C2Motorsports 0 Posted February 17, 2006 Author Report Share Posted February 17, 2006 C2Motorsports would be willing to undertake a DIRECT from C2 sales event. I will list below both SC and Turbo SystemsSuperCharger Stage-I: est. 280 hp Fully Equipped with: Vortech SC Head Unit -V1 standard-V2 upgrade +$100usdSatin finish standard -Polished available +$100usdSerpentine belt C2Motorsports SC Brackets -CNC machined -T-6061 aluminum -Anodized: blackC2Motorsports Billet SC pulley -CNC machined -Anodized C2Motorsports Dual Idler -CNC machined bracket -Dual idler pullies -Eliminates slipping with 120° of belt-wrap C2Motorsports Billet 95mm MAF Housing -OEM sensor drops right in C2Motorsports Custom EPROM -Plug n play compatibility for ECU C2Motorsports Cold Air Intake -Pulls cool air from outside engine compartment -K+N open-element filter -Appropriate tube fittings for recirculation Bosch Diverter Valve -Recirculation plumbing included (6) 30# High-Impedance Injectors (6) Performance Spark plugs Intake Plumbing -Mandrel bent -SC to throttle body OEM VW VR6 oil pan -Direct replacement -w/-AN8 welded fitting Oil Feed/Return Lines -Stainless steel braided -Teflon hose interior -AN swivel fittings Silicone Couplers -Complete set of silicone couplers -4-ply aramid reinforced SS Connectors -T-bolt design -Highest quality Charcoal Canister Relocation Kit Bolt Kit -All necessary bolts for installation -All necessary washers and lock washers Misc -Teflon tape -Full instructions -Technical support -Installation available Retail: - $3999.00 USDStage II Includes EVERYTHING from Stage I with these additional items:2.50" C2 Billet PulleyLarger injectorsLarger injector EPROM programmingC2 SS 9:1 Head Spacer -lowered CRRetail: - $4399.00 USDVR6 TURBOStage 1MKII/III VR6 Turbo Kit: The Stage1 VR6 Turbo Kit is sure to satisfy the need for speed in just about any driver. This kit is specifically designed for the OBD1 and OBD 2 Coil Pack ignition system. We have dyno’d this kit at 245WHP on a stock motor with 94 octane fuel and a 3" cat-back exhaust (no cat). - T3/T4 Oil Cooled Turbocharger (500hp Capable) - Kinetic Motorsport VR6 Manifold - TiAL 38mm Wastegate - 2.5" Stainless Steel Down pipe - 3" Stainless Steel Intake - Braided Oil Lines and Oil Pan with fittings - Re-useable Air Filter - Kinetic Motorsport Silicone Hoses and Stainless Steel Clamps - Injectors - C2Motorsports Chip Software - This kit runs 6psi of boost ODB1 95 - $2650.00 USDODB2 96-99.5 - $2650.00 USDStage 2MKIII VR6 Turbo Kit: This kit includes the complete Stage 1 Turbo kit with the addition of a Front Mount Intercooler Kit. The FMIC kit features a Spearco aluminum intercooler core, stainless steel tubing, 4-ply silicone couplers and stainless steel band clamps. With a 3" cat-back exhaust (no cat), 94 octane fuel and 8.5 - 9 lbs of boost you should see close to 300 whp. Full Kit (ODB1) - $3650.00 USD Full Kit (ODB2) - $3650.00 USD****Shipping to be additional********GB pricing depends on participation********We can also provide performance clutches**** Link to post Share on other sites
Petesvw 0 Posted February 17, 2006 Report Share Posted February 17, 2006 Thank you C2 : ) Link to post Share on other sites
VR6Pete 1,455 Posted February 18, 2006 Report Share Posted February 18, 2006 Very Interesting..... Link to post Share on other sites
jaysVR6 2 Posted February 19, 2006 Report Share Posted February 19, 2006 God my eyes hurt after reading all that!!All I can say is: 'The cheap route isn't usually the best!!!'Lesson 1: Buy a secondhand Charger and fit it yourselforLesson 2: Go straight to a reputable tuner and throw loads of money at them!! (if you have it!!)End of todays class! Link to post Share on other sites
VR6Rich 3 Posted February 19, 2006 Report Share Posted February 19, 2006 On the turbo kit is the Kinetic Motorsport VR6 Manifold designed for RHD cars? I.e. will it foul on the master cylinder? Link to post Share on other sites
C2Motorsports 0 Posted February 20, 2006 Author Report Share Posted February 20, 2006 On the turbo kit is the Kinetic Motorsport VR6 Manifold designed for RHD cars? I.e. will it foul on the master cylinder?We have one that is designed for the RHD car...and in fact we have an RHD car here for final fitment.chrisC2 Link to post Share on other sites
tinny22 11 Posted February 20, 2006 Report Share Posted February 20, 2006 can you send any picstinny22 Link to post Share on other sites
