cbmotorsport 0 Posted December 4, 2011 Report Share Posted December 4, 2011 Any luck? Link to post Share on other sites
lumoxs 0 Posted December 5, 2011 Author Report Share Posted December 5, 2011 Yea the black and brown was from the coil pack which was an ecu earth feed as you said.I double checked all the wires were getting earths which they are now I need to double check there all getting power. Which i presume I would do by havin someone inn the car cranking whilst I check, I got my little bulb with 2 wire that I'll be using to check for positive.Also whilst I'm here I'm so confused as to what engine/ loom I have , the engine says AAA but after some research my loom looks like and ODB1 anyone help??Got some pics of the fuse plug connectors Hi mate heres soime pics of my fuse box part of the engine/ecu loom...The 3 plugs...3 other random plugs - 2x1pin (black and white plug) and 1x2 pin (green plug)again other plugs.... relay plug (4 wires going into it) - red plug/black plug both 2 pin but join to them selves - then got a 2x1 pin plug (brown and blue plugs) then 1x2 pin plug (brown plug) Link to post Share on other sites
