWSEAUS: Diagnosis cam control (outlet side) final stageDNWSEEIN: Diagnosis of the camshafts stage (inlet side)DNWSEIN: Diagnosis; Cam timing (inlet side)DPH: Diag. Plausibility test phase sensorDSLSLRS: Diag; Secondary air system with constant lambda controlDSWEC: Bad drive from wheel-Accel, -.> via CAN ABS SG to MotronicDSWES: Rough road detection by means of statistics of the engine uneven runningDTANKL: OBDII diagnostic errors due to an empty tankDTEV: Diag; Canister purge valve (OBD II)DTHM: Thermostat diagnosis engine coolantDUF: Diagn; of functional monitoringDUMMY: Dummy SectionDVFZ: Diagnostic plausibility check; vehicle speedDWUC: OBD II; Fulfilment condition “warm up cycle”DZUEET: Diag; End stage driverESGRU: Basic injectionESNST: Injection after startESNSWL: Injection during afterstart & warm-upESSTT: Injection duration at startESUK: Injection; transient compensationESUKAS: Adaptation of the transitional compensation (with constant lambda control)ESVW: Injection; calculation of injection angleESWE: Injection; resumption of overrun fuel cut-offESWL: Injection Warm-upFGRABED: Switch off cruise controlFGRFULO: Functional logic; cruise controlFGRREGL: Control algorithm cruise controlFUEDK: Charge control (calculation of nominal throttle valve angle)FUEDKSA: Influence of air charge by throttle blade, processing throttle angleFUEREG: Charge controlGGATS: Master variable; Exhaust gas temperatureGGCASR: Master variable; CAN signals for ASR/MSRGGCGRA: Master variable; GRA control levers with CANGGCS: Master variable; crash sensorGGTOL: Master variable oil temperature via CANGGCTUM: Master variable ambient temperature via CANGGDPG: Input signals; tachometer and encoder phaseGGDSAS: Master variable; intake manifold pressure sensors outsideGGDST: Master variable; Tank pressure sensorGGDVE: Sensor variables for throttle valve actuatorGGEGAS: Master variable; brake and clutch switchGGFGRH: Master variables; operating lever for cruise controlGGFST: Master variable tank levelGGGTS: Master variable; accurate temperature signalGGHFM: Encoder signal MAFGGKLDF: Master variable; DFM terminal of generatorGGKS: Master variable; Knock sensorGGLSH: Master variable; Lambda probe signal (Nernst type) after CATGGLSU: Encoder signal LSUGGNW: Adaptation angle of camshaft relative to crankshaftGGPBKV: Master variable pressure for brake boosterGGPED: Master variable; Accelerator pedalGGTFA: Master variable; TFA Intake air temp sensorGGTFM: Signal engine temp sensor (coolant)GGUB: Master variable; Battery voltage including diagnosticsGGUBR: Encoder size & diagnostic board network voltage across main relayGGVFZG: Master variable vehicle speedGGZDGON: Master variable; terminal 15GK: Mixture controlHLSHK: Probe heating after CATHLSU: Heating steady lambda sensors LSUHRLSU: Heating control continuous lambda probe LSUKHMD: Calculation of reserve torque for CAT heatingKOS: Air compressor – controlKRDY: Knock control for load dynamicsKRKE: Knock detectionKRRA: Adaptive knock controlKUA: Output signal; fuel consumption displayLAKH: Lambda coordination for CAT'sLAMBTS: Lambda component protectionLAMFAW: Lambda drivers requestLAMKO: Lambda coordinationLANSWL: Lambda afterstart/warm upLDOB: LDR OverboostLDRLMX: Calculation of LDR max fuelling (rlmax)LDRPID: LDR (Boost pressure control) PID – RegulatorLDRPLS: Calculating target boostLDTVMA: Preperation & output duty cycleLDUVST: LDR Diverter valve controlLLRBB: Operating conditions of idle speed controlLLRMR: Torque reserve for idle speed controlLLRNFA: Target speed boost when short tripLLRNS: Idle speed control, set speedLLRRM: Idle speed control; torque controllerLRA: Lambda closed loop control; adaptive pilot controlLRAEB: Switch – mixture adaptationLRS: Continuous lambda controlLRSEB: Switch – continuous lambda controlLRSHK: Lambda control (steady) after CATLRSKA: Continuous catalyst lambda control additional function clearingMDBAS: Basic calculations for torque interfaceMDBGRG: Torque limitation minimumMDFAW: Calc. Of vehicle operator demand/drivers torque requestMDFUE: Nominal value input from nominal torque for airmassMDIST: Motor torque calculationMDKOG: Torque coordination for overall