Coolant everywhere, banging sound, f***ed basically
Hi guys - my VR has been drinking coolant like there is no tomorrow. After looking at the forum I decided it could possibly be the thermostat housing. In the last few days though there has been a rythmic tapping sound from the left hand side of the engine where the rubber belt is and today the coolant has come pouring out from this area. I'm assuming that this is where the water pump is located. Is that right?
Does anyone think the pump could have been making that noise. Im hoping its not the chains :@ Also what is the name of that rubber belt on the left hand side? Mine looks pretty worn...
Thanks for your reply. Here are some images of the offending area
http://i14.photobucket.com/albums/a333/PiperUK/DSCF1011.jpg
http://i14.photobucket.com/albums/a333/PiperUK/DSCF1008.jpg
http://i14.photobucket.com/albums/a333/PiperUK/DSCF1009.jpg
You can see the coolant on the road in the first pic. In the second pic the corroded rubber belt and the tapping noise are on the left hand side of the engine. The third pic is a close up of the belt - the coolant seems to be coming from here, its dripping onto the belt.
Yes. The noise is caused by the water pump pulley which isn't running truly as it's no longer balanced by the impeller. I'm sure I read that they are designed to leak if the impeller fails which explains the coolant leakage.
The belt simply drives the pulley off the crank which spins the waterpump.
[blockquote]
Midland VW is in Cannock which is not too far.....
[/blockquote]
Thanks for bringing these guys to my attention, I didnt know about them. Maybe a little too far for me though mate, especially with a moaning wife and 2 kids in toe...Considering the amount of dubbers in the Black Country there is a gap in the market for a good VW garage... [blockquote]no ,