Eat this 2 Posted February 20, 2006 Report Share Posted February 20, 2006 On the turbo kit is the Kinetic Motorsport VR6 Manifold designed for RHD cars? I.e. will it foul on the master cylinder?We have one that is designed for the RHD car...and in fact we have an RHD car here for final fitment.chrisC2details???? Link to post Share on other sites
rs1800gr4 0 Posted February 21, 2006 Report Share Posted February 21, 2006 How much for the turbo kit delivered in Greece?Does the intercooler fit in the front bumper if the car is equipped with a/c.Any photos would be much appreciated. Link to post Share on other sites
mk3anni 0 Posted February 21, 2006 Report Share Posted February 21, 2006 On the turbo kit is the Kinetic Motorsport VR6 Manifold designed for RHD cars? I.e. will it foul on the master cylinder?We have one that is designed for the RHD car...and in fact we have an RHD car here for final fitment.chrisC2details????At a Guess John, I'd suspect its a Manifold designed to allow you to fit a turbo to a RHD car.It will fit to the head by means of a stud and nut combination, and will channel the exhaust gases down to a flange(great word!!!!) to which a turbo can be attached.It will probably be cast from some kind of metal, as wood and cardboard don't withstand engine temperatures too well. Link to post Share on other sites
mk3anni 0 Posted February 21, 2006 Report Share Posted February 21, 2006 Once the manifolds are ready, I'll deff have a stage 2 turbo kit!!Ta!!! Link to post Share on other sites
dubloke 4 Posted February 21, 2006 Report Share Posted February 21, 2006 is that to remove all the waste gases away from your oratory orifice steve, or are we still talking about the cars, lol! Link to post Share on other sites
mk3anni 0 Posted February 21, 2006 Report Share Posted February 21, 2006 is that to remove all the waste gases away from your oratory orifice steve' date=' or are we still talking about the cars, lol![/quote']Hmmmmmmmmmmmmmmmmm Link to post Share on other sites
dusty_mauve 0 Posted February 22, 2006 Report Share Posted February 22, 2006 Well, that's taken me nearly an hour and a half to read and digest!Interesting reading for sure!What I came round to thinking is that an hour and a half is about half the time it would take me to drive from London to Derby to get my money back. If there are still people waiting for refunds I can't believe you've not been up there asking for your cash in preson. After all most of us drive that far every other weekend during summer to stand in a field or on a disused runway and show our cars, let alone when there's nearly £2k at stake in most cases!!Hope everyone gets sorted out soon! Link to post Share on other sites
rs1800gr4 0 Posted February 22, 2006 Report Share Posted February 22, 2006 It's a bit difficult when you live in Greece. Link to post Share on other sites
purple highline monster 0 Posted February 24, 2006 Report Share Posted February 24, 2006 when i get there' date='i will let you know,and invite you to come,just to see.in my country-village we do f*ck thieves and liars all the same way......i really dont want to say more words,and i dont know why uk guys who are owned from that guy dont do nothing,but i only can f*ck him when i get therechris[/quote']sounds like Rob better Grease himself up then Link to post Share on other sites
vr1 0 Posted February 24, 2006 Report Share Posted February 24, 2006 "sounds like Rob better Grease himself up then" !dodge sounds like robert better get he's backside in gear!!!!!!! !amazed Link to post Share on other sites
antera309 3 Posted February 25, 2006 Report Share Posted February 25, 2006 Chris, It's worth you starting a new thread about the turbo kits, I'm sure there will be plenty of interest. Link to post Share on other sites
mk3anni 0 Posted February 28, 2006 Report Share Posted February 28, 2006 On the turbo kit is the Kinetic Motorsport VR6 Manifold designed for RHD cars? I.e. will it foul on the master cylinder?We have one that is designed for the RHD car...and in fact we have an RHD car here for final fitment.chrisC2Any news on this??? Link to post Share on other sites
Eat this 2 Posted February 28, 2006 Report Share Posted February 28, 2006 On the turbo kit is the Kinetic Motorsport VR6 Manifold designed for RHD cars? I.e. will it foul on the master cylinder?We have one that is designed for the RHD car...and in fact we have an RHD car here for final fitment.chrisC2details????At a Guess John' date=' I'd suspect its a Manifold designed to allow you to fit a turbo to a RHD car.It will fit to the head by means of a stud and nut combination, and will channel the exhaust gases down to a flange(great word!!!!) to which a turbo can be attached.It will probably be cast from some kind of metal, as wood and cardboard don't withstand engine temperatures too well.[/quote']sarky as always you know full well i meant the kit ya tit ~ Link to post Share on other sites
