Slim 0 Posted August 12, 2005 Report Share Posted August 12, 2005 I'm looking at improving my brakes.I know the front stuff will go on ok if I can get a spacer. Does anyone know what size of spacer I'd need and where I cn get it from? IIRC, it's the same spacer you need to fit the 312mm brakes from other mk4's.I've not had the rear brakes off my car yet so I'm not sure what the deal is there. I think I've read that the rear wheel bearings are part of the standard VR rear discs. Will this cause problems with getting the R32 rears to fit on easily? Anything else i'd need to do to get them to fit?Cheers for any advice. Link to post Share on other sites
purple highline monster 0 Posted August 12, 2005 Report Share Posted August 12, 2005 think the rear set up is completely different tbh the front is simmilar but again quite a few differences, it would probably be just as effective to fit uprated discs and pads imo and if you only have 280mm brakes go to the later 288mm set up it would be more cost effective and you know it will work properly you dont want to compromise when it comes to being able to stop!!!!! Link to post Share on other sites
Slim 0 Posted August 12, 2005 Author Report Share Posted August 12, 2005 I've got 288mm uprated discs and pads, still isn't as good as I'd like, and I'm planning on upgrading the engine soon so I'll need better brakes first. Link to post Share on other sites
Ciaran 4 Posted August 19, 2005 Report Share Posted August 19, 2005 are u mad my standard brakes alone are flippin mental compared to most of my last cars!!saying that they were frenchwhats the engine plans? Link to post Share on other sites
craggsy 91 Posted August 19, 2005 Report Share Posted August 19, 2005 The 288s should stop you quite well as they have a bigger surface area on the brake pads i beleive.I wait to be corrected Link to post Share on other sites
Slim 0 Posted August 19, 2005 Author Report Share Posted August 19, 2005 Well it's got 288mm as standard, with black diamond discs and pads, they're pretty good, but I always think there's room for improvement. Link to post Share on other sites
VRmonster 1 Posted August 19, 2005 Report Share Posted August 19, 2005 the problem with the r32 setup is that the calipers are wayy fatter, not just bigger discs, if you look at the inside of a standard r32 wheel it has a massive dished shape to the spokes. and it would be difficult to fit these under most 17s.its easier to go for the 312mm audi setup although id love the r32 myself. might give it a go one day. sod it, lol. Link to post Share on other sites
craggsy 91 Posted August 20, 2005 Report Share Posted August 20, 2005 True, always room for improvement on the brakes Link to post Share on other sites
Ultimatetune 0 Posted August 25, 2005 Report Share Posted August 25, 2005 i think you will have to many complications using r32 stuff, i would use a tried and tested upgrade avalable from loads of companies and just use some grooved disc and uprated pads at rear as almost all your braking force is at the front anyway Link to post Share on other sites
Slim 0 Posted August 25, 2005 Author Report Share Posted August 25, 2005 R32 stuff have been tried and tested on many R32's without much complaint, just need a spacer for them to fit on the front and buying them privately will cost a fraction of most upgrade kits from suppliers. Link to post Share on other sites
purple highline monster 0 Posted August 25, 2005 Report Share Posted August 25, 2005 i have seen a few mk2 vr6`s with porsche 6 pot callipers on!!!! why not go the whole hog! Link to post Share on other sites
Slim 0 Posted August 25, 2005 Author Report Share Posted August 25, 2005 Cos i'm skint after having to buy a new gearbox Link to post Share on other sites
simey 0 Posted August 26, 2005 Report Share Posted August 26, 2005 Slim, how about a brembo brake kit? Link to post Share on other sites
Slim 0 Posted August 26, 2005 Author Report Share Posted August 26, 2005 Aye, that would be good too, talking big bucks though aren't we? Posted this thread after I seen a full set of R32 brakes on eBay for about Link to post Share on other sites
Radostormvr6 2 Posted August 26, 2005 Report Share Posted August 26, 2005 If you want the spacer try www.ecstuning.com $49.00 Link to post Share on other sites
VRmonster 1 Posted August 26, 2005 Report Share Posted August 26, 2005 how big is the spacer? 6mm? Link to post Share on other sites
Slim 0 Posted August 27, 2005 Author Report Share Posted August 27, 2005 http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi/?html=learnmore.html&productID=1475Good find. Link to post Share on other sites
Radostormvr6 2 Posted August 27, 2005 Report Share Posted August 27, 2005 Just fitted the 312 setup on my Rado today, well worth it Link to post Share on other sites
mattverth 0 Posted September 15, 2005 Report Share Posted September 15, 2005 After all this discussion re: 312mm brakes, i was wondering...if you got the caliper spacer kit from ecs tuning, could you just walk into your local audi stealership and buy the balance of the parts, ie: carriers, discs? Would save me some serious postage from US or UK....With the caliper moved closer to the edge of the wheel, I could then ditch the 3mm wheel spacer and not have to roll my front arches.... Link to post Share on other sites
dubloke 4 Posted September 15, 2005 Report Share Posted September 15, 2005 why dont you just go out and buy a hi-spec kit for 600 notes? comes with discs, pads and 4 pots, with all hardware! stop like a bitch! Link to post Share on other sites
mattverth 0 Posted September 15, 2005 Report Share Posted September 15, 2005 Ive just found a bloke selling whole Audi S3 stock brakes in Aus.....Hijack..would this be the way to go? Link to post Share on other sites
Seademon 0 Posted September 15, 2005 Report Share Posted September 15, 2005 I've got the Hi-Spec conversion on my car - 312mm discs at the front, come with bells etc, brackets for the calipers and what not - got drilled/grooved discs at the rear, stainless hoses all round, green stuff all round - Its true, it stops like a bitch! ha ha! When I brake hard it sounds like the landing gear of a plane is being lowered! Also when I brake hard, they are so good at slowing you down, you can slide out of the seat! Link to post Share on other sites
VRmonster 1 Posted September 15, 2005 Report Share Posted September 15, 2005 slide out of the seat, lol... next purchase = 4 point harnesses, lolwhat exactly do you get with the hi spec kit then as i was gonna do the 312 but for Link to post Share on other sites
Seademon 0 Posted September 16, 2005 Report Share Posted September 16, 2005 Yeah I could do with a harness!As far as I know it came as 2 discs, bells, pads & caliper mounting brackets as my car is using the standard VR6 calipers I believe - I have ordered new Green Stuff pads since & Golf Vr6 ones sitted straight in - my car also has a big disc conversion on the rear too. The front discs on their own are about Link to post Share on other sites
Nerih 0 Posted September 16, 2005 Report Share Posted September 16, 2005 i think what he's saying is tried and tested on the vr6, like the brembo kit and audi stuff... Link to post Share on other sites
