lumoxs 0 Posted November 25, 2011 Report Share Posted November 25, 2011 ha, well today i decided to lengthen the loom.engine plug ecu etc and now the car wont start.... it cranks n cranks but no fire.....so i had to chop the ecu plug, and engine loom plug to get the loom through the hole i had cut to hide it in the scuttle pannel...but i extended the loom etc and plugged it all up but now it just cranks n cranks but nothing.i have checked all the right color leeds go to the right ones etc and thats all correct...i then got my multi meter out and checked the engine plug to see if it was all getttin power and again. all the wiries on the engine plug was gettin power. so, now im stuck... any ideas please? Link to post Share on other sites
filtee 0 Posted November 25, 2011 Report Share Posted November 25, 2011 Have ya tried switchin it off and on again? Link to post Share on other sites
lumoxs 0 Posted November 25, 2011 Author Report Share Posted November 25, 2011 yup turned it off and on, disconnected the ecu and battery plugged it all back in.... nothing.possibly thinking of purchasing another loom! Link to post Share on other sites
oldmandon 1 Posted November 25, 2011 Report Share Posted November 25, 2011 Way to go if you ask me...start again ......... Link to post Share on other sites
lumoxs 0 Posted November 25, 2011 Author Report Share Posted November 25, 2011 yup. think i may just buy anoher loom and boll0xs it all off.....least i know what to do for next time..... all a learning curve...... Link to post Share on other sites
legvw 0 Posted November 25, 2011 Report Share Posted November 25, 2011 I your not getting a spark or of your fuel pump doesn't prime then I'd say there's something wrong with the crank sensor/crank sensor loom. Link to post Share on other sites
lumoxs 0 Posted November 25, 2011 Author Report Share Posted November 25, 2011 well it cranks n cranks but doesnt smell of fuel..... possibly fuel pump aint priming then? Link to post Share on other sites
rodney 17 Posted November 25, 2011 Report Share Posted November 25, 2011 quick check .... pop a plug out and hold against the engine whilst cranking... you should see a spark... that'll firm that up and you should be able to smell fuel from the hole the plug came out of....remember to use insulated pliers otherwise you will do the dance of shame as you get electrocuted... Link to post Share on other sites
Daverse 175 Posted November 25, 2011 Report Share Posted November 25, 2011 quick check .... pop a plug out and hold against the engine whilst cranking... you should see a spark... that'll firm that up and you should be able to smell fuel from the hole the plug came out of....remember to use insulated pliers otherwise you will do the dance of shame as you get electrocuted..it only tickles.. Link to post Share on other sites
VR6Pete 1,455 Posted November 25, 2011 Report Share Posted November 25, 2011 How come you lengened the loom Link to post Share on other sites
cbmotorsport 0 Posted November 25, 2011 Report Share Posted November 25, 2011 sounds like you have a wire in the wrong place, lengthening a loom will cause no ill effects providing all joints are sound,each cable goes to the right terminal, and all earths and lives are in the right place. i lengthened the loom on mine when i did the conversion, took a while but if you take it slow and double check each connection its easy double check your fuel pump is priming by sticking your head next to the fuel pump while someone flicks the ignition on, then do as stated above, check for spark . Link to post Share on other sites
lumoxs 0 Posted November 26, 2011 Author Report Share Posted November 26, 2011 sounds like you have a wire in the wrong place' date=' lengthening a loom will cause no ill effects providing all joints are sound,each cable goes to the right terminal, and all earths and lives are in the right place. i lengthened the loom on mine when i did the conversion, took a while but if you take it slow and double check each connection its easy double check your fuel pump is priming by sticking your head next to the fuel pump while someone flicks the ignition on, then do as stated above, check for spark .[/quote']This is what's making me think maybe I have put the wrong fcolour together... Fir example there was 3 brown and black wires!!!! So now I'm after an ODB1 wiring loom if there is one for sale?? Link to post Share on other sites
filtee 0 Posted November 26, 2011 Report Share Posted November 26, 2011 Why not swap the brown and black ones one at a time.And try it each time? Link to post Share on other sites
lumoxs 0 Posted November 26, 2011 Author Report Share Posted November 26, 2011 Done lol.Problem is, I cut the ecru loom and engine plug loom the same time. And had a fewvsets of 2 wires everywhere blue red black green etc. Could proberbly be a simple fix, but I think it would be easier to just get a new loom and do it 1x1Plus just found out my engine is a AAA so I bet knowin my luck them looms are like hens teeth!! Link to post Share on other sites
filtee 0 Posted November 26, 2011 Report Share Posted November 26, 2011 You'll find one on ebay but if not theres a vw breakers near me that will probably have one if you struggle. Dub haus theyre called. They have a website. Link to post Share on other sites
lumoxs 0 Posted November 26, 2011 Author Report Share Posted November 26, 2011 No spark and no fuelMy mate has an AAA engine project and has a spare engine ecu fusebox loom sp now i can sit there and follow wire for wire what goes whereFingers crossed problem solved Link to post Share on other sites
lumoxs 0 Posted November 29, 2011 Author Report Share Posted November 29, 2011 just a thought, if i have NO spark and NO fuel getting to the engine,could this be relay or fuse related rather than getting a wire mixed? Link to post Share on other sites
lumoxs 0 Posted November 30, 2011 Author Report Share Posted November 30, 2011 replaced the fuel pump relay and nw im getting fuel, still not getting spark tho...any ideas?? Link to post Share on other sites
michael5556 247 Posted November 30, 2011 Report Share Posted November 30, 2011 Is it dizzy or cool pack? Link to post Share on other sites
lumoxs 0 Posted November 30, 2011 Author Report Share Posted November 30, 2011 coil pack me ansum. Link to post Share on other sites
cbmotorsport 0 Posted November 30, 2011 Report Share Posted November 30, 2011 check that you have a live and an earth to the coil pack, pins 1 and 5. and the 3 pins in the middle are the spark feeds from the ecu, check you have an earth pulse at these pins when cranking,if not, let us know and ill post an ecu pinout diagram so you can check pulse wires. Link to post Share on other sites
lumoxs 0 Posted November 30, 2011 Author Report Share Posted November 30, 2011 they pins 1 & 5 on the engine loom plug ? Link to post Share on other sites
cbmotorsport 0 Posted November 30, 2011 Report Share Posted November 30, 2011 no sorry should have made myself clearer, im talking about the plug on top of the coil pack mate, cant remember what pin numbers they are on the engine loom plug Link to post Share on other sites
lumoxs 0 Posted November 30, 2011 Author Report Share Posted November 30, 2011 ok buddy thats cool.Also, after extending my loom i had to cut the crank sensor and knock sensor, after some serious reading, have later found out that this could also be causing a problem.... if the ECU senses that the engine isnt cranking then why sould it make the sparks spark....so possibly worth a volt meter check tomorrow to see if there getting the correct voltage.... as all this could be down to them not being done correctly! Link to post Share on other sites
lumoxs 0 Posted December 1, 2011 Author Report Share Posted December 1, 2011 i had a thin black and brow wire from the ecu going to the plug on the coil pack, it wasnt earthing so i put a wire from there to the negitive on the batt, couldnt see if it were that or not cause my bat died.... aarghhhhhhh Link to post Share on other sites
