regs
Everything posted by regs
  1. when i took my car to the phirm i had a new ignition switch fitted and when finished the airbag light stayed on tim just cleared the codes and all was fine its not a problem you just need it on vag com
  2. are you a debt collector oh no please dont knock on my door
  3. agreed with pete what damage could it cause if it breaks up
  4. you will get a better quality sound from 2 separate boxes a lot tighter bass
  5. Very impressive looks like good fun
  6. the pedal seems fine is there any way i can check to see if it is the slave cylinder without just replacing it
  7. Just been in contact with The Phirm and they say it may be the slave cylinder is this easy to replace
  8. I like the look of the R32 rims but they are pricy
  9. Just wondering if anyone could help me out last night i went to drive the vr and my clutch pedal just went flat to the floor and stayed there any ideas the last couple of months ive had a ratchet sound coming from thee clutch pedal nothing seems to have snapped aroumd the pedal any help would be great
  10. just get under the car and measure it thats the only way you will know
  11. Sounds like the ignition switch to me i had exactly the same problem took it to the phirm and they diagnosed the problem straight away
  12. remote start will not work if the car is in gear anyway
  13. http://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?132301 Hi JK this link might help you vr6 absy is in plymouth
  14. not sure but mines a 5 door and i have the window buttons in the dash
  15. I had mine serviced at the phirm and they changed mine for gsf ones so they must be ok
  16. Hi mate i would get on the case about that because even if you havent received the log book yet it should still read up the car details unless you have changed the reg in the pics
  17. you look like your stalking her in that top pic lol