interventionMDKOL: Torque coordination on filling levelMDMAX: Calculation maximum torqueMDMIN: Calculation minimum torqueMDNSTAB: Torque; engine speed stabilisationMDRED: Calc of reduction stage torque requirementMDTRIP: Calc of torque reserve for short tripMDVER: Loss in engine torqueMDVERAD: Adaptation of torque lossMDVERB: Torque demand by auxiliary systems (air con etc)MDWAN: Torque of the AT converterMDZUL: Calc of max permitted set torqueMDZW: Calc of torque in nominal ignition firingMOTAUS: Engine switch-off/shutdownNLDG: Emergency speed encoder (limp mode) for defective engine speed sensorNLPH: Limp-home mode for phase synchronizationNMAXMD: Torque calc during max speed controlNWEVO: Camshaft; limited adjustment for oil pressureNWFW: Calculation factor angle camshaftNWSFAT: Cam control, setpoint with testerNWSOLLA: Setpoint cams (NWS) (exhaust)NWSOLLE: Setpoint cams (NWS) (inlet)NWWUE: Calculation of camshaft overlapPROKON: Project configurationRDE: Detection of reverse rotationRKTI: Calculation of injection time (ti) from relative fuel mass (rk)SGAAU: Feed forward AU IISLS: Secondary air controlSRMHFM: Intake manifold model MAFSTADAP: Starting fuel adaptationSTARTUF: PowerfailSTMD: Start momentSU: Intake manifold switch-overSWADP: Software adapterTC (then a number) MOD: Carb communications modesTEB: Purge canister functionTEBEB: Switch-on conditions for purge controlTKMWL: Testers communications, read measured valuesTKSTA: Testers communications; actuator driveUFACCC: EGAS monitoring concept; ACC input signal monitoring functions monitoringUFFGRC: ETS monitoring concept; monitoring of cruise control for function monitoringUFFGRE: ETS monitoring concept; CC input information used in functional monitoringUFMIST: ETS monitoring concept; Calculation of actual torque in UFUFMSRC: ETS monitoring concept; MSR intervention monitoring for functions monitoringUFMVER: ETS monitoring concept; torque comparison of functional monitoringUFMZF: ETS monitoring concept; torque filter for function monitoringUFMZUL: ETS monitoring concept; Calculation of permissible torque in UFUFNC: ETS monitoring concept; Afterstart monitoring for function monitoringUFNSC: ETS monitoring concept; Afterstart monitoring for function monitoringUFREAC: ETS monitoring concept; Monitoring of fault reaction of functional monitoringUFRLC: EGAS monitoring concept; load signal superv for function monitoringUFSPSC: EGAS monitoring of pedal value for functionUFZWC: EGAS monitoring concept; Monitoring of ignition angle for function monitoringUMKOM: ETS monitoring concept; Enquiry/response communication between UM/FRURADCC: ETS monitoring concept; test of AD converterURROM: ETS monitoring concept; ROM testVMAXMD: Torque requirement of VMAX controlVS_VERST: Adjusting parameters for the momentWDKSOM: Calculation of desired throttle angle without torque structureWNWRA: Exhaust cam position controlWNWRE: Inlet cam position controlZUE: Basic function; IgnitionZUESZ: Ignition; calculation of coil closing timeZWGRU: Basic ignition angleZWMIN: Calculation of maximum retarded spark limitationZWOB: OverboostZWSTT: Ignition at the startZWWL: Ignition angle during warm up VR6Pete 1 Link to post Share on other sites
VR6Pete 1,455 Posted January 24, 2014 Report Share Posted January 24, 2014 I hybrided an R32 NA map with a 20vt map to take into account the variances between the ECU's (i.e. R32 change-over barrel on the VRIM v's the 20vt SRIM, different cam controls etc) and have the major map areas for them both here. Not perfect English as some bits are just straight from the translator machines but cut and paste is easier than translator! I'll put up some screen shots of fully English translated VR6 maps I have (12v/24v & R32) in the near future if that's of help to anyone? Here are a lot of the main areas you will find when tinkering with winOLS - (the map areas change depending on what ECU it is, i.e. different levels of cam timing such as the AUE v's BDE etc): ABKVP: Booster pump control ACIFI: Output for each individual cylinder injection ADVE: Activation of the DV-E by means of the DLR AEKP: Output EKP control AEVAB: Output injection EV-suppression AEVABU: Output injection