Treva1990
About Treva1990
  • Birthday February 14
    Margate Kent
981 profile views
  1. Any issues with fitting or problems with pipes?
  2. Only issue with the bmw rad is having to run aftermarket fans and I don't like that.
  3. Not tried terraclean but is highly recommended. Even by petrolhead edd china
  4. Hi I am looking to but braided lines for my golf. I am unsure which ones I need as I cannot find a set that has 4 banjo style. My front calipers are banjo and these are my rear ones. [img can someone provide a link to the correct ones?
  5. http://www.ebay.co.uk/itm/Alloy-Water-Tank-Filler-Neck-Cap-Radiator-Intercooler-Motorcycle-Bike-/271087903026?pt=LH_DefaultDomain_3&hash=item3f1e192132 Could i fit this instead of a e36 rad and aftermarket slim line fans. As i have cut the mounts for my bottle and want to try to run the standard fans.
  6. Update Abs bits are here and have fitted the abs pump and wiring i now need to do the lines. The engine has had several stages of cleaning and a week to dry completly and then painted. I have also painted the rocker cover to match and painted the bolts Have also finished the shopping list inorder to compelete the car and it stands at £2k and thats without a respray
  7. Ok so i will leave the valve in place then. Thanks for your help on that one. any idea what this connector is for? I have two in the wheel arches already and seem to have this connector spare on both sides?
  8. Jimjon Do you happen to know which teves i have? I will be sticking with what i have but need to know if i have to use the valve or not.
  9. are you saying the breaks use the rear brake compensator valve on the rear beam?
  10. Could you not take it to a local machine shop? they Will have loads of bolts and will sell you the correct ones to fit.
