scooter 10 Posted December 16, 2014 Report Share Posted December 16, 2014 i'm sorry if this is a bit of a repost, but i am suffering from a wet carpet on the passenger side, i've currently got no heater matrix in the car ( had a hole in it when bought and previous owner bypassed all the matrix pipes in engine bay ) so it cant be coming from that, ive checked the door and sunroof seals which look in pretty good condition. are there any other ideas to where it could be coming from? Link to post Share on other sites
Big J 283 Posted December 16, 2014 Report Share Posted December 16, 2014 The sunroof has drain tubes attached to it. Open the passenger door and youl see a little rubber dick sticking out of the body on the front end of the door frame. There's a good chance that's blocked up, and the same on the driver side. There's also drain tubes running above the headliner and draining out behind the rear bumper. Make sure all these tubes are clear. Be careful with compressed air incase you detach the tubes and then it's headliner and trims out to refit them.Tail lamp seals are a common failing point too so check for water in spare wheel well. It has a habit of running forward if excessive.Just a few places to start looking. damian8588 and scooter 2 Link to post Share on other sites
scooter 10 Posted December 16, 2014 Author Report Share Posted December 16, 2014 Thanks Big J will take a look at those in the morning Link to post Share on other sites
cactusjackslade 146 Posted December 16, 2014 Report Share Posted December 16, 2014 The sunroof has drain tubes attached to it. Open the passenger door and youl see a little rubber dick sticking out of the body on the front end of the door frame. There's a good chance that's blocked up, and the same on the driver side. There's also drain tubes running above the headliner and draining out behind the rear bumper. Make sure all these tubes are clear. Be careful with compressed air incase you detach the tubes and then it's headliner and trims out to refit them.Tail lamp seals are a common failing point too so check for water in spare wheel well. It has a habit of running forward if excessive.Just a few places to start looking.Little rubber dick sticking out..... lmao scooter, The Duke and VR6Pete 3 Link to post Share on other sites
daveyboy 897 Posted December 16, 2014 Report Share Posted December 16, 2014 Are they like little rampant rabbits J lol Bealieboy and Gwr corrado 2 Link to post Share on other sites
Big J 283 Posted December 16, 2014 Report Share Posted December 16, 2014 (edited) Couldn't think of any other way to describe them lol, but yeah, imagine the little clit stimulator bit?? Well you've got 2 on your car, one for each side of the sunroof. Simple test, give the end a squeeze and youl know if it needs emptying! Edited December 16, 2014 by Big J cactusjackslade 1 Link to post Share on other sites
cactusjackslade 146 Posted December 16, 2014 Report Share Posted December 16, 2014 Couldn't think of any other way to describe them lol, but yeah, imagine the little clit stimulator bit?? Well you've got 2 on your car, one for each side of the sunroof. Simple test, give the end a squeeze and youl know if it needs emptying!Lmao... I'll make sure to give mine a squeeze then incase they are full.... daveyboy 1 Link to post Share on other sites
daveyboy 897 Posted December 16, 2014 Report Share Posted December 16, 2014 Lol how did I know it was gonna go that way. Give them a quick squeeze but watch your eyes apparently it stings lol Big J and cactusjackslade 2 Link to post Share on other sites
VR6CABBS 1,311 Posted December 16, 2014 Report Share Posted December 16, 2014 Now that this post has took a turn for the worse I'd like to add........There's no easy way to say this but......Does your regular passenger have trouble holding on to a full bladder? Eliminate the easiest of solutions first. Hahahahaha daveyboy, cactusjackslade, Bealieboy and 1 other 4 Link to post Share on other sites
Big J 283 Posted December 16, 2014 Report Share Posted December 16, 2014 Now that this post has took a turn for the worse I'd like to add........There's no easy way to say this but......Does your regular passenger have trouble holding on to a full bladder? Eliminate the easiest of solutions first. HahahahahaLet's face it cabbs, with you me and Dave in here, op's lucky he's had even had half a constructive reply!That said, If squeezed to often, that can also result in a wet patch! Bealieboy, VR6CABBS and daveyboy 3 Link to post Share on other sites
