DundeeDub 0 Posted September 12, 2004 Report Share Posted September 12, 2004 as above, which ones are the better and also is it worth getting the gearbox one changed?? Link to post Share on other sites
acf8181 0 Posted September 12, 2004 Report Share Posted September 12, 2004 i've got a full set of vibratech ones, fast road rears with competition front. all i can say is wow! they've totally transformed it, theres no vibration and the engine is rock solid, just the way it should be.i'd previously tried replacing the front one with an o.e. one at it made no difference.uprated is the way to go...will cost £300 unfortunatly, though phatvr6's mate might be able to get them a tad cheaper Link to post Share on other sites
speedo 0 Posted September 12, 2004 Report Share Posted September 12, 2004 I have VF front, and it`s made it a little harsh, but well happy. If i was buying again, i`d recomend vibratec race front, and OE rears... done that on my girlfriends, and it feels fantastick ... Link to post Share on other sites
DundeeDub 0 Posted September 13, 2004 Author Report Share Posted September 13, 2004 was going to be going for the vibratechnics ones but i seemed to remember a post ages ago about the VF ones being better was never going to be going o.e. need to stiffen up the engine.anyone done the gearbox one?? Link to post Share on other sites
andy 0 Posted September 13, 2004 Report Share Posted September 13, 2004 i've got the vibratechnics fast road front engine mount and its much improved over the o.e one, gearchange is better and the whole car feels better in the corners and on and off the power, thinking about getting the other mounts but also interested in how people find them? Link to post Share on other sites
acf8181 0 Posted September 13, 2004 Report Share Posted September 13, 2004 i've got a full set of vibratech ones' date=' fast road rears with competition front. all i can say is wow! they've totally transformed it, theres no vibration and the engine is rock solid, just the way it should be.[/quote'] Link to post Share on other sites
DundeeDub 0 Posted September 13, 2004 Author Report Share Posted September 13, 2004 sorry acf misread that post thought you had just done the other two. Link to post Share on other sites
acf8181 0 Posted September 13, 2004 Report Share Posted September 13, 2004 thought that was the case, so thought i'd remind you! Link to post Share on other sites
Geastb 0 Posted September 13, 2004 Report Share Posted September 13, 2004 Where do you get the vibratec mounts? I'm changing my engine next week so probably a good time to change the mounts at the same time! Link to post Share on other sites
six appeal 53 Posted September 13, 2004 Report Share Posted September 13, 2004 Stealth do them both. Vibratech and VF ones. Link to post Share on other sites
VR6Pete 1,455 Posted September 13, 2004 Report Share Posted September 13, 2004 ive got em - they are nice:) Link to post Share on other sites
Valver 0 Posted September 13, 2004 Report Share Posted September 13, 2004 I've got the VF rear and box mount and will be ordering the Vibratechnic front mount for my Mk2 VR conversion.... Link to post Share on other sites
mk3anni 0 Posted September 13, 2004 Report Share Posted September 13, 2004 VF?????Cost anyone??? I think i need a new front mount. Link to post Share on other sites
acf8181 0 Posted September 13, 2004 Report Share Posted September 13, 2004 i got mine from phatvr6's mate Link to post Share on other sites
mk3anni 0 Posted September 13, 2004 Report Share Posted September 13, 2004 Ahhh, i'll ask him next time he's on.Ta Link to post Share on other sites
Valver 0 Posted September 14, 2004 Report Share Posted September 14, 2004 http://www.vfengineering.com/vw_mounts.htm Link to post Share on other sites
VRmonster 1 Posted September 14, 2004 Report Share Posted September 14, 2004 i had the VibraTechnics front one fitted ages ago, and it felt great for about a week, then it destroyed the rears due to all of the vibrations being transmitted through them, so id say if you get any get em all. i have the 2 rears sat in the garage waiting for me to strip the engine out and drop em in. lol Link to post Share on other sites
Geastb 0 Posted September 14, 2004 Report Share Posted September 14, 2004 How easy are they to fit? My engine is out next week so i assume that its easier then but in case i dont get them before then - how difficult a job is it? Link to post Share on other sites
acf8181 0 Posted September 14, 2004 Report Share Posted September 14, 2004 both the engine ones are very easy. the g.box one is the toughy.with the front one you can just put a jack under the engine, then release the top and bottom bolts of the mount. jack the engine up slightly, then undo the two bolts at either end of the front crossmember and drop the crossmember to give enough room for the mount to be removed.the engine rear, you need to remove the drivers side wheel, then support the engine and undo the top bolt (theres a nut on top of it holding some wiring in place) then go under the wheel arch and undo the four bolts holding the bracket in place. remove the bracket and undo the two side bolts holing the mount in, and remove the mount.the gear box one is more trcky, as you have to remove the brackets again...but the nuts are very hard to get to. best way is to go from under the wheel arch again. but you'll have to be persistant with that one. Link to post Share on other sites
Geastb 0 Posted September 14, 2004 Report Share Posted September 14, 2004 in other words - get them done at the same time as the engine fitting!!! Link to post Share on other sites
