c00k 435 Posted November 9, 2014 Author Report Share Posted November 9, 2014 (edited) Summer wheels taken off and on stand,Temp mock up using the 2nd spare charger mounted on engine, so I can start looking at making some pipe work. I'd like to do complete alloy piping with just silicone joiners either end. And MFA and temp sensor built in flanges. Edited November 9, 2014 by c00k D11PS, Bealieboy and Surreyvr6 3 Link to post Share on other sites
DanChave 98 Posted November 9, 2014 Report Share Posted November 9, 2014 Cheers bud! I should be getting an air ride setup next year sometime before winter when I completely strip down the cab for colour change and bodywork Link to post Share on other sites
c00k 435 Posted November 17, 2014 Author Report Share Posted November 17, 2014 Early spec Corrado VR6's came with an extra brace on the gearbox.Obsolete from VW. So I bought a 2nd hand one and refurbished it. Almost sanded back to bare metal. Priming, and sanded before colour coat. colour coded to same as car.Then colour coat. D11PS 1 Link to post Share on other sites
c00k 435 Posted November 17, 2014 Author Report Share Posted November 17, 2014 (edited) On the rear of the charger, there is an oil bath, the polished part behind the cog. On the very top of it is a very small breather hole, supercharger is sat in same orientation as it would on the car.There are also 2 small grub screws that sit horizontal in the oil bath.These are to change the oil within the supercharger.Although not in the easiest position to access once on the vehicle, it can be done with a length of small tubing, and a large syringe.Reason NOT to rotate the oil housing to make the grub screw easier to access is.... the breather hole would sit half way down,leaking oil as it's not pointing vertically up. Also this breather hole needs to be kept clear, as it only very small.as I have seen one or two pictures on the internet while doing research, where people have rotated the oil bath. Edited November 17, 2014 by c00k D11PS and VR6Pete 2 Link to post Share on other sites
Therusterman 59 Posted November 17, 2014 Report Share Posted November 17, 2014 Nice work refurbishing the pulleys and tracking down what bearings you need, must have been satisfying! I've looked into getting the gearbox brace before, didn't know it was obsolete. Seems odd it was never fitted to Golf's despite the gearbox having the mounts for it. I've read its supposed to stop the gearbox twisting, will be interested to hear your feedback on whether it makes any difference. D11PS 1 Link to post Share on other sites
c00k 435 Posted November 18, 2014 Author Report Share Posted November 18, 2014 (edited) Cheers buddy, I've found all the bearings, all the bolts, every signal one had been replaced with 12.9 high tensile. Plus I've found the replacemt belt too. I should hopefully notice a huge differance, as I also have a soild front engine mount being made, and I have ordered vibra tech rear engine mount, and gear box mount. So they will all be being fitted same time as the gear box brace. Edited November 18, 2014 by c00k D11PS and michael5556 2 Link to post Share on other sites
Therusterman 59 Posted November 18, 2014 Report Share Posted November 18, 2014 Considering the extra output you'll be getting from the 'charger, the gearbox brace will definitely come to think of it. Link to post Share on other sites
c00k 435 Posted November 24, 2014 Author Report Share Posted November 24, 2014 Painted and Polished a few things.... 1st heat resistant aluminum paint afterwards light sand, more heat resistant paint, repeated for a couple of layers until nice a smooth. Then colour coat, 2K, Colour coded to same as car. The parts that were masked I had already previously polished. I also painted the large pulley at the same time Most of the parts waiting the be re-assembled Test fit. Surreyvr6, Bealieboy, daveyboy and 1 other 4 Link to post Share on other sites
DanChave 98 Posted November 27, 2014 Report Share Posted November 27, 2014 Looking really great man Link to post Share on other sites
c00k 435 Posted December 1, 2014 Author Report Share Posted December 1, 2014 Cheers buddy, it's getting there. Can't wait to drive it with in on there Link to post Share on other sites
c00k 435 Posted December 2, 2014 Author Report Share Posted December 2, 2014 Few new mounts waiting to be fitted.Solid alloy front engine mount, Vibratech gearbox mount.Extra gearbox brace,Solid alloy gear box linkage mounts,Solid alloy camber adjustable front suspension mounts.Still need Vibratech rear engine mount. Link to post Share on other sites
al_mooring 102 Posted December 3, 2014 Report Share Posted December 3, 2014 Solid work dude just read through your build great attention to detail and a stunning car mate! Link to post Share on other sites
