Goldie
About Goldie
Help wire identification needed
Goldie replied to vdubgirl's topic in Engine Maintenance and Problems
ABS sensor plugs wont be on the engine management loom -
you make 407hp at 1 bar? please show us the proof
ECU, loom, inlet manfold, throttle body, maf, lambda probe, inlet tube.
largest bore you can go to is 85mm, this will give 3.1 all bore, no crank change needed. 85mm is safe enough on NA engines.
theyre not different, theyre the same gasket
One for each valve, learn to type english!
Are these coilovers roadworthy??
Goldie replied to amazak's topic in Wheels, Brakes, Suspension and Steering
no. -
Help - cracked cylnder head + other problems
Goldie replied to FP3's topic in Engine Maintenance and Problems
oil rocker switch? sounds like someones having you over! a skim will not fix a cracked cylinder head -
black box now with pics ov the box LOOKIE
Goldie replied to drue1's topic in Engine Maintenance and Problems
air silencer -
petrol
a vacuum feed to the heatbox inside, your car must have climatronic? this vacuum is what the heatbox uses to control all the flaps inside.
nothing to do with luck, its how your numbers are delivered.
somewhere there is a big resistor, with a yellow and yellow/blue wire on it, unplug it. i think its on the drivers side front chassis leg somewhere
the 4 pin maf wont work on a 6 pin maf ecu.