cut-off by monitoring functions (EGAS) ALE: Discharge detection ALSU: Output function LSU ANSWE: Controlling connected intake camshaft ARMD: Moments based anti-judder system ATEV: Control tank purge valve (period) ATM: Exhaust gas temperature model ATR: Exhaust gas temperature control AZUE: Output ignition BBBO: Start operating range with fuel in oil BBDLS: Operating range digital idle stabiliser BBDNWS: Diagnosis function: camshaft operating status BBGANG: Detection of actual gear BBKD: Calculation of kick-down information BBKHZ: Control of CAT heating BBNWS: Operating status: enabling the cam shaft control BBPHSYN: Operating range; phase synchronization BBSAWE: Conditions for fuel cut-off/cut-in BBSTT: Conditions; Engine start (operating range) BBTEGA: Operating conditions for purge canister control/fuel adaptation BBZMS: Operating range ZMS protection BGARNW: Calc. Size requirement camshafts adaptations BGCVN: Calc size calibration verification number CVN BGDVE: Values for DV-E control from the learning and checking routines BGGNSOL: Calc. Variable; target gear-influenced engine speed BGLBZ: Calculated charge deficit of the battery BGMIL: Calculated size; controlling MIL (Malfunction Indication Lamp) BGMSABG: Calculation of exhaust emission mass flow – bank dependent BGMSZS: Calculation of mass flow into the intake manifold BGNG: Calc variable; engine speed gradient BGPIRG: Calc. Of interval residual gas fraction BGPLGU: Calculation of the base boost pressure – turbo engine BGPUK: Size calculation ambient pressure corrected (downhill recognition) BGRBS: Calculated size wheel acceleration from wheel speed BGRLP: Calculated variable rlp; predicted air charge BGRML: Calculated value of relative air mass according to SAE J1979 mode $01 & $o2 PID BGSRM: Charge detection intake manifold BGTABST: Calculated variable; cut-off time BGTEMPK: Charge detection temp compensation calculation for intake manifold model BGTEV: Calculation variable; mass flow from TEV BGTOL: Calculated size (motor) oil temperature BGTUMG: Calc. Variable; ambient temperature BGVMAX: Calc variable for (vmax) speed control BGWDKM: Calculation of throttle angle model BGWPFGR: Calc. Var; back calculated pedal value for FGR BKV: Pressure control for brake booster CAN: Can signal list DATR: Diagnosis; Exhaust gas control DATS: Diagnosis; Exhaust gas sensor DBKVP: Diagnosis; booster pump DBUKSUE: Diagnosis; intake manifold amplifier DCDACC: Diagnosis; access to tester data DCLA: OBD II Classification table DDCY: OBD II Fulfilment condition “driving cycle” DDG: Diagnosis; Engine speed sensor/tachometer DDSBKV: Diagnosis; pressure sensor for brake booster DDVE: Diagnosis; EGAS Actuator DV-E DECJ: Diag; Power stage CJ9x (CJ4x/9x) DEGFE: Diag; of input variables for charge detection DEKPE: Diag. Power stage of fuel pump relay DEPCL: Diag; Electronic powertrain control lamp DFFTCNV: Diag. Freeze frame table, conversion to bytes DFPM: OBD II, Fault path manager DFPMEEP: Diagnostic function; error path manager EEPROM storage DFPMNL: Diagnostic function; error path management at the overrun DFPMOVF: Diagnostic function; error path, memory overflow DHFM: Diagnosis; Plausibility test MAF DHLSHK: Diagnosis; Sensor heating after CAT DHLSU: Diagnosis; heating LSU DHR: Diagnostic function; Main relay DHRLSU: Diag; Heating control LSU DHRLSUE: Diag; heating stage for systems with Cjxxx diagnostic ES-block DIMC: OBD II Inspection/Maintenance ready DIMCAGR: Diagnostic inspection maintenance code Exhaust gas recirculation system monitor DIMCHLS: Diagnostic inspection maintenance code; LS-heating monitoring DIMCKAT: Diagnostic inspection maintenance code; CAT monitoring DIMCLSV: Diagnostic inspection maintenance code; Oxygen sensor monitoring DIMCSLS: Diagnostic inspection maintenance code; Secondary air system monitoring DIMCTES: Diagnostic inspection maintenance code; Tank ventilation system DKATLRS: Diagnosis; Catalytic converter DKRA: Diag. Function; Knock control DKRNT: Diag; knock control, zero test (OBD II) DKRS: Diag; Knock sensor (OBD II) DKRTP: Diagnostic of knock control, test pulse for OBD II DKUPPL: Diagnostic function; Clutch switch DKVS: Diagnostic; Plausibility