c00k 435 Posted December 4, 2014 Author Report Share Posted December 4, 2014 Cheers buddy, It's the little things that makes a car special and stand out from the croud for me.I have a much longer built that it over 40 pages long if anyone does want a read, But you have to be a member on that fourm to view it, it free to sign up. www.So-Wal.co.uk Surreyvr6 and al_mooring 2 Link to post Share on other sites
DanChave 98 Posted December 7, 2014 Report Share Posted December 7, 2014 Nice, those Dibed top mounts? I'm currently running standard rear and gearbox mounts, solid front mount and Dibed top mounts, along with polybushed wishbones and FK Sport Plus coilovers set to the softest dampening setting, I think ill be swapping out the top mounts for OEM ones to see if I like the ride quality better, as it is quite harsh at the moment Link to post Share on other sites
VR6CABBS 1,311 Posted December 7, 2014 Report Share Posted December 7, 2014 Dan.......Where did you get the dibed top mounts from pal? Are they the same on all mk3's including the VR? Sent from my iPad using Tapatalk Link to post Share on other sites
al_mooring 102 Posted December 8, 2014 Report Share Posted December 8, 2014 Nice, those Dibed top mounts? I'm currently running standard rear and gearbox mounts, solid front mount and Dibed top mounts, along with polybushed wishbones and FK Sport Plus coilovers set to the softest dampening setting, I think ill be swapping out the top mounts for OEM ones to see if I like the ride quality better, as it is quite harsh at the moment Dan.......Where did you get the dibed top mounts from pal? Are they the same on all mk3's including the VR? Sent from my iPad using Tapatalk[/quoteI got mine off eBay from a company in Poland if that help guys Link to post Share on other sites
VR6CABBS 1,311 Posted December 8, 2014 Report Share Posted December 8, 2014 Dan.......Where did you get the dibed top mounts from pal? Are they the same on all mk3's including the VR? Sent from my iPad using Tapatalk[/quoteI got mine off eBay from a company in Poland if that help guysHow much were they mate?? Link to post Share on other sites
al_mooring 102 Posted December 8, 2014 Report Share Posted December 8, 2014 Around £120 if I remember correctly maybe a bit less I can't remember but came quick enough etc Link to post Share on other sites
VR6CABBS 1,311 Posted December 8, 2014 Report Share Posted December 8, 2014 Ok. Thanks. Link to post Share on other sites
c00k 435 Posted December 8, 2014 Author Report Share Posted December 8, 2014 I got my dibed top mounts from eBay. Yeah there the same for all mk3's. But they make 2 different type threads for use of different suspension struts. M12 or M14. So you need to measure the thread on the top of your front suspension 1st. al_mooring 1 Link to post Share on other sites
DanChave 98 Posted December 8, 2014 Report Share Posted December 8, 2014 I got them from ebay bud! Think they were around the £100 mark when I got them. Yeah, they are the same for all MK3's Link to post Share on other sites
VR6CABBS 1,311 Posted December 8, 2014 Report Share Posted December 8, 2014 I got my dibed top mounts from eBay. Yeah there the same for all mk3's. But they make 2 different type threads for use of different suspension struts. M12 or M14. So you need to measure the thread on the top of your front suspension 1st.Arrrr right. I emailed these guys and they said a MK3 set fits all MK3's. They have mentioned thead sizes. I guess the top half screws onto your strut then? Link to post Share on other sites
c00k 435 Posted December 9, 2014 Author Report Share Posted December 9, 2014 The shaft needs to sit inside the circular bush, The better the fit, the better the bush will work, It also means they give the right size washer / spacer. And the nuts fit and are right size. So few reasons to measure it. Most coilover shaft are M14. VR6CABBS 1 Link to post Share on other sites
VR6CABBS 1,311 Posted December 9, 2014 Report Share Posted December 9, 2014 The shaft needs to sit inside the circular bush, The better the fit, the better the bush will work, It also means they give the right size washer / spacer. And the nuts fit and are right size. So few reasons to measure it. Most coilover shaft are M14.Have you got any pictures of your fitted pal. I've ordered some today and they say all fitting come in the box with them. Link to post Share on other sites
c00k 435 Posted December 10, 2014 Author Report Share Posted December 10, 2014 Yeah they do come with fittings, Only a spacer for each side, And a nut for each side. I don't have a pic sorry mate, I can try and get one later, but it may be in the dark as I don't get home from work untill about 6.30pm. Link to post Share on other sites
