ingham
Everything posted by ingham
  1. Trying to get my car ready for show but going to be tight
  2. ive a coil pack and a pair of rear shocks standard ones if you need them
  3. great track & well run day nice to meet you swivelonit i was amazed how easy it was to get on track all day ,no ques at all
  4. is it warming up ok , maybe thermostat may have stuck open ?
  5. im going in vr if can get place on show and shine or in van if not
  6. you can check if its the immobiliser thats lost its code by disconnecting battery for 15 mins it should start one time and run if it is ,as immobiliser is reset after 15mins and locked on engine shut down , mine did the same i had to take it to vw to reset the code in immobiliser the code reader i had wouldnt do it only the vw one could reset it
  7. vw do a aero wiper kit that fits onto standard arms now ,got them on mine
  8. i would put new bearing in if i were you there only about £5 from most bearing specialists
  9. if the noise is coming from the area you videoing on clip its the aux water pump area
  10. just had sensor go down on mine got a new one for £12.98, has fixed the problem http://www.ukpartsdirect.com/index.php
  11. http://www.clubgti.com/forum/showthread.php?t=224427&highlight=abs+mk3 see this about it on cgti
  12. depends on valves and valve seat condition may just need reseating ,that can be done at home , you will need valve spring compressor and grinding paste
  13. my car always struggled on emissions ,this time i took it out for good thrash before took it really hot , it passed easy
  14. i have oval only pic is this one
  15. grind heads off. get new bolts from vw or be sure you get high tensile steel ones to replace them
