Everything posted by gavinvr6
I can get my fans to kick in if I remove the plugs from the control module and jump the large red to each of the two to the right. 1 at a time checking both speeds. can also get the aux run on pump to kick in. yet they won't kick in if I bypass the temp sender unit. Also not kicking in if I let the car run up to temp. getting desperate as im slowly cooking my poor engine. but my fault code reader (cheap genden one) isnt finding anything wrong. ive checked and replaced all fuses. cleaned all contacts inside the plug and tried 2 different modules.
The yard/depot manager showed me the mot receipt u get nowadays and it has no advisories in the box on the right. This is from a reputable business who we have been using for years.
My main concern is I was told bottom ball joint were gone, mechanics words were f***ing hanging out, speed bump equals seperation. Also beleived other suspension components needed attention as did engine mounts. But the mechanics who did the work just replaced bottom ball joints and left the rest. This is a company vehical so the first fitter would have no reason to lie about bits failing, where as the others who done the works are known to be lazy w***ers. I been moaning the header tank is leaking for 3 months and they have seen it themselves, Not even convinced it actually went for an mot an
Its not dull thud from worn rubber its to harsh for that. Apparently its just past an mot. But I'm not entirely convinced its road worthy.
Couple of questions. Would like to know if they would come up/show up in an mot and if they would be a fail or advisory. Vehical is a 3.5t ldv van coolant tank-visible obvious leak Knocking on suspension, bottom ball joints replaced, still doing it just slightly less. Knocking noise under initial load (gear stick jerking at same time) Vibration on brakes when slowing from motorway speed, front brakes replaced.
how long before this gets me pulled?
gavinvr6 replied to gavinvr6's topic in Members Rides and Event Photos
Nah didnt half inch it, some nice 'do as ya likey' tried to steal the 4000 gallon fuel bunker from the works depot, and mr plod left about 30 mtrs of it wrapped round the fuel bunker when they finished thier 'investigations' -
My sentiments exactly -
been quite lucky so far. been past a few, couple of odd looks and double takes but no stops yet. been round town, went to croydon and drove round there and back home again. just hope i dont get a miserable one today -
Don look at the splitter Daverse, wasn't planning to fella, just hope I don't get a miserable sod. -
http://s23.photobucket.com/albums/b394/my1stgolf/?action=view¤t=Havant-20120404-00209.jpg cant get image link to work grrrrrrr
right i replaced coil pack, leads and plugs. took it on a 2 mile round trip of surface streets and a bit of a dual carriageway blast and not a hint of miss fire paul i pm'd you the vag 6 digit codes to look at when u get a chance..... cheers
Anyone tell me what the faults listed are for? I believe low voltage terminal 30 is something to do with the MAF. But the other 2 are a mystery to me.
thats what i thought, the old gal is due a service anyway so i'm going to swap coil pack plugs and leads when i do the oil change. but knowing my luck it will still crap out hence listing the faults found. hoping it might pin point something before i go spending a fortune i dont need to.
forgot to say car is a 1996, obd2.
hey guys i need some help on my way down the a3 last night my car developed a miss fire. then sorted itself out then miss fired again. i ended up having to limp it home for about 70 miles. with it keep doing it. i put it on a generic fault code reader and got the following 3 faults voltage terminal 30 positioning m. for centre outlets v102 mixture adaption can anyone tell me what these mean please i really need my car working
oh yeah i got that bit but my prob is where the tb pipe come of the matrix pipe its split where the pip enlarges. what i wqnt to do is just chop it out and fit a bit of pipe in its place removing the tb pipe completely. but concerned about the left over tb to header pipe. can this just be plugged up or is it possible to just cut the header top hose at the tb return. is it long enough?
is a bit of copper or steel tube ok for the matrix pipe and just plug up the one from the header?
is it safe to chop and re-jig the pipe work to delete the tb heater pipes. im only asking as my matrix to tb water pipe has split at the big bit in the middle and i need to use the car.
yup is factory conlog lol. everything bar the sounder is working.
guys i got a bit of a pickle going on, my stupid conlog alarm dont make any noise, aint done since i bought it. i've tried popping the fob in the secret socket, lol, and randomly pressing he button and turning on and off the ignition but nothing at all has changd. does anyone know the button sequences for this?
a lot of people are complaining when they never even watched the show. simply because they heard about what he said. i say grow up it was a joke, slightly of the bad taste variety but thats his sense of humour and i think he is bloody hilarious. i've probably seen every top gear hundreds of times. i always read him column in the sun, yes im a commoner, and i have almost every book he has written. YET NOT ONCE HAVE I FOUND ANY THING HE SAID OFFENSIVE.
high speed vibration
gavinvr6 replied to gavinvr6's topic in Wheels, Brakes, Suspension and Steering
okie dokie i give it a try. thinking about it though my company had some fit and balance my front tyres on the van and that was 150g over weight and 1/3 of the way round the wheel away from the balance point lol -
vody all day long. so long as its a nice ice chilled bottle of stolly straight up
thats what i thought but the guy i got it from had just had new rears put on it at a reputable varahe -
y o y would u do that? ive seen someone do it a jeep wrangler but thats a brand new merc
