Everything posted by yakuza racer
VR6 12v Full Vortech V-9F kit
yakuza racer replied to RyanC's topic in Exhaust and Performance parts
Emailed -
mk3 vr6 one to keep an eye on ;)
yakuza racer replied to ibs's topic in Members Rides and Event Photos
looking really nice!!! -
Thanks bud!
Help idk if I'm misfiring
yakuza racer replied to Adam Galusha's topic in Engine Maintenance and Problems
that is strange.... have you done a scan yet? -
POST A SINGLE PIC OF YOUR CAR
yakuza racer replied to mike's topic in Members Rides and Event Photos
My Jetta 5 2L Turbo -
fitted some wheels and done a Straight 63mm Exhaust with two boxes, she sounds good. need to ad a new front spoiler and oil catch tank..and tune her
After the test drive i need to bleed out the brakes and check the alignment but other than that just need to put some km's on the motor and fit the branches and exhaust
3.1L build the mess assembled everything... first time crank and it started up, no knocks, pings or sounds... taking her out tonight for a test drive
thanks man, block is out, just the money problem now lol... going to do new chains, bearings, mains, everything new... bore out with BMW M40 pistons and lighten the flywheel... progress will be slow again
on the way home a lady in a BMW 1 series knocks into the back of me, cracking the rear bumper and just before getting stuck on the N1 when a plastic make shift T exploded, thought the car was on fire lol... what a friday the 13th indeed.. anyhooo fixed the pipe with a metal piece and went to the dyno the saturday 14th, picked up another 9kw, so on the pump fuel map im sitting on 144kw on the fly.. Off to MSA: best time of the day was a 15.002 got crank case ventilation , smoke out the top and zorst on WOT then some rims...... but then sold again now: ok so head off and we s
15.002 best on the day....
pics for clicks: Jetta is betta
14.9 1/4mile - Went to a dyno day straight after MSA at JDMWORX, first car on the rollers 134kw 238nM ATW bought rims... at Wheelworx getting redone 17inch narrow wides BBS RS reps..
VR6 won't start - Possibly head/lifter related?
yakuza racer replied to Das Matt's topic in Engine Maintenance and Problems
what management you running? "low compression in some of the cylinders" - i could guess this is the issue perhaps the rings are collapsed, also those metal fragments could have damaged the bore/pistons/rings/etc... i have gotten motors from Mikes in CPT, fitted and started already but i always strip the motor down before fitting just to make sure everything looks good and replace the important bits which has wear on them. if you have skype hit me up.... -
Can you fine fellows post up your supporting mods with your 1/4mile times, im trying to get a base on my times with mods... ran a 14.9 Headwork 57-63mm exhaust Stand alone management 262 cut cams
if you looking to sell these drop me a PM...
Done another drag event: 185km per hour over 800m after 2 runs... retired as my oil cooler water pipe tore, fixed it but was still 200km's from home so didnt want to chance it. nice day had all round and looking to go a bit faster at the next event.. i didnt strip the car down as many others had done, so that is school fees for me. i ran the same speed as a mk1 vr6, 3.1 with gas, so not bad really, also had a run with a 13.2 sec 16v mk1 and sat a car behind him, so things coming along nicely... next drags is the 4th, i want to go, get a benchmark and then pull the motor again for 3.1, branche
1st run: 15.5 - spun into 3rd gear 2nd run: 15.3 - spun into 3rd gear again 3rd run: 15.1 - dropped the tyre pressure a bit but still way too much spinning... little mk1 left me on the line 4th run 14.9 - dropped pressure to 1.5 bar but was still spinning my arse off....but didn't launch properly at the time wanted to go for a 5th run as i was really getting used to the car but the drags was over... Going for official drags saturday, car can go MUCH faster, i must just get used to it again...
exciting times ahead of us, Liverpool 10 in row, City lossing, Chelsea coming through, seems like the last few games is going to be a nail biting one!! www.betloud.com for some wagering fun... let me know which pool you join and i will join up.
Tuning: Jody Van Schoor Company: JVS Tuning Friday- Jody calls tell me my car spat out a welsh plug while he was loading the car on the dyno at 5000rpm.. off i go and we correct it. Saturday- Temperature - 37 degrees, 32 degrees inside Head on off to the dyno, start the car and let the fans pop on, everything looks good, half way through the first base run water comes shooting out of the water bottle, air lock, so we drain and make sure its 100's again. A load dyno is no fokken joke... if anything had to break it would have exploded on the dyno, so i can feel feathers hitting limited who
Looking at this season and it seems that the EPL is jam packed with excitement... Liverpool cutting it close but City in with a chance! who do you think is going to take it? ps- im a gunner and well pathetic display by them against everton
took her for her first drive last night.... dyno booked for thursday... tuning her on 102 Av fuel...
