About Timah89
Solihull
VR6Pete reacted to a post in a topic:
Abs Pump Fitting Guide
Timah89 replied to Marneus's topic in Wheels, Brakes, Suspension and Steering
no worries. its a pretty straight forward job. still not fitted them haha, -
http://www.houseofthud.com/cartech/abspump/ABSProcedure.html -
there is a guide somewhere, cant remember if on here on another forum, will try and dig it out -
think you can see the part numbers with it on the car, might need to do some trickery camera shots though to see them. will need coding for it to work. if interested let me know the part numbers and i can see if i have the same
let me know the relevant part numbers and i can see if mine will work for you. not just a case of getting one from another OBD1 as there are several with different part numbers on and they need to match,
yes and yes, good tv coming back at last! just need a new series of Fast 'n Loud and we're sorted.
did you buy the correct lamba sensor? i know when i was looking for a new one they were a couple of not so obvious choices. it ran fine on mine - i have it for sale now if you want?
alot of roads are cambered to allow for water to flow off the road to the drains. might not be the cause but could be making it feel worse than it is
arches look like they are photoshopped, blurry and different shade of grey/black to the other plastics, looks especially suspicious on the rear
not massive but big enough to work with a roller in it, it would actually make things a bit easier too.
ABS Removal questions
Timah89 replied to cornishvr6's topic in Wheels, Brakes, Suspension and Steering
i am cuirrently doing this on mine. you will need a brake bias valve too as the current one is done via the ABS unit. Also it will fail the MOT, anything like that which is factory fitted must remain on the car unless the car can be proven for use as a track car or rally car. we all have friends who can help with MOT's though -
thats the kind of thing i am after. just really unsure about weight limits on them. i dont mind doing full engine out job as want to do alot of work on that too and tidy all the bay out. I want to pretty much make the car 100% mint again. alot of damage underneath and something like thye chassis roller would make life so easy
Looking to get a Chassis Roller as hopefully doing a full overhaul on the VR over the next year. where can i get one form and how much should i need to spend? are there any good 2nd sites that will have them?
where can i buy a brand new mk3 bootlid from??
Timah89 replied to paceo's topic in Bodywork and Styling
http://www.crashrepairparts.com/ -
HotGolf from ClubGTI builds them for about 500' date=' I've just had stealth to do mine, but i supplied both gearboxes, new bearings, seals and ARP diff bolts.... I know know that I have a really strong gearbox, however like any second hand box, you just dont know the condition of it swings and roundabouts... not sure what the gear ratio's are like for the V5's though, but i highly recommend the 3.68 modification in a VR box... [/quote'] i think n£500 would be out of my league right now, but that does sound very interesting.
