mtopple 0 Posted January 13, 2006 Report Share Posted January 13, 2006 Q - how long do wheel bearings last and anyone had faulty ones before???Had my fronts done in July last year and they have gone again, just wanted to know if this has happened to anyone before??? Link to post Share on other sites
andy 0 Posted January 13, 2006 Report Share Posted January 13, 2006 They should last for yonks, I had a duff one from GSF last year, it didn't fail as such but started droning loudly, when I took it apart the metal was pitted. That was a rear by the way. Link to post Share on other sites
kilokilla 0 Posted January 13, 2006 Report Share Posted January 13, 2006 The hubs actually wear down on inner edge where they meet with driveshafts and cause the bearings to wear quicker i always replace hubs at same time as bearings now because it saves this problem reoccuring you can get new hubs from eurocarparts for approx £30+v.a.t and this will stop the bearings wearing so quick .Thats if you are talking about fronts anyway. Link to post Share on other sites
Eat this 2 Posted January 13, 2006 Report Share Posted January 13, 2006 i bought the car with 62k miles it needed a front bearing its now done 89k ish and theres play in a rear 1 Link to post Share on other sites
kilokilla 0 Posted January 13, 2006 Report Share Posted January 13, 2006 rear ones work loose john because they are tapered generally you can just regrease and tighten em up a bit. Link to post Share on other sites
Eat this 2 Posted January 13, 2006 Report Share Posted January 13, 2006 u know iv got a new 1 sittin at home just cant be arsed to get it fitted (well too skint/tight fisted atm really lmao) Link to post Share on other sites
kilokilla 0 Posted January 13, 2006 Report Share Posted January 13, 2006 if they not making noise just adjust em up mate save new bearing til old 1s start rumbling Link to post Share on other sites
purple highline monster 0 Posted January 13, 2006 Report Share Posted January 13, 2006 i think someone on here did that already! and the bearing went bang!! i would change it!!!!! worst case it fails and you snap your stub axle you wreck your rim and god knows whatever else!!! just imo Link to post Share on other sites
kilokilla 0 Posted January 13, 2006 Report Share Posted January 13, 2006 purple thats caused by overtightning mate and whoevers it was it must have been humming its sack off they should only be done up to just a fraction past finger tight any tighter and this can be the result as you said as i said in my previous post if its humming change it as this means bearing is knackered but as i said the rears are tapered and can have play after 100 miles or less sometimes its just the way they are aslong as you dont overtighten a non humming bearing and just adjust it up to just past finger tight you will not have this prob . Link to post Share on other sites
shail 0 Posted January 14, 2006 Report Share Posted January 14, 2006 I had one go in about 18 months, I put it down to dodgy fitting / crap bearing. But as said above, it may be a problem with the hub. Link to post Share on other sites
mtopple 0 Posted January 15, 2006 Author Report Share Posted January 15, 2006 update, the noise is unbearable, it's loaduer than my exhaust which is saying something!!it is making a wo,wo noise (sorry only thing I can think of!!) from 10mph and just gets louder the fast I drive. Make a little more going around corners, could it be the CV boot??? Link to post Share on other sites
kilokilla 0 Posted January 15, 2006 Report Share Posted January 15, 2006 that sounds like a really dead bearing mate jack car up and spin wheel if its that bad it should still sound rough as feck and there should be play in it and id advise getting it sorted P D Q cos you could end up knocking other bits out around it and no it doesnt sound like cv to me mate they rattle not hum. Link to post Share on other sites
mtopple 0 Posted January 16, 2006 Author Report Share Posted January 16, 2006 thanks car goig in this week to Storm Developments they did the wheel bearings