i seem to be having this problem too it looks like the google ads arnt loading and pressing the back button makes the ad go back not the web page then the page will go back with a second click of the back button
had a sebring cat back system on my vr for about 8 years with no problems at all and it still looks in good condition and will last for a lot more sound good, not loud when just driving but roars when giving it some
the Kona Dawg Supreme is a much better bike has better components and a good buy at £300 as it would have been over 2k when new the kikapu is a entre level bike with bottom of the range componets if you dont have the supreme PM me and i will have it
http://www.direct.gov.uk/en/Motoring/BuyingAndSellingAVehicle/RegisteringAVehicle/DG_10014199 sound if you use most of the vr bits on to the replacement shell you will be ok would be worth speaking to them befor to be sure
wrapping the standard manifold can crack the cast iron with the extra heat that would be held in it the standard down pipe would rust faster from the moisture thats generated when the pipe heats and cools
remember this when it was on tv he had sped away when he was spotted by police the dumped the car and tried to run. it was on quite a bit ago so (more then 5 years?) so the VR would have be worth a fair bit.
the stud diameter is 112 where the vr is 100 you could use adaptors but the will be 20mm bringing the offset to 10 making them stick out to far depending on the center of the wheel you might be able to redrill them to 100pcd but could affect the strength of the wheel but would go straight on
