About vr6newcomer
London
VR6 TS (turbo supercharged) is it possible?
vr6newcomer replied to VR6-RR's topic in Engine Maintenance and Problems
very interested in this also, again i am not terribly knowledgable regarding this matter, but seeing as a supercharger supercools the air on the intake, and a turbo works off of used exhaust gasses, subject to getting the correct mapping i dont see why it wouldnt be possible, with something like an extra 100 bhp from both of the f.i devices? -
TPS or GSF for heater matrix?
vr6newcomer replied to vr6newcomer's topic in Engine Maintenance and Problems
v.w. trade parts specialists, the new name for vw, seat, audi, skoda parts, probably for tax purposes!!!! also can anyone clarify what the aircon has to do with it? -
high milers, avoid like the plague or all good?
vr6newcomer replied to longeatonlad's topic in General Chat
167 is a lot of miles mate, having said that if its had the timing chain & tensioners done recently it may be okay, also you need to check all other stuff that will tend to be worn at that sort of mileage, i.e pads & disks, exhaust, alloys + tyre condition, just that little lot could cost you the same as the car again very quickly, its not so much an expensive car to purchase as it is to run and maintain correctly, best of luck whatever you decide. -
hey girls and boys, as the title says in the title, going to do my heater matrix in the next few days, called t.p.s in colindale today, quoted £102:00 + v.a.t. Just checked it on GSF, £37:80 + v.a.t ( - my VR6 discount) eurocarparts - £27:95 not a little difference, just wondering if anybody was aware of the difference between the 2, and if almost triple the price is justified? all help appreciated.
abt 144 according to g.p.s, this was a while ago tho, on 15's and standard suspension, so im hoping for a bit more now tho.
normally end up racing... but last time i bumped into a vr on the north circular the guy slowed down and told me to log onto vr6ownersclub.com!!!!!
if speed is the most important factor here mate, go for the mitsi, its a bloody quick car out of the box, drive it for 6 months, and the beauty with that car is that as long as the engine is sweet, and the work that he says has been done, you can chuck £1500 at it and get it up around 350 to 370 brake, reliabe. that doesnt even get you a stage 1 supercharger on the vr, and as you mentioned, the traction then becomes the issue, whereas the 4wd on the mitsi will make it a bit more bearable, and then that thing will be silly quick, but be warned tne interior looks like a sheeps intestines!!!!!!!
Misfiring again!! any feed back would be welcome!!!
vr6newcomer replied to EugVR6's topic in Engine Maintenance and Problems
seems like you have allready covered all the basics, like zorro said above, double check all the leads are in nice and tight, if so it may be something a bit more serious, so the compression test is the next logical step. -
the ngk's work fine and are the recommended ones, bosch super 4's wont make much difference in your performance
yup you need 2 five litre bottles for an oil change, and its nigh on 6 litres for an oil change, and stick the rest in the boot on the left hand side to use for top-ups.
all depends on how the cars been used as above mate, the chains are made of metal so thats why you get the noise as opposed to a belt, but its the plastic guides that break so the sound is usually intermittent. do a search on google, im sure there is a vid on there,blown vr6 timing chain or something.
ive got the fk badgeless 3 bar ( just a bit different from the usual 2 bar), just make sure you get a bodyshop to spray it up in the right color, it fits fine.
yeah thats about right for the type of mileage youre indicating, you may get it up ever so slightly with an oil service, plugs e.t.c, but unfortunately its the comletely wrong car for such a short journey, you need to remember that despite being a 2.8 it is a 12 valve engine, so its much more comfortable and economical at higher speeds, i drive about 18 miles aound the north circular to work and the v.r is ideal,whereas when im just running around to the bank, tesco's, to a mates round the corner the fuel seems to be disappearing like ive got a fuel leak!! but its a fact of vr ownership and we
if its a standard mani then there shouldnt be anything there dude, i am assuming as youre stating spark plug you have allready got the lead off? and maybe this one is a bit tighter than the others so a qualit spark plug removal toll will definately help.
ok boys well ive voted for 5th gear and here are the reasons. as far as it being a cheap imitation bbc are che cheapest bastards on the planet, i dont see them giving away any cars, ps3's, plasma screens, e.t.c, e.t.c. secondly yes jezza has a lot of personality and he is funny, but those of you old enough to actually remember old top gear, with jezza, tiff, quintin and vicky near the end. you will recall that clarkson wasnt the one doing all the powersliding and stuff with the supercars. it was tiff. i dont rate many drivers personally, but this guy is truly magnificent, james may is a t*t, k
