Golf VR6 Track Car Project
Thought I would post my project on here as I have just signed up for premium membership.
Hopefully it may be of interest to others on here.
I started it back in Oct 2007.
I'm copying from the thread I have on another forum.
Well after trying a few other cars and spending a fortune on them a_whistle.gif
Steph and I had a discussion about doing a shared car for track use, mainly at the Ring.
Steph had a Mark 3 Golf VR6 3 door as a base car sitting in his garage doing nothing.
The discussions became a reality and a few weeks ago I went down to start the project.
It needed some work doing before it could go on track though.
Our aim was to have it ready for its first shake down testing at Cadwell for 10th November.
We had bought a roll cage off ebay for a reasonable price which was sat in the back waiting to be fitted.
The Steering lock would have to be replaced aswell as the ECU due to previous issues.
We decided to do a full overhaul of the key areas a matter of course.
Brake Discs all round
EBC Yellow stuff Pads all round
New Braided Hoses
New Adjustable Shocks
New Wheel Bearings all round
New track rod ends
New lower ball joints
New ARB drop links
New Top Mounts
Replace ignition barrel
Fully Strip Interior
Fit Roll Cage
Refit new head gasket after having the head skimmed
Fit Oil cooler
There are other jobs to get done but we wanted to crack on and get as much done over the two weekends I had to go and visit Steph...
Brakes
Removed all the old discs, pads and rubber lines.
Suspension
Off with the old and strip the bits we needed.
We had got new shocks and springs front and rear.
I made up the new units and fitted the rears first.
Did the same for the fonts.
We initially got some G60 front top mounts but swapped for the VR6 ones as they didn't fit.
We also put the old springs back on as we think the new ones are for a GTi.
lots more to come...
Ian
  • Replies 58
OK, just a bit more...
Steering [/b ]
As precaution we changed the parts as listed in the first post.
This was another of my jobs while Steph rebuild the engine.
In the process of stripping it down we found a split inner drive shaft boot angry.gif
This meant removing the drive shaft from the gearbox, how difficult could that be blink.gif
Well actual its a PITA!!
The six bolts holding it on are very difficult to get to unless you have an access pit / ramps.
After playing around under the car for ages we worked as a team with a very long bar and removed them. Me underneath and Steph by the wheel arch with the long bar ratchet.
Once repaired, the shaft was refitted, alot easier than taking it off wink.gif
Steph had done all the wheel bearings using his very impressive home jig.
Next was to replace the ball joints, track rod ends and ARB links which were all fairly straight forward.
Everything was put back together ready for alignment setting soon.
Engine
We are leaving the engine standard at the moment.
Apparently getting cams, port&polish, inlet manifold and exhaust manifold cost alot ohmy.gif
To be on the safe side Steph replaced the headgasket after having the head skimmed.
After playing with cam chain for a bit the engine was put back together.
With everything connected and all fluids topped up the car was started for the first time smile011.gif
Interior
Next job was to strip the guts out to save weight and give us room to get the roll cage in.
We weren't going to go crazy and remove everything just the obvious just.
Starting with all the seats (fronts going back in till we get some buckets) I then moved onto the interior panels and carpets.
We then tried a test fit of the cage.
More stuff had to come out to get it fit so the roof lining came out and the lower front plastic panels.
But still the cage was catching so out came all the seat belt mechanism.
Nope, still not quite there as the sunroof was catching. (thoughts of Gary and an angle grinder came to mind biggrin.gif )
Once the cage was in place we looked and thought we should be able to get it back in with some modification... involving a hack saw a_whistle.gif
We removed the blind and the rear sliding runners. We are not going to open it so the motor/switches was removed.
After a bit of correction we managed to refit the sunroof blink.gif a huge sigh of relief was heard all over Hampshire biggrin.gif
So the cage is in ready to be welded / bolted.
The front seats have been put back in as said earlier till we get some buckets.
Its surprising how much stuff comes out!
A couple of little jobs needed to be done to tidy things up a little.
New exterior door handles were replace as one side had been damaged.
The ignition barrel was also replaced which turned out to be a real nightmare to remove.
This involved using an extractor tool an adjustable spanner and two pairs of hands angry.gif eventually it came free and replacement put in.
R888's are now ordered for delivery Friday (Thanks to Jude for waiting in for them while I go to work all day).
Set of 15inch Audi A3 alloys waiting in the garage that Steph gave me to bring home on Sunday ready for them to go on.
Harnesses also arrived today at Stephs ready to be fitted.
[October 2007]
To help other members I will start to try and put some costings together for this project.
Some of the parts have come through Steph so may be different for others to get but it will at least give an idea to people starting out on a DRT thumb.gif
All prices quoted are approximates.