test fuel supply system DLDP: OBD II, Tank ventilation diagnostic function; module DLDPE: Final stage diagnostic; pressure pump of tank diagnostic DLDR: LDR Diagnostic DLDUV: Diagnostic; Diverter valve for turbo engine DLLR: Diagnostic; Idle speed control, recognition of blocked actuator DLSAHK: Ageing monitoring for Lambda sensor downstream of CAT DLSH: Diagnostic; Readiness for operation of CAT downstream sensor DLSHV: Diagnosis, detection exchanged Lambda probe behind catalytic converter DLSSA: Signal ouput from lambda sensors DLSU: Diagnostic; Continuous Lambda probe LSU DLSUV: Recognition exchanged oxygen sensors before catalytic converter DMDDLU: Diagnostic routine misfire detection forming the difference for rough running DMDFON: Diagnosis misfire detection fuel-on adaptation DMDLU: Diagnose misfire detection; rough running DMDLU_C: Diagnostic routine; misfire detection DMDLUA: Diagnostic routine; misfire detection rough running spacing/distance measurements DMDMIL: Error handling of misfire detection, triggering the MIL and rectification DMDSTP: Diagnosis; Misfire detection; stop conditions DMDTSB: Diagnosis; misfire detection; segment time education DMFB: OBD II MIL externally determined DMIL: OBD II, MIL Control DNMAX: Diagnosis, plausibility test maximum speed is exceeded DNWKW: Diag; Alignment between camshaft and crankshaft DNWSAUS: Diagnosis camshaft control (outlet side) DNWSEAUS: Diagnosis cam control (outlet side) final stage DNWSEEIN: Diagnosis of the camshafts stage (inlet side) DNWSEIN: Diagnosis; Cam timing (inlet side) DPH: Diag. Plausibility test phase sensor DSLSLRS: Diag; Secondary air system with constant lambda control DSWEC: Bad drive from wheel-Accel, -.> via CAN ABS SG to Motronic DSWES: Rough road detection by means of statistics of the engine uneven running DTANKL: OBDII diagnostic errors due to an empty tank DTEV: Diag; Canister purge valve (OBD II) DTHM: Thermostat diagnosis engine coolant DUF: Diagn; of functional monitoring DUMMY: Dummy Section DVFZ: Diagnostic plausibility check; vehicle speed DWUC: OBD II; Fulfilment condition “warm up cycle” DZUEET: Diag; End stage driver ESGRU: Basic injection ESNST: Injection after start ESNSWL: Injection during afterstart & warm-up ESSTT: Injection duration at start ESUK: Injection; transient compensation ESUKAS: Adaptation of the transitional compensation (with constant lambda control) ESVW: Injection; calculation of injection angle ESWE: Injection; resumption of overrun fuel cut-off ESWL: Injection Warm-up FGRABED: Switch off cruise control FGRFULO: Functional logic; cruise control FGRREGL: Control algorithm cruise control FUEDK: Charge control (calculation of nominal throttle valve angle) FUEDKSA: Influence of air charge by throttle blade, processing throttle angle FUEREG: Charge control GGATS: Master variable; Exhaust gas temperature GGCASR: Master variable; CAN signals for ASR/MSR GGCGRA: Master variable; GRA control levers with CAN GGCS: Master variable; crash sensor GGTOL: Master variable oil temperature via CAN GGCTUM: Master variable ambient temperature via CAN GGDPG: Input signals; tachometer and encoder phase GGDSAS: Master variable; intake manifold pressure sensors outside GGDST: Master variable; Tank pressure sensor GGDVE: Sensor variables for throttle valve actuator GGEGAS: Master variable; brake and clutch switch GGFGRH: Master variables; operating lever for cruise control GGFST: Master variable tank level GGGTS: Master variable; accurate temperature signal GGHFM: Encoder signal MAF GGKLDF: Master variable; DFM terminal of generator GGKS: Master variable; Knock sensor GGLSH: Master variable; Lambda probe signal (Nernst type) after CAT GGLSU: Encoder signal LSU GGNW: Adaptation angle of camshaft relative to crankshaft GGPBKV: Master variable pressure for brake booster GGPED: Master variable; Accelerator pedal GGTFA: Master variable; TFA Intake air temp sensor GGTFM: Signal engine temp sensor (coolant) GGUB: Master variable; Battery voltage including diagnostics GGUBR: Encoder size & diagnostic board network voltage across main relay GGVFZG: Master variable vehicle speed GGZDGON: Master variable; terminal 15 GK: Mixture control