BigDaddy
Everything posted by BigDaddy
  1. Yo anyone know what I'd be looking at after a simple plug and play remap at there's no where on guernsey with a rolling road to do one? Would be fitting a raceland manifold, cat-back with high flow cat and aftermarket center and rear silencer, looking at a ram air air intake like the bmc cda but it's cheaper [emoji23] think it's an obd2 manual haven't actually got the car yet getting it on the 3rd
  2. if you get steelies get em banded, look proper euro aha
  3. which golf mate? could the heater matrix just be shagged or even a blockages in the pipe stopping warm aim flowing through to the vents?
  4. that could also explain why your steering wheel wasnt aligned? someones obviously had a go trying to fix it, maybe hit a few speed bumps at speed or those oversized ones which fuk up you car and cost a lot to fix
  5. could the rims be bent after all the curbing? just wondering? is it pulling left on braking or just general driving?
  6. if its scraping either raise it back up or get stiff shocks pref ajustable
  7. HAHAHA i win told you poly all the way mate
  8. polys for the rear beam bushes aha hes beening stubborn saying there no good and cause to much vibration. is that the case or have you found improvements with the polys over oem? cheers
  9. cheers for the reply! what about the rear beam? i still trying to convince him
  10. i cant why it wouldnt?
  11. my mate just used 15mm spacers and they where perfect, i think 20 will be ine to
  12. right guys i know this has ben covered multiple times but im getting mixed messages so i need it to be clearer (and im trying to convince a stubborn mate that oem isnt the best aha) some people say no vibrations some say loads? ruin steering/makes it better/ makes tyre wear happen more/less ete ete just anything to say pros and cons i need to know from your personal experinces and knowlegde Cheers guys much appreciated for your time
  13. hahah i like your plan! but dont you have to remap it for the turbo to work properly?
  14. i would just chuck the standard golf exhaust and get a raceland 6-1 branch and a miltek/remuse/supersprint catback with a decat and centre box delete, then get either a k&n filtre or BMC CDA system then look into the remap to get the best out of the mods because on there own they dont gain might even lose without the re-mapping. but the guys are right cams are a must and the final drive in the gearbox with make it better. if you want even turbo or supercharge it
  15. [blockquote]The plastic ones aren't even fit for purpose, never managed to hook the plastic one on properly, the metal one is a piece of cake[/blockquote]. to true! they are shockingly bad and the catches just snap
  16. you can buy the plastic ones for £10 from the stealers but they are useless after a while because all the clips snap :'( but the metal ones are £20 and trust me it makes life so much easier :)and they last a life time untill your like me and lose them ahaha
  17. my mate had this, it was the starter; changed it started firts time
  18. they are on ebay just its a pig to find them, i cant remember what i used to put in
  19. i have a vw golf gti one if that would work :/
  20. they all seem to be the same mate, we put an ecu that was off an ac car on to non ac car and it works perfectly
  21. is the ford one the same as they used they 2.8l vr6 engine? unsure what prices they would be but they r quite good on prices
  22. that is one mean machine, sounds incred mate, good work keep it up, cant wait to see what u gonna do next
  23. if u do change it take it to the stealers and they will take money off a new one
  24. mates i know dont have aircon but had sunroof, dunno if it was an option or std tho
  25. would a gi one fit? cos dats all they do on da supersprint website