* Car - £800
* Cage - £300
* R888 tyres - £235
* Audi Gauges - £41
* EBC Pads - £60
* Discs - £60
Engine
VR6 Headset 60
Chain set 35
Head bolts 30
Skimmed Head 60
ECU 60
Hoses (Oil Cooler) 20
Sandwich Plate 45
Oil Cooler 40
Alt Belt 22
Seal 5
Oil 40
Exhaust 77
Suspension & Steering
Dampeners 200
Springs 90
Top Mounts 48
Tie Rods 26
ARB Tie Rods 28
Lower Ball 31
Front Bearings 32
Rear Bearings 18
Brakes
Braided Hoses 67
Front Disks 40
Rear Disks 40
Front Pads 40
Rear Pads 40
Chassis
Roll cage 300
Extinguisher 15
Roll cage Padding 22
Harnesses 70
Eye Bolts 10
Steering Wheel & Extras 65
Seats ?
Gauges 41
Wheels & Tyres
R888 235
Wheels 65
Other
Car 800 Market Value
Car Tax 100
MOT 50
Insurance 450
Door Handles 30
Halfords, Electrics, Tape,Seal,Bolts, 22
We've been very lucky to get a few bargins.
More to come still.....
Oct 2007 cont.
From Steph -->
in between work breaks I managed to get a wee bit done on the car.
First off was to finish off the roll cage mounting plates by pre drilling them, I have a lovely little bench drill that made the job very easy.
I have a nice lubrication mix that protects my bits tongue.gif steering fluid and water in a spray bottle, stops the drill bit from getting to hot and sticking
My plates all neatly done.
After 20 minutes of tidying the workshop I got the mig out and set it up for welding and then I rolled it to the garage.
I remembered the hole we found in the floor from the corroded floor plug. so i thought i'd best start on that, I stripped the hole back to good metal, the 8cm hole got at least twice as big.
The fuel lines had to be moved and tied to prevent any chance of a nasty occurrence , I also wrapped them in damp cloths for additional protection.
Next up I made a stencil out of card and cut a bit of sheet metal to the size and shape needed then I welded it up.
It then got a nice coat of thick underseal to protect it from the same fate.
Next up decided to start on the foot plates, thought i would do one to start with.
Got the front ones measured and drilled, then marked them out before removing the front of the cage. Out came the grinder for the tar and paint removal and then I bolted down the plates and welded them up.
and a coat of hammerite for good measure
With both the front ones done, I should of stopped here to get more work done in the house but i decided to carry on and do the 2 rear plates as well.
Pretty much the same technique as the front,
Measure,
Mark,
then measure again
then drill,
get the grinder out and clean the surface down to bare metal,
bolt down the plate
then weld it up.
Both the back ones are finished and coated with hammerite as well.
just the middle to do now, I think I'll give Ian a go, failing that the rest of the car needs undersealing tongue.gif
The start of today, wheeled the mig and the car out the garage, I had to shoe horn it in yesterday when I had finished,the garage is rather full at the mo so space is tight.
I then had to fit the cage into place so I could mount and drill the centre plates. The cage was a bugger to get back into place as we bolted the adapted sunroof backin, brute force and ignorance were required.
Anyway got it back in and bolted up back and front, center place put in the the whole cage bolted up tight.
End of the day pic, the cage is in really solid, I gave the cage a good old shake and it is very solid no creaks and nil movement, proper job.
just a couple of cover plates to put on but other than the the cage is done biggrin.gif
Ian is defo on the underseal now and changing a dodgy drive shaft
Back to me --> 25th Oct 2007
Update on the Wheels.
These are the Audi A3 alloys we are using to start with...
Borrowed a friends car for the trip to local Kwik Fit, where I payed £40 for the swap over, valved and balancing of the wheels...
Off came the old tyres...
On with the new Toyos...
Working hard!
ABS is hopefully sorted, pipes all running clear so hoping that'll be it.
Fitted the harness bar, Had to cut and shape the tube with a grinder which was rather testing and difficult to get the angle and curve right, subsequently this resulted in the welds having to be really thick to fill the gaps at the ends. wink.gif
The 888's are staying off the car until cadwell,
New Steering Fitted
The next thing was to have a look at the suspension as we were looking to change a few things as it didn't sit right. After checking we realised the bearing on the top of the strut was in the wrong place. I had put it in the wrong place (under the guidance of steph a_whistle.gif) Quick change and all was ok.
As Steph stated earlier the hub nut wouldn't tighten so off came the OSF drive shaft again to replace the end and back on again. I'm getting quite good at this now biggrin.gif Much easier with 2 people doing though. This time job done and the hub nut tightened up.
Had to get the brake system filled and bled accordingly following all the work on them.
This proved to be a bit of a pain and took longer than expected.
As we topped the system up we found no fluid coming through to the rear calipers angry.gif
This lead to a fault finding exercise which eventually we traced to a blockage in the ABS unit in the engine bay. After alot of effort we eventually got it cleared without having to take it apart thumb.gif
No Photos sorry as all the jobs were quite messy and didn't want to get the camera covered. No gloves left! ( PLEASE NO more Gay comments biggrin.gif )
While all this was going on Jim.C and Gary Kinghorn turned up to take the piss wave2.gif
Talked cars, drank tea, ate the bacon sarnie then GK had to get off to watch some team play something. Good to see them both, and thanks for the FREE stickers Gary a_whistle.gif
When they had gone we finished the brakes.
Next up was to fit the oil cooler.
First a location was chosen to make the most of it.
Fitting was fairly straight forward.
Update:
New Steering Fitted
user posted image
Running the pipes and connecting it was a little harder but we got there in the end.
Checked for leaks but seems ok at the moment (fingers crossed).
As time was getting on we flushed the water system a couple of times before filling up with a little bit antifreeze for the winter. (replaced by water for the Ring)
Everything was put back on, tightened, checked and we transported it to a small
private road that we had access to, to test the car where steph lives.
Steph drove it first and came back reporting there was a slight misfire and it pulled to the left sad.gif
I finally got to drive the car, albeit for a short distance but it felt great thumb.gif
I think its misfiring on 2 cylinders on low revs but goes away higher up the band. As for the brakes, it locked the left front wheel with mild braking.
Even with these slight issues I was more than happy with the car and can't wait for Cadwell now biggrin.gif
Next morning I was awoken with a cup of tea and some toast (slept in the lounge), and the realisation it was 8am on the old time - thats 7am new time Steph, I'm not in the bloody Army you know nono.gif
First job was to look at the brakes again. This time, as it was raining, Steph sat in the car with the engine running, for the servo assist, and I went round each wheel in turn to bled the brakes. After doing this the ABS light went out ohmy.gif biggrin.gif
Hopefully cured the problem, but didn't get chance to check so will have to wait and see.
Next job was to get a harness bar put in and the harnesses for the MOT.
Steph had some cage pipe which e measured up and cut to length a_whistle.gif
A bit of fine tuning....
Test fitting....
Then welding into place....
Finished the bars off and fitted the harnesses.
Need to move 2 of the eye bolts a_whistle.gif put some new plugs in and test the brakes but apart from that the car is ready for the MOT thumb.gif
Decided to remove the passenger airbag as it weighs a good couple of kilos and we have a cage and helmets a_whistle.gif laugh.gif
Steph joked about setting it off for a laugh.... wrong comment to make to a pyromaniac wave2.gif
So a couple of bits of wire later and a small battery and well this icon gives you a good idea.... mad0233.gif
One very loud bang later and ....
I really would not want one of these to go off in front of me, the explosion was very fierce but as long as you are sat correctly (one of my bug bears with people sitting too close behind the steering wheel) it is a preferable to smashing into a dash board ohmy.gif
Went looking for the steering wheel airbag but couldn't find it and we had some more work to do...
It was great fun setting it off and alot cheaper than some fireworks this time a year laugh.gif
New plugs in 23 quid frim the local factor.
Took the car for a spin to check it out and the miss fire is now cured ,
The car has now stopped pulling to the left, but they do lseam to lock on heavy braking so I'll have to look at that.
The brakes do work so that wont stop it from getting moted
Nov 2007
Update 1
Steph spent a few hours getting the car ready for the MOT yesterday.
He sorted out the Harnesses (buckle type) so they were fully attached and secured you around the middle rather than on you hip biggrin.gif thumb.gif
He then went to work on the brakes as they locked on the fronts with no ABS cutting in angry.gif
After going over the whole system checking everything he eventually found out what was wrong...... a_whistle.gif
When we, and by we... I mean me wave2.gif put the new rear discs on, I didn't put the ABS ring on the new discs from the old ones. ( What can I say, rookie error, plus I didn't realise I had to loser.gif laugh.gif )
After visiting a couple of motor factors and a VW garage to no avail he stripped the ones off his Toledo, fitted them to the Golf and guess what.... the brakes worked fine and the ABS cuts in thumb.gif
Nov 2nd 2007
Breaking NEWS!!!!!!
From Steph -->
I gave it a wash and a hover prior to going for the MOT, I then swapped the tyres over as one of the road wheels had a bulge on the tyre wall.
The Test: a couple of points but nothing really so Yes it's passed and now taxed, ive just been up and down the A343 from Andover to Newbury then onto the bypass to give it a good road test thumb.gif thumb.gif thumb.gif
The result, the 20 quid of tescos 99 has gone and I have a large smile on my face.
