harry 0 Posted January 6, 2007 Report Share Posted January 6, 2007 hello all, im after some advice please, ive taken my vr off the road for the time being, (sorn) and need to know the best way to protect the engine etc whilst its not in use, it will be garaged. i had a mate keep an elise in our garage for some time and he used to get a jump start so he could get it out to wash every so often, but ive heard this isnt the best thing to do? should i periodically turn it over and run it on the driveway or just leave her tucked away? ive also heard that removing the spark plugs is a good idea? im no mechanic and time is limited to me, i may consider selling her if it is doing her more harm being locked up!it means so much to me but i dont want to break it by looking after it incorrectly.thank you for reading this, any help would be great..... Quote Link to post Share on other sites
Russ_vr6 12 Posted January 6, 2007 Report Share Posted January 6, 2007 if for 6 months or so if u wanna do it proper mate,get her up on 4 axle stands to take the weight off the tyres,plugs out,and put a drop of oil in the cylinders,and get a sheet to put over her too Quote Link to post Share on other sites
jaysVR6 2 Posted January 8, 2007 Report Share Posted January 8, 2007 Try this out:Before you put your car away for the season give it a good wash and wax job. It is VERY IMPORTANT to always store your car clean. Don't forget to wash off the underneith. After all, that's were most of the rust starts. A good coat of wax on the car will protect the finish against stains if something happens to get on it during the time it is being stored. If you use a car cover, put it on while the car is clean and dry to protect against dirt, dust and possible scratches. DO NOT cover your car with plastic or one of those blue tarps that you can get at the hardware store. It only traps moisture, and trapping moisture between the finish and a piece of plastic will make the paint bubble and rust will begin to form.# Take your car for a drive and get everything warmed up before you park it. By getting your car up to operating temperature it helps to burn off contaminants in the oil and it also gets rid of moisture in the crankcase and the exhaust system. NOTE: Don't start your car during the winter unless you plan to drive it or allow it to get up to normal operating temperatures. "Short running" the engine will allow moisture to build up in the crankcase and exhaust system.# Change your oil and oil filter. Fresh oil will protect the internal parts of your engine better because there are less hydro-carbons and other contaminates in fresh oil. If you would rather change your oil in the spring, be sure to do it as soon as possible after you get the car out of storage.# Check and fill all major fluids, including brake fluid, clutch fluid reservoir and supercharger oil (On SC's). Also be sure your antifreeze is clean and fresh to avoid the cooling system from freezing or possible corrosion.# Fill the fuel tank just before you park the car for the winter. (This will help prevent moisture from condensing inside the tank). If you are not planning to visit your car during the winter, be sure to add a good fuel stabilizer.# Remove the battery and keep it charged. When storing a battery you should keep at as close to room temperature as possible and it should be kept off of the floor so that it doesn't discharge. Store it on a wooden shelf or on a large block of wood (a piece of 4x4) several inches off of the floor to keep it from discharging.# Put steel wool or rolled up scotch-brite pads in the tailpipes and also in the air-intake openings to keep mice from using your car as a food pantry.## Some say place a board on the clutch pedal rod to partially depress it, that helps to avoid the risk of the clutch and flywheel rusting together. (If you are only storing the car for a few months this really shouldn't be necessary). Never set the hand brake. The brake shoes or pads could stick to the drums or disks or the cables could rust or freeze up during storage.## If you store your car off of the ground, (on jack stands), the stands should be under the suspension. If not, damage to the shocks and other suspension parts can occur.# If you store your car on the ground be sure to over-inflate the tires slightly. Five to 15 pounds should be enough. Even tires that are new or in good condition can lose around one or two pounds of pressure per month. When you get your car back out in the spring, re-check the pressures to insure against tire damage. Put a moisture-absorber, like baking soda, inside the car to keep mildew from starting inside the cars interior. (From mildew come mold, from mold comes a new interior). If you store your car inside a heated area leave the windows opened about 1/4 to 1/2 inch to allow the air to circulate.## Do NOT treat inside surfaces with Armor-All (or similar) products before storing your car. They contain a lot of water and chemicals that can encourage mildew and mold. (I did the dash on my RST one time before I stored it and it took all of the next summer to get that musty smell out of the car). Mouse traps or poisons placed around the car is also a good idea, BUT be sure that your dogs and cats can't get to it. Place them around the car every several feet. Leave your sun visors down so it is more difficult for mice to get into the headliner if they do get into the car. NOTE* Mothballs will repel some pests, but the smell stays in the car for a long time. Don't put them IN your car. Bars of soap placed in an open plastic butter tub or coffee can in the trunk and front and back floorboards work good too. They smell a lot better too.## Always store your car on a vapor barrier like a large piece of plastic. Try not to store your car where vehicles will be coming in and out during the winter months. They bring moisture in with them. If you are like me, (somewhat forgetful), make notes and leave them on the front seat or tape them to the windshield to remind you what needs to be done in Spring to get the car ready for the summer season.# Lastly, be sure you have plenty of photos of your car to look at all winter. Otherwise you'll go nuts by the time you get to drive it in the spring. It also helps if you have some racing games on your computer!!! munroe98vr and rich 2 Quote Link to post Share on other sites
Earwig 89 Posted January 8, 2007 Report Share Posted January 8, 2007 Very impressive list. Very infomative :-)Mark. Quote Link to post Share on other sites
vr6newcomer 1 Posted January 10, 2007 Report Share Posted January 10, 2007 nuff said, thats a very impressive list dude, ure cars r stored better than some pple have their cars when on the the road...lol.but ill remember to come back 2 this post if i ever need to store a car. Quote Link to post Share on other sites
VR6gaz 0 Posted January 10, 2007 Report Share Posted January 10, 2007 ive stored mine for last 2 winters (currently SORN and in garage now) Its in a council garage across from my house which just happens to have a nice sized car park next to it(handy when u have no TAX) so it gets a run round there every other day n still i clean it every weekend.jays2.9VR6 wrote:"DO NOT cover your car with plastic or one of those blue tarps that you can get at the hardware store. It only traps moisture, and trapping moisture between the finish and a piece of plastic will make the paint bubble and rust will begin to form"mate of mine had this happen to his series 1 RS Turbo - needed a respray to sort it!!!!! Quote Link to post Share on other sites
ingham 5 Posted January 10, 2007 Report Share Posted January 10, 2007 im on my 2nd year storing vr over winter ,its geat when its back on road but hard not to drive it.ive got a nice dry garage so i only charge the battry every 3 months,the disks dont even go rusty! doent even get dusty...think i minght try the soap bar in tub Quote Link to post Share on other sites
mkoneboy 1 Posted February 2, 2007 Report Share Posted February 2, 2007 Some good advice there Quote Link to post Share on other sites
v!rus 1 Posted December 18, 2007 Report Share Posted December 18, 2007 hectic..im glad its never that cold here in S.Africa..we never store cars here..unless it's stolen or @ the police impound LOL...just kidding hey!! rich 1 Quote Link to post Share on other sites
J@BZVR6 0 Posted September 16, 2009 Report Share Posted September 16, 2009 Hi champs :-| Good adive there champs!!! Learned a few tricks! Thanks! :-d Quote Link to post Share on other sites
H13VYY 0 Posted September 16, 2009 Report Share Posted September 16, 2009 ressurected! Quote Link to post Share on other sites
brokenvr691 0 Posted August 14, 2010 Report Share Posted August 14, 2010 I wish i read this before i put mine in storage cos it just wont start now. Had to get new tyres, the milldew has just cleared an it took some persuasion to unseize the brakes (I did have the sense to leave the handbrake off though) Quote Link to post Share on other sites
rich 40 Posted May 10, 2016 Report Share Posted May 10, 2016 very good write up that dude,fair play....lots of good tips Quote Link to post Share on other sites
