About Russ_vr6
wiltshire
dannivr6 reacted to a post in a topic: POST A SINGLE PIC OF YOUR CAR
VR6Pete reacted to a post in a topic: Pete's OBD2 Corrado VR6 - On The Road
Stephano reacted to a post in a topic: My sensible family car. Vento Vr6 inside
For only a few months what you have done is fine - you could get anal and take the weight off the tyres so they don't flat spot by putting the car on axle stands but I wouldn't do that unless I was storing a car for 6 months plus. I have had over 20 Clio 172/182's and most were track based cars so sat up with little use between track days and I have never had an issue with simply doing the basics before a month ir two lay up ( good wash and dry, windows slighly open to aid ventilation etc) So if you have a garage I'd be cracking open a couple of Windows about an inch and leaving it
Russ_vr6 replied to Stephano's topic in Members Rides and Event Photos
looks lovely mate! Such underrated cars, the Vento's- 51 replies
- ongoing project
- 5 years
(and 1 more)
Tagged with:
well trodden suspension and brake upgrades?
Russ_vr6 replied to Russ_vr6's topic in Wheels, Brakes, Suspension and Steering
Agree - as said the only way to make a top strut brace to work is if it attaches to the top mounts rather than the strut tops. Will look into the brace, ARB's and uprated bushes - what do we think about wheels - 15 or 16 inch? Thanks Guys so far! -
I know I won't be the highest, I have just passed 172,000 miles, but i'd really be interested to hear from the rest of you high milers! Also from a tuning perspective, how have they held up at higher miles?
R32 Front Disc Recommendations.
Russ_vr6 replied to himselfunknown's topic in Wheels, Brakes, Suspension and Steering
Elaborating on this a bit, don't bother with drilled or groved discs, a disc can dissipate heat fine on a riad car, so ignore the flashy aftermarket ones, just buy some high quality basic discs - brembo do a range of oem style discs (I've used brembo hc's for many m as ny track days with issue) just make sure you get decent quality pads -
Thanks mate-is there any strut braces that attach to the top mounts? Most seem to bolt to the strut tops by piddly little 10mm bolts - which do absolutely nothing, I know pure motor sport do a kit but unsure if they do them for mk3-I'll research brakes seem ok bearing I'm on cheap pads-I've tended to use either 1155's or ds2500's - any preference on vr's? -
Russ_vr6 reacted to a post in a topic: Russ's VR6
bennyk reacted to a post in a topic: Russ's VR6
Oh and todays update lol
Cheers mate, yeah when I do a restoration or 'clean up' it is one of the first places I hit - it's amazing how much dirt and muck can find it's way into areas!
VR6Pete reacted to a post in a topic: Russ's VR6
Poriordan reacted to a post in a topic: Phil's mk3 vr6 turbo build
Any thoughts on this guys? -
looking very nice!
Ah smashing thanks mate, keep me updated
Yeah I can imagine they are-the morettes never felt that great a quality, but looks wise I think they look great - I don't tend to use my Golf in the dark much mind. I think I'll keep an eye out for whatever comes up first
Header tank cap ? Pressure in pipes ?
Russ_vr6 replied to Jakeyb's topic in Engine Maintenance and Problems
Well if you're squeezing the pipes and getting coolant out the cap then the cap is definitely knackered. The bottle could be damaged on the threads and to be honest for how cheap they are to buy I'd replace both - I've found with vw's that the caps are worth replacing every few years or so anyway as the pressure valves in the caps can go a bit weak. A miss on start could be a number of things - important thing is to not only make sure that it's not loosing oil and water but to also check the water and oil are not mixing(as you could think it's not an internal issue due to not seeing one fluid -
Ah ok yes - I do prefer the way the morettes sit in if that makes sense?
What do the hella ones look like guys?