Nov 4th 2007
Some more small jobs done today
First off was to dispose of the large box filter and cleanout the space it left, it was manky.
I then got some cardboard and made some stencils for the heat shield.
Thankfully I had made a visit to the metal shop before leaving my last job so I had some great sheet ally to use in the workshop.
After cutting the sheet to size and shaping it I slotted it into place. I got the hole cutters out next and cut out the space for the pipe to do through, so now the compartment is pretty much sealed when the bonnet is closed.
Now attached into place.
the air feed was pretty simple to install, I had to reshape a bracket for access for the pipe but other than that job done.
to finish off I sealed it all in with some gaffa tape a_whistle.gif , does the job well.
after finishing that, I got a spare set of wheels sorted out and fitted the roll cage padding.
Job done
Nov 14th 2007
Update: Cadwell Park
First shake down testing of the VR6.
We had a couple of issues, which both turned out to be minor.
The first one was a blown coolant hose, which at first we both thought was a blown head gasket ohmy.gif
Within 30mins or so Steph found the split, cut the offending piece off and rejoined the pipe.
Decided that we will be getting some new hoses all round to prevent it happening again.
The second issue was an ARB drop link that sheered. We did a temporary fix but it was at the end of the day so decided not to go back out on track as Steph had to drive the car home. I believe JimC had some nice ones on the Mazda which would be good...
On the positive side the car ran well all day.
We had no braking issues either in the damp with the ABS a_whistle.gif or later on a drying line.
The car handled well especially when we out the R888's on after lunch - OH My God they are fantastic compared to Normal Road tyres blink.gif Never using normal tyres again biggrin.gif
I rigged the Bullet Camera up in the afternoon and got some videos of both of us driving. (Not done much with it as purely wanted to get some hosted.)
Ian Driving: http://www.streetfire.net/video/Ian-driving-the-VR6-at-1_141032.htm
Steph Driving:http://www.streetfire.net/video/Steph-at-Cadwell-in-VR6_140953.htm
GVK quote after: "BTW, the mk3 pops out flames on the gearchanges biggrin.gif"
QUOTE (IanHowell @ Nov 14 2007, 09:49 PM)
OH My God the R888's are fantastic compared to Normal Road tyres
QUOTE (Nige @ Nov 15 2007, 01:47 PM)
I told you once you`d tried the 888`s you`d never go back. I`d been at the ring for 2 weeks, then swapped over,
my god, that seemed even such a change !
Looking at the videos;
In the morning Steph was lapping around 2mins 15secs in the wet on road tyres.
First lap out on the R888's and he did a 2min 13secs.
Second lap out on the R888's and it was down to 2min 3secs - 12secs off ohmy.gif
But as you told me Nige, its the confidence that was the biggest difference wink.gif
Feb 11th 2008
Update:
Went down to work on the car this weekend with Steph.
Got up early Sat morning and drove down to Andover, great run down with stunning weather. Fingers crossed it would stay that way.
Arrived, and the car was already out and Steph was ready to get on with it.
Well it was 9:50am and the sun had been up for hours tongue.gif
Sills
The first job was to sort out the sills which had developed a hole on one side when the jack had slipped at cadwell and pushed through a small rusty area around a grommet angry.gif
As we were doing this we decided to put some strengthening plates on to help with jacking in the future.
So, we cleaned the area up...
made some plates...
welded plates on...
Waxoiled the plates...
Roll Cage support
Needed to put some brackets on the rear feet of the cage for extra strength.
Templates cut, plate cut...
MC Hammer time
Feel the force Luke...
Finished brackets
Welded into plate
Job done!
Baffled Sump
Rumour has it that VR's suffer on the Ring with oil issues so we wanted to make sure we minimised this by putting a baffled sump on. As a new one cost silly money we made one instead.
Sump off...
New sump with card board templates...
Test fit....
Bugger catches somewhere...
Bit of cutting later and plates are test fitted...
And welded into place...
Here is a close up of the single baffle that we ended up going with. Hopefully you can see that there is a good clearance under the baffle but should prevent the oil from draining away under heavy cornering.
Further test fitting showed more fouling so the smaller plate had to come off but still the other plate will add some benefit...
Gasket and sealant added....
Job Done!
Rose Jointed Drop Links
At Cadwell we had a ARB droplink fail (newly fitted but just couldn't cope) so decided to get some Rose jointed ones.
Steph sourced parts from Simon (Big Thanks thumb.gif) rather than buying new joints, due to the great price difference biggrin.gif
Off came the original ones...
Old and new...
Attached to ARB...
Fully connected...
Job done!
We also fitted an exhaust support and adjusted it from slightly catching but no photos taken.
All in all a good weekends work.