Dubsingh 0 Posted February 28, 2006 Report Share Posted February 28, 2006 lol you lot honestly why? i swear this thread gonna be the curse of this site....any one got their money back? Link to post Share on other sites
vr1 0 Posted February 28, 2006 Report Share Posted February 28, 2006 has he been 'f'd yet!!! Link to post Share on other sites
mk3anni 0 Posted February 28, 2006 Report Share Posted February 28, 2006 lol you lot honestly why?I can never bring myself to miss a good oppertunity........!! Link to post Share on other sites
chris 20vt 0 Posted March 10, 2006 Report Share Posted March 10, 2006 i havent been in for quite a long time,but after a chat i had today with vr6greece,he ia actually going to uk,with 7 friends of his,just for this reason.unfortunately i cant made it to go with him,but i am so SURE,thatit doesnt matter who is there of us,me or vr6greece,its the same.he is coming there on june,i have been emailing this as*hole every single day,to give us our money back,but no respond.on may,its been a year since this THIEF,stole our money from us.we have been no more than pacient,unable to do nothing more than wait,or enable our hopes to you guys,uk i mean.it doesnt matter if no one from uk couldnt help us greeks get our money back,but we cant do no more than thank you all for the support and iformayion you had-have-will provide us.but time for pay back is REALLY COMING......robert thief,if you read this post,prepare your shelf thief,cause we are finally coming for you.no more words or begging for OUR stolen money.just acts.we have trusted you so much money,not even knowing how you look like(we do now,actually,even what underwear you are wearing now)and you stole from us like stealing an ice cream from a kid.GOD,is is fair,let's thieves steal,but is punishing in the end people LIKE YOU--->THIEVES.before anything else though we are coming for you.PREPARE YOURSHELF TO.............thats for robert isaac.as far as you all uk and no mates,from the deapth of my heart,and vr6greece'swe thank you fro everything.if you ever get stolen from someone in greece,or ever get in the need of something from greece,dont hesitate to ask us,we will be there for you brothers............thanksChris BadisGREECE Link to post Share on other sites
mk3anni 0 Posted March 10, 2006 Report Share Posted March 10, 2006 i havent been in for quite a long time' date='but after a chat i had today with vr6greece,he ia actually going to uk,with 7 friends of his,just for this reason.unfortunately i cant made it to go with him,but i am so SURE,thatit doesnt matter who is there of us,me or vr6greece,its the same.he is coming there on june,i have been emailing this as*hole every single day,to give us our money back,but no respond.on may,its been a year since this THIEF,stole our money from us.we have been no more than pacient,unable to do nothing more than wait,or enable our hopes to you guys,uk i mean.it doesnt matter if no one from uk couldnt help us greeks get our money back,but we cant do no more than thank you all for the support and iformayion you had-have-will provide us.but time for pay back is REALLY COMING......robert thief,if you read this post,prepare your shelf thief,cause we are finally coming for you.no more words or begging for OUR stolen money.just acts.we have trusted you so much money,not even knowing how you look like(we do now,actually,even what underwear you are wearing now)and you stole from us like stealing an ice cream from a kid.GOD,is is fair,let's thieves steal,but is punishing in the end people LIKE YOU--->THIEVES.before anything else though we are coming for you.PREPARE YOURSHELF TO.............thats for robert isaac.as far as you all uk and no mates,from the deapth of my heart,and vr6greece'swe thank you fro everything.if you ever get stolen from someone in greece,or ever get in the need of something from greece,dont hesitate to ask us,we will be there for you brothers............thanksChris BadisGREECE[/quote']I put this into bablefish but it didn't understand it either. Why are you interested in his underwear???? Link to post Share on other sites