HLSHK: Probe heating after CAT HLSU: Heating steady lambda sensors LSU HRLSU: Heating control continuous lambda probe LSU KHMD: Calculation of reserve torque for CAT heating KOS: Air compressor – control KRDY: Knock control for load dynamics KRKE: Knock detection KRRA: Adaptive knock control KUA: Output signal; fuel consumption display LAKH: Lambda coordination for CAT's LAMBTS: Lambda component protection LAMFAW: Lambda drivers request LAMKO: Lambda coordination LANSWL: Lambda afterstart/warm up LDOB: LDR Overboost LDRLMX: Calculation of LDR max fuelling (rlmax) LDRPID: LDR (Boost pressure control) PID – Regulator LDRPLS: Calculating target boost LDTVMA: Preperation & output duty cycle LDUVST: LDR Diverter valve control LLRBB: Operating conditions of idle speed control LLRMR: Torque reserve for idle speed control LLRNFA: Target speed boost when short trip LLRNS: Idle speed control, set speed LLRRM: Idle speed control; torque controller LRA: Lambda closed loop control; adaptive pilot control LRAEB: Switch – mixture adaptation LRS: Continuous lambda control LRSEB: Switch – continuous lambda control LRSHK: Lambda control (steady) after CAT LRSKA: Continuous catalyst lambda control additional function clearing MDBAS: Basic calculations for torque interface MDBGRG: Torque limitation minimum MDFAW: Calc. Of vehicle operator demand/drivers torque request MDFUE: Nominal value input from nominal torque for airmass MDIST: Motor torque calculation MDKOG: Torque coordination for overall intervention MDKOL: Torque coordination on filling level MDMAX: Calculation maximum torque MDMIN: Calculation minimum torque MDNSTAB: Torque; engine speed stabilisation MDRED: Calc of reduction stage torque requirement MDTRIP: Calc of torque reserve for short trip MDVER: Loss in engine torque MDVERAD: Adaptation of torque loss MDVERB: Torque demand by auxiliary systems (air con etc) MDWAN: Torque of the AT converter MDZUL: Calc of max permitted set torque MDZW: Calc of torque in nominal ignition firing MOTAUS: Engine switch-off/shutdown NLDG: Emergency speed encoder (limp mode) for defective engine speed sensor NLPH: Limp-home mode for phase synchronization NMAXMD: Torque calc during max speed control NWEVO: Camshaft; limited adjustment for oil pressure NWFW: Calculation factor angle camshaft NWSFAT: Cam control, setpoint with tester NWSOLLA: Setpoint cams (NWS) (exhaust) NWSOLLE: Setpoint cams (NWS) (inlet) NWWUE: Calculation of camshaft overlap PROKON: Project configuration RDE: Detection of reverse rotation RKTI: Calculation of injection time (ti) from relative fuel mass (rk) SGAAU: Feed forward AU II SLS: Secondary air control SRMHFM: Intake manifold model MAF STADAP: Starting fuel adaptation STARTUF: Powerfail STMD: Start moment SU: Intake manifold switch-over SWADP: Software adapter TC (then a number) MOD: Carb communications modes TEB: Purge canister function TEBEB: Switch-on conditions for purge control TKMWL: Testers communications, read measured values TKSTA: Testers communications; actuator drive UFACCC: EGAS monitoring concept; ACC input signal monitoring functions monitoring UFFGRC: ETS monitoring concept; monitoring of cruise control for function monitoring UFFGRE: ETS monitoring concept; CC input information used in functional monitoring UFMIST: ETS monitoring concept; Calculation of actual torque in UF UFMSRC: ETS monitoring concept; MSR intervention monitoring for functions monitoring UFMVER: ETS monitoring concept; torque comparison of functional monitoring UFMZF: ETS monitoring concept; torque filter for function monitoring UFMZUL: ETS monitoring concept; Calculation of permissible torque in UF UFNC: ETS monitoring concept; Afterstart monitoring for function monitoring UFNSC: ETS monitoring concept; Afterstart monitoring for function monitoring UFREAC: ETS monitoring concept; Monitoring of fault reaction of functional monitoring UFRLC: EGAS monitoring concept; load signal superv for function monitoring UFSPSC: EGAS monitoring of pedal value for function UFZWC: EGAS monitoring concept; Monitoring of ignition angle for function monitoring UMKOM: ETS monitoring concept; Enquiry/response communication between UM/FR URADCC: ETS