Golf Mk3 VR6 on Air - Supercharger.
  • 4 weeks later...
  • Replies 255
Popular Posts
Couple of photos from last time it was out to keep build alive.
First photo of my Two VR's together.  Not the best photo, but I had both of them out on weekend, and had to take one     Many more photos of these pair coming when the nicer weathe
I tired to hand paint my rear VR6 badge red, with a small artist brush. I went for hand painting at 1st as I wanted to keep the black outter edge. And didn't want to mask it all up. But it came out s
The paint in the engine bay was letting stuff down, now that I sorted the engine out.... it was the long easter weekend,
So I Started re-painting it on my drive way...
Removed all seam sealer, removed all mounts, welded up few small holes from air box, ABS Wire (i have re-routed ABS Wire), and few other little holes, tried to keep the OE lines without smoothing.
Primer and guide coat waiting to be flatted back...
Started to flatten back...
before the colour coat i covered all my car port with tarpaulin and static dust sheets, wet down the floor, trying to minimize as much dust as possible.
I wore disposable coveralls, some latex gloves and respirator. Removed both inlet and exhaust manifolds, and made sure i had taped and covered everything!
My Heater/ Drying set up, one static heater, and one blowing heater,
Then on to colour coat,
Colour coded, to match my wheels, and air tanks.
I use 2k Paint mixed with rocket, as I was painting out doors, and even with the heaters it wasn't the warmest and best condition out there.
After 2 Coats...
After 4 coats, Before the top coat I 2000 grit sanded the paint...
Top Coat,
I will let the paint cure for a week, then i will flat it back with my buffer, and polish it all up.
Removed all covers and masking taping, starting to put back together
It's not flatted black or polished in the photos, that will be next weekend jobs. Plus finishing getting it back together.
  • 4 weeks later...
Built the front end back up :)
wing, grill and bumper still need painting, as I've replace them with better condition ones than i had before
the bonnet is also getting the washer jet smoothed, as they have been relocated to the scuttle panel. and having a dust over with new paint.
Strut brace mounts will be going red aswell.
I also bought my self a private plate :D
(address photoshopped out)
Had this little beauty CNC'ed
Guess what it is yet?
I'm relocating the air filter to above the gear box, with an MAF and 1.8T temp sensors built in to the inlet pipe :)
120 degree silicon pipe. I could only find 2 companies that made this degree pipe, Samco and Viper Performance.
Samco were out of stock and couldn't get any made for about 4 weeks, so then I found Viper Performance who had them in stock.
It also fits very well flipped the other way, if you want to run it the standard route over the chassis leg. Gives alot more clearance on the turret.
Then it will be linked up to 76mm alloy piping, need to put a 90 degree bend in, then get the MAF flange welded on.
I'm going to weld the MAF flange so it mounted above the gear box, as the other place would be on the other straight of the pipe above the manifold, and this could get heat soak, even thou my manifold is heat wrapped.
There's also a 1.8T temp sensor flange being welded on, but that was simple to make, so didn't need cncing.
And finally I will polish it all up :)
more coming after weekend....
Inlet pipe all welded up..
had to weld a 90 bend into it then weld the MAF flange on underneath.
test fit to car.
P1050073_zpsed528cec.jpg.
Ground back the welds on the visable sides.
Didn't grind them back underneath or on the rear to keep a bit of added strength.
then sanded it all back going up through the grades getting it read for polishing.
P1050076_zps37e27044.jpg .
Finished on 1500grit. Sanded wet from 400 upwards.
P1050081_zpsb1148e4b.jpg .
All Polished up using 3 different grade metal polishing mops, and a heavy and a light cutting compund.
Top side.
P1050088_zps81184cb7.jpg .
Underneath side.
P1050087_zpsa2bfb084.jpg .
Fitted back on car.
P1050101_zps52de7c22.jpg .
Then sorted a few more things, painted wing and bonnet, went back to my old bumper for few weeks until i paint my new one.
and built the rest of front end back up.
After 1st little test run .
P1050122_zps03244859.jpg.
No front splitter, pass side indicator and few other thing not on there. and its still on its winter wheels.
so few tiny things to sort then its all done
yeah it does, I need to weld a mount on it, as it droops down.
Will be done next weekend while tweaking few other things :)
1st idea was to use the clamp that came with air filer,
but after trying that it still drooped slightly on the bend of the pipe.
so i will weld a mount on the pipe and bolt it on near where the 2nd water pump, and large loom plug are located.
Cheers guys, it starting to get there now!
Happy to be driving it again, and hear that VR sound!!
Looking awesome mate! Will it be ready in time for our rolling road day?
Cheers Buddy,
It's going to be ready for Players Goodwood, as I'm in the Show and Shine.
Then loads of shows after that :)
