pete23
Everything posted by pete23
  1. Any ideas as to how you did this. Same problem and no solution!!! Need to recode mine too - any ideas
  2. Any joy with this problem? I've got a similar issue with my vr... No response from either of my key fobs to de immobilise and allow me to start it. HELP me please!!!
  3. Got a similar problem to this. Key fobs just dont respond to deactivate things. Changed all batteries but still no joy. How much was it to get the alarm removed and did it solve the problem??
  4. pete23
    VR6 turbo
    Theres a 9:1 spacer for sale on this site i think. Have a look in the for sale section mate
  5. Small update: Was able to start the VR once. +''ve terminal disconnected and reconnected with the key in and ignition on. The console led was not lit so instead of turning the ignition off and trying to reset using the fob I turned the key and the engine fired up. Ran and drove fine but once turned off I was again unable to disarm the alarm / immobiliser using the fob again. LED back to solid red again!!! Very frustrating to say the least. Tried this procedure again but all I get now is a strong engine turnover with no fire up (presumabley a fuel / spark block). Reading other forums I've have
  6. Still stuck with this one guys. Anyone have any other ideas or inspiration??? Xyber, can you expand on the socket reset please - ie: location, leads needed, how this is done etc. Thanks again.
  7. I can post one up over the weekend if needed. But basically its the black rectangular chaped one with two sqaure buttons at the top (one to arm / disarm and the other acts as a panic button). There is an re LED in the top left and a slider on the right. I am fairly sure this is the factory fit alarm / immobiliser and I have a 97 VR6 so ODB2 i think. I would hazzerd a gues at the scorpion 918 from reading other posts. Maybe someone can confirm this???
  8. Bit of an update... Reconnected my battery lastnight with the key already in the ignition in the 'on' position' and was able to fire the old girl up. (The immobilizer light next to the ash tray was off for the 1st time). However when I turned the ignition off I was unable to prevent the cars alarm from sounding and arming itself again. It seems to me as though the key fob just isnt synced with the car anymore. I have two remotes and have tried the 20 second hold down thing mentioned above but cant get it work. The led on the fob simply lights up immediately but then goes out and doesnt flash l
  9. any ideas peeps? I'm really stuck and need the VR back
  10. Replaced my battery this weekend after my old one was flat as a pancake and would no longer hold charge. All connected up the car started fine and all seemed well until I turned the engine off after a short run down my local road. Since then I cannot seem to disarm the immobilser with the key fob and as such cannot start it again!!! The fob battery was relaced a few months back and the small led light lights when the button is pressed so I cannot see this being the source of the problem. Is it possible that the car has lost some codes due to having a flat battery for some time and simply needs
  11. yes mate, its the flexible rubber hose that has two 90 degree bends and an 'accordian' appearance. It runs from the pcv (disc shaped thingy) to the main air intake pipe that runs behind the engine block.
  12. Hi all. I recently fitted a PCV breather which i bought from Fords for £25. When i fitted it i noticed the flexible breather pipe which connects it to the main air intake pipe is also broken and causing a drip of oil onto my exhaust manifold wrap. And its now abit stinky when stationary. I was wondering if any of you know where i can get this piece of pipe cheaply or if anyone knows the part number? Pic of the pipe i need below. http://i229.photobucket.com/albums/ee167/xXR3DEyeXx/vrsplitpipe.jpg Thanks alot in advance. Pete
  13. Morning, My gearbox engine mount is completely goosed so have bought a new one to replace it with. Having searched for the procedure I think I know roughly what I am to do. Question is, is there an easy way to get to the bolts without accessing from the top of the engine to eliminate the possibility of rounding the bolts. Obviouly to do this you need a very long extension piece and 'angled' adaptor (not sure of the technical name). Any help / tips and tricks are appreciated. Thanks
  14. Currently running a set of T1-R-s but as it has been said, they do wear down very quickly due to their softness. What kinda prices have you been paying for your tyres recently. I heard that their is some good deals to be had on the T1-R's since they are now an 'old' mould?
  15. Looking for two new front tyres for the VR. Any one had any experience with the new Proxes 4 mould? Or know of anywhere promoting good deals on a 'good performance' tyre? Any advise / ideas. Pete
  16. would the 195/40/17's be ok for use with TT comp wheels to give a slightly stretched look. Or would it be advisable to stick with the 205's?
  17. I have one in very good condition if you are interested. Make me an offer
  18. Where they a big job to fit? any problems encountred?
  19. You can also buy them from the VAG parts website. As Xyber said, i would also be intereested in knowing who else runs these in the hella celis headlights.
  20. I thought GSF no longer stocked the lights as I checked when i bought mine???
  21. I presume the water injection and ouil cooler can be added to the kit when and if the funds recover. As for the exhaust I already have a decat s/s full system fitted. Has the charger made a huge difference to the drivaebility of your VR?
  22. Cheers, I think Alex has now sold his charger kit but I'm defo still intested in this mod. You mentioned the dual idler pully - what exactly does this do?
  23. As it turned out, i didnt need the wiring harness! Lucky i guess. But apparently there are two conenctors found on the VR6. If you already have the oval type then you will not need the adaptor. If you have the square connection you will. However I have a wiring harness at home and could sell you this if you were to buy some lights?
  24. Ok, so the temptation to supercharge my Vr is eating away at me! I've done a fair bit of research into this but as I'm no mechanic I'm after some of your thoughts and ideas. You may have seen Alex (Lizard Racing) is selling his Stage 2 charger (and I hope he doesnt mind me asking) but I just want to know what additions to this kit I would need... As it stands he is selling the following: "This is a full kit to fit an OBD2 2.8 VR6. Kit is a full VF Engineering jobbie with Vortech V9F polished charger, 330cc injectors, 8 PSI pulley, 7 rib belt, adjustable fuel regulator, all hosing, alloy VF dum
