Days Won
2
redborbet last won the day on November 26 2018
redborbet had the most liked content!
About redborbet
hull
noggin reacted to a post in a topic:
Ignition Coilpack required
Neon Leon reacted to a post in a topic:
check my post about the phenolic coilpack spacer !! heat is why they crack and vr6's run hot if you get a new coil pack i can supply you with a phenolic spacer that should safeguard your coil pack
updated add - second batch now available for some people that missed out on the first or didnt see the post , iv kept the origional add below Hi all i hope this is ok to post on here after owning my vr for 7 years and going through three coil packs i thought id adapt the same idea as my phenolic inlet manifold gasket to the coil pack to help protect it and prolong the life of it iv had the idea for a while and decided to get this sorted as there are non available to buy in the uk its a 6mm pacer cut plate with four new allen head bolts to fit directly to the car , it sits on the sid
Im running a v9f with a bosch valve as well Seems fine but i did do some reading and you can use the 007 or the forge splitter valve if you want more noise apparently I thing the bosch ones are ok up to 8psi and then anything over your best off upgrading
Messaged you mate if you havent recieved it my number is 07980690184 you can give me a text
Bealieboy reacted to a post in a topic:
Club Event: Rolling Road Day - 05/22/2016
redborbet replied to michael5556's topic in Meets & Events
A bacon buttie ? -
It was high for na , 230.2 was the figure the camber was out though and according to jon it can male a difference on the rollers but its been set up now and ran a few thousand miles just changed to fully synth oil to so it should all be performing at its max and hopefully good numbers i think anything over 200 is good na , iv put a fair amount in to get that figure like -
Hoping to hit 230 n/a again , daubt it though -
bennyk reacted to a post in a topic:
Sweet -
VR6Pete reacted to a post in a topic:
Ill be at this now mot passed today and a few issues sorted put me down for the rollers -
Dave_ciw reacted to a post in a topic:
VW Festival Leeds 16/08/2015 Pictures (pic heavy)
redborbet replied to Dave_ciw's topic in Previous Events
Love the pics man -
VR6CABBS reacted to a post in a topic:
VW FESTIVAL 2015, HAREWOOD HOUSE LEEDS
daveyboy reacted to a post in a topic:
Thank you daveboy
Exellent news i was really hoping id get on the stand cant wait for this now Should be a great weekend
Need to get signed up to the vr6oc but is there room for one more ? If so id deffo take the space as im camping all weekend so would be nice to get the rado on there after its full rebuild
VR6OC Competition Time DA POLISHER WITH POLISH & PADS
redborbet replied to Dave_ciw's topic in General Chat
Ill take five strips please can someone send me the paypal adress ? Id say next time you could make this process so much easier by just putting the paypal adress in the origional first post- 45 replies
- competition
- cleaning
(and 3 more)
Tagged with:
Upgrade 312mm Discs and Calipers Please Help !
redborbet replied to VR6DEN's topic in Wheels, Brakes, Suspension and Steering
Are the bleed nipples at the top or the bottom ?