monitoring concept; test of AD converter URROM: ETS monitoring concept; ROM test VMAXMD: Torque requirement of VMAX control VS_VERST: Adjusting parameters for the moment WDKSOM: Calculation of desired throttle angle without torque structure WNWRA: Exhaust cam position control WNWRE: Inlet cam position control ZUE: Basic function; Ignition ZUESZ: Ignition; calculation of coil closing time ZWGRU: Basic ignition angle ZWMIN: Calculation of maximum retarded spark limitation ZWOB: Overboost ZWSTT: Ignition at the start ZWWL: Ignition angle during warm up I'm sure be screenshots will be useful buddy - get them uploaded Club Chairman Link to post Share on other sites
MonzaVR6T 3 Posted February 7, 2014 Report Share Posted February 7, 2014 This topic interests me a lot! My last few evenings have been spent looking at remaps, standalone, getting my old Megasquirt 2 out and changing it for 6 coil wasted spark used to have it running on my 1.8T conversion all self mapped. I'm going to need newer maps for my turbo'd 2.9 VR6 OBD1. I have found quite a lot of information on it mostly from Broke 4 Speed there are some XDF definitions for TunerPro.From what I can see I can either burn chips and log using vag com then reburn the chip etc. By far the best setup is the Ostrich 2.0 from Moates.net which replaces the EEPROM in the ECU with a hardware emulator. Plug in by USB and you can live trace the maps to see which bins to edit and make on the fly bumpless changes to the maps using tunerpro. unplug the USB and it works as a chip again. So it basically turns my OEM VW OBD1 ECU into a Motronic standalone with the ability to still use vag-com for diagnostics and fault codes. The ultimate in my opinion and it's $175 and free/donate software This is pretty much an ideal solution as I see it.Maybe your work on this and the other info from B4S on the Vortex can be pulled together and a confident marking of maps and hex locations can only be a good thing!!Also from what I have read the checksum is recalculated using tunerpro and a certain range of Hex locations from 0000 to CEFF as per the thread here (unsure on link policy!) http://www.vwforum.com/forums/f11/obd1-motronic-tuning-thread-43655/ I have tried WINOLS before but found it a bit awkward I shall revisit it now I have the standard VR6 map bin to tinker with, Have you tuned for boost on a 12v VR6 OBD1 as yet? a link to some of your musings would be nice to work with.I actually think I can get this to work for me I have the power! \0/ Link to post Share on other sites
RBPE 198 Posted February 17, 2014 Report Share Posted February 17, 2014 Expensive systems and interfaces for the win! These are the original main VR6 bins I have, they'll show up as the Bosch "16" maps and the like if you ever need any? Nyet's holding Doug's contribution to such tuning, good guide based on the Bosch function sheets - I'm not entirely sure how correct it is in full as I have worked through the original info myself and don't have time to compare but it's a damn good start to learn how to tune! http://nyet.org/cars/info/Translated%20Funktionsrahmen%20Modules%20(10-01-2012).pdf The thing with this is that you need a good solid base knowledge of the ECU and what it does. There should be plenty of info if you can get a hold of VW's SSP's and the like to learn. I am hoping to do a half decent guide when I get chance that starts at the basics and then shows you an overview of the maps.Something I will do for my site and can add here but it's just getting the time to do it So much to do! Here's another brief contribution to give you a rough idea as to some of the variances of the main functions, this doesn't include the sub-functions which if you look at the fourth picture down at the top of this post, can change also (made little marks in red to note the variances). Quick note - brake booster control for FI vehicles not on the VR's, also EGT control on the 20vt ECU for same reason. Quick note - above; you have more maps the ECU references the newer they get as there is more cam control and more emissions controls. You can also see the boost references required for FI vehicles over NA ones e.g. BGPLGU (seems I hadn't finished splitting that one up, must've been 3a.m which is about the time I finish work most days!). One thing I noticed above when comparing/blending them was the way in which later models have less main maps with more sub-functions, i.e. ESNSWL - ES (Einspritzsteuer - or injection control) - on the R32 has the start and warm-up functions integrated into it whereas the older models have seperate map areas. However, when you look at the ECU's you see a hell of a lot more tables, maps etc inside this single area. Above you have signs of more emissions control (tighter and varying emissions legislations), for example here the LANSWL on the R32. Much more adaptive controls the newer the models and ECU's get.Main thing to note for any new to studying these things is the Ladedruck info (German for boost pressure - abbr. LDR - yes you will end being able to speak fluent German engineering terms when you do this lots!). No boost pressure controls on the standard VR's ECU for obvious reasons. Bit of a quick contribution there, I'll try and do a thread that explains things for the layman when I can. Link to post Share on other sites
lukeanderson31 0 Posted May 28, 2014 Report Share Posted May 28, 2014 any guide or indication on how to remove an immobiliser? Link to post Share on other sites
CALICO 130 Posted May 29, 2014 Report Share Posted May 29, 2014 Pay united motorsport to do it. Link to post Share on other sites
Daverse 175 Posted May 29, 2014 Report Share Posted May 29, 2014 As above, i dont think you can do it without a certain code to delete itSent from my GT-I9300 using Tapatalk Link to post Share on other sites
RBPE 198 Posted June 26, 2014 Report Share Posted June 26, 2014 http://nefariousmotorsports.com/forum/index.php?action=printpage;topic=2973.0 c00k 1 Link to post Share on other sites
RBPE 198 Posted October 30, 2014 Report Share Posted October 30, 2014 (edited) 2.9 Turbo Immobilizer on/off switch (some variations can mean different positions but it gives you an idea) Edited October 30, 2014 by RBPE Link to post Share on other sites
Mk3highline 287 Posted January 13, 2015 Report Share Posted January 13, 2015 Hi I'm after some help as you'd seem to know what's what The dilemma I have is I've used 24v aue lump running on 12v obd2 ecu works fine got power etc butI have a cam sensor fault code It is to do with the cam sensor trigger/pick up wheel being different The later post98 12v ecu use the later cam sensor trigger-pick up wheel I'm wondering as there the same hardware if just swapping the chips over, late chip in early ecu could work? Link to post Share on other sites
RBPE 198 Posted January 19, 2015 Report Share Posted January 19, 2015 (edited) Hi I'm after some help as you'd seem to know what's whatThe dilemma I have is I've used 24v aue lump running on 12v obd2 ecu works fine got power etc butI have a cam sensor fault codeIt is to do with the cam sensor trigger/pick up wheel being differentThe later post98 12v ecu use the later cam sensor trigger-pick up wheelI'm wondering as there the same hardware if just swapping the chips over, late chip in early ecu could work? It could be the sensor, it is about that time that VW started changing things for the ME ecu's and parts can be a bt of a mish mash - but the 24v ME7.1.1. ecu has many more cam controls than the 12V Motronic 3.8.1 ecu's, at a guess I would say there are ten times as many cam control functions so there are functions missing which could throw fault codes. Is your ecu a 256 or 258 code - last 3 digits? These are the cam controls on a 96 12v - 256 ecu; I have some 551 Audi 2.7T cam controls I did in English, that is similar to the inlet vvt only ME7.1.1. ecu's to show the differences to above - I'll dig them out and post them up. Edited March 3, 2015 by RBPE Link to post Share on other sites
Mk3highline 287 Posted January 19, 2015 Report Share Posted January 19, 2015 This is my ecu Sinc I've bought this from a sharan vr6I have had it plugged in and car starts but dies due to immobiliser But from what info I can get the sharan used the later type cam trigger wheel Will you have the standard map from a sharan vr6? Link to post Share on other sites