daveyboy 897 Posted December 17, 2014 Report Share Posted December 17, 2014 Between a truck driver and a truck mechanic your always gonna get a professional reply lol Link to post Share on other sites
Big J 283 Posted December 17, 2014 Report Share Posted December 17, 2014 We had one fall over on Saturday morning, the answer they had off me was firstly "who was driving it and was he ok", swiftly followed by "HA! That's one less scania on britains roads" daveyboy 1 Link to post Share on other sites
daveyboy 897 Posted December 17, 2014 Report Share Posted December 17, 2014 Lol the scanny was obviously out on the piss on friday to fall over in a ditch lol shit thing is I'm back in a scanny at the minute Link to post Share on other sites
Big J 283 Posted December 17, 2014 Report Share Posted December 17, 2014 Ah I feel for ya, I really do. No doubt it's that toss 3 pedal opticruise shite too Link to post Share on other sites
daveyboy 897 Posted December 17, 2014 Report Share Posted December 17, 2014 Sure is mate. Even my iveco only had 2 pedal lol Link to post Share on other sites
dom.joy 87 Posted December 17, 2014 Report Share Posted December 17, 2014 Rusted floor around one of the rubber grommets? Link to post Share on other sites
scooter 10 Posted December 17, 2014 Author Report Share Posted December 17, 2014 Floor is in perfect condition no rust by any grommets...checked inside the doors this morning and no " rubber dicks " jumped out at me..maybe a opening myself to silly answer question lol but how big are they..are they quite obvious ? Link to post Share on other sites
daveyboy 897 Posted December 17, 2014 Report Share Posted December 17, 2014 Well you can get them in various sizes scooter. From tiny to ron Jeremy lol....... oh you talking about the water drain pipes lol scooter 1 Link to post Share on other sites
scooter 10 Posted December 17, 2014 Author Report Share Posted December 17, 2014 Now how did I know it was going to go down this route lol Link to post Share on other sites
daveyboy 897 Posted December 17, 2014 Report Share Posted December 17, 2014 Sorry mate I couldn't resist lol. They'll not be very big I wouldn't of thought I'd say about the same size as a straw? I haven't seen any myself Link to post Share on other sites
scooter 10 Posted December 17, 2014 Author Report Share Posted December 17, 2014 Lol cheers davey will have another look in morning Link to post Share on other sites
Big J 283 Posted December 17, 2014 Report Share Posted December 17, 2014 (edited) They stick out about an inch from the door frame between the 2 hinges, I've had a couple of mk3s in the past where they've been full of crap and leaves etc. that said it might just be where I live, being a country boy and all that lolScooter, if you can just stick a pic up of the door opening on your car and I'll see if you've got what I'm thinking of. I'm starting to doubt myself now! I'd check mine for you but it's wrapped up and I'm just too busy until next week to lift the covers sorry. Pissed scanias by day, hungry dairy cows by night. Someone get me a violin!!!! Edited December 17, 2014 by Big J daveyboy 1 Link to post Share on other sites
Big J 283 Posted December 18, 2014 Report Share Posted December 18, 2014 (edited) Here ya go. Not my pics, they belong to that bloke called goggle or google or something but he said I could borrow them Rear - behind bumperFront - in door pillarThat blue one is actually a mk4 but same idea. Edited December 18, 2014 by Big J thesurgeon 1 Link to post Share on other sites
dom.joy 87 Posted December 18, 2014 Report Share Posted December 18, 2014 I had to unblock mine and just poured boiling water into the sunroof drain channel and got a long sink unblocking spring divice from a local hardware store. Twisted it and pulled out so much crap then got burnt by the boiling water that flowed out haha Link to post Share on other sites
Big J 283 Posted December 23, 2014 Report Share Posted December 23, 2014 Scooter, how did you get on with those little dicks? Link to post Share on other sites
