Days Won
5
UnitedMotorsport last won the day on November 6 2014
UnitedMotorsport had the most liked content!
About UnitedMotorsport
UK
Nick Rallye started following UnitedMotorsport
C J BICHO reacted to a post in a topic: difference in vr6s ?
UnitedMotorsport started following jetplane
Melting pistons on Vr6 turbo
UnitedMotorsport replied to GrantVr6's topic in Engine Maintenance and Problems
What is the temperature of the exhaust gas pre turbo? -
matt@unitedmotorsport.net
4mo front arms
UnitedMotorsport replied to mattvr6's topic in Wheels, Brakes, Suspension and Steering
No - all are pressed ~steel -
If you are planning on using our turbo software, then the wideband sensors need to be in the downpipe.
Bealieboy reacted to a post in a topic: AFR on idle for VRT
AFR on idle for VRT
UnitedMotorsport replied to ssaunders's topic in Engine Maintenance and Problems
Lambda 1 at hot idle. -
dom.joy reacted to a post in a topic: Soldered or socketed ECU
Most OBD2 USA market ECU's have a socket from the factory.
No OBD2 (021906256xx) ECU is socketed from the factory.
Unplug the throttle position sensor and run the car again, do the symptoms persist?
The same thing VW does - nothing. here is a cap: http://www.ebay.co.uk/itm/Audi-A4-Avant-B5-2-5-TDI-Olkuhler-Deckel-021117063-/261367689178
If any of that PTFE comes away, it will potentially wreck the engine.
Use an OE alloy cap. Is that PTFE tape?
The stalling problem is caused by the item right behind the left headlamp.
The Duke reacted to a post in a topic: External Oil Cooler
Bealieboy reacted to a post in a topic: zircotech coating
Used many many times, its a fantastic product.
michael5556 started following UnitedMotorsport
UnitedMotorsport started following michael5556
Engine code difference
UnitedMotorsport replied to himselfunknown's topic in Engine Maintenance and Problems
With the ECU's being non-interchangeable the same goes for the software inside them.
