BigSi
About BigSi
Macclesfield, Cheshire
Sounds like the camber is out to me. Are you sure the garage definitely checked the Camber? When I got mine done I was suprised how many garages didn't seem to understand what I wanted doing when I asked for Camber alignment!!! Lots of places will just do the tracking. It will pull all over the place is the camber is out, espcially if its not even on both side of the car. Also when I when I got my Camber set the guy said tyres can have an effect on the pull. I swaped back to front and the pulling went away!
I was going to go for 215/40/16 when I first got my 16" alloys as that is the size listed on the fuel cover (lists the tyre pressure for that size tyre and the normal 205/50/15s). But after getting advise the norm seemed to be 205/45/16 so I went for that.
I couldn't find any tyres made in that size so went for 205/45/16 which seems to be the norm on mk3 Gols on 16s. I got T1 Rs on mine. Got them from Selectra (in Macclesfield) were about
James, I'm certainly not as knowledgeable as some as the others that have replied to this link but I have fitted the Neuspeed ARBs to my car with standard suspension set-up. They made a big improvement! I fitted 25mm on front & at the advice of Awesome GTI went for a 25 on the rear as well (they advised that the 28 is just too much). I thought exactly the same about the handling of the car as you mentioned early on in this link. I have never been in a 306 GTI 6 or an old 205 GTI so I can't compare (infact my VR is the only performance car that I have ever had the chance to drive long enou
Which type of bushes to go for?
BigSi replied to BigSi's topic in Wheels, Brakes, Suspension and Steering
I put the arbs on when it was still on standard suspension set up and they made a load of difference, but yet don't the the comfort remains. I would definitely recommend them to anybody. I went for the Neuspeed after reading lots of threads on this web page. One of the main advantages that I was told about was the heavy duty front drop links that are supplied with the Neuspeed, but not the Eibach. When they arrived I found there weren't any drop links supplied. After much chasing I found that Neuspeed do make drop links but NOT for the VR6, which are a different style to to the rest of the gol -
I've got a paper copy, but no scanner, so I can't send it directly to you. I got mine from my local VW supplier when I was figuring out which parts to replace when I did my suspension. For a 1997 they go together in the following order. Shock Bump Stop Protection boot Spring Sping disk - Part no. 357 421 341 A Axial grooved ball bearing - Part No. IJ0 412 249 Threaded bush - Part No. 1H0 412 365 A Suspension strut storage (The big lump of rubber - top mount) - Part No. 357 412 331 A All that goes under your arch then fit the dished cup and nut to the top. Hope this helps!
I need to change the suspension bushes on both the front and rear. Just wanting to gain your knowledge on the different types. Is it just a choice of O.E. or Poly? Do the poly ones make the ride harsher? I have the Gmax suspension kit (springs and shocks) and Neuspeed Arbs I can cope with the current level of comfort but don't want to loose any more. Whats your thoughts?
quick rear wheel bearing question/advice
BigSi replied to jt's topic in Wheels, Brakes, Suspension and Steering
I had the same thing when mine was MOT'd last September. I nipped the bearing and it was ok for a while but the play soon comes back again. I replaced both rear bearings about a month ago. Like Sanky says you have to remove the disk in order to be able to replace the bearings and the shells but if your disks are ok you don't need to replace them. -
Putting my Gmax kit on tomorrow and just wanted a quick sanity check on cutting the bump stops down! The kit says to cut an minimum of 20mm off. I take it I just cut that off the TOP of the bumpstop!?! Cheers
I agree. Also like the idea of a bottle opener style
Rear Brakes/Calipers - tool tip!
Fair comment - It worked fine for me, and no damage done. Just a suggestion -
You may already know that if you want to replace your rear disks you need a special tool to wind the caliper pot back in. Apprently you can buy these from Halfords - don't know how much they are? Anyway I figured out a great alternative when I did mine at the weekend - But you have to have a 4 1/2 inch angle grinder (or know somebody who has one). The tool that you use to change the blade on them fits perfectly
As ferrariVR6 said, we have done a comparison and got that the GMAX kit gives a 40mm drop. I've been looking for a set-up that gives exactly what FerrariVR6 describes, not the ultimate in handling, but a big improvement over the OEM, whilst still retaining the OEM comfort, (cos I use the car everyday and I do a fair bit of trecking around in it - esp over to Huddersfield where the folkes are and the roads round there are dia!). I did some shopping around and got the kit for £205 all in Bargin! They will be going on this weekend, so I'll let you know what my first impressions are! It's killi
Hobbsy, Got the same alloys as your talking about fitted with 205/45's and there fine. I agree with everybody else, 195's would be too narrow. My car isn't lowered though (yet) so I can't pass opinion on that. TBH I'm supprised the Mk4 wheel size of 205/55 hasn't been giving you problems with rubbing - they are huge!!!! They'll slow down the acceleration as well.
Yes they are a legal requirement. Doubt the police will stop you but if the MOT guy does his job right he won't pass it without them. I had a old E reg Polo which had the wings replaced by the previous owner but he didn't put the side repeaters on. When I took it for the MOT he wouldn't pass it until they were re-installed.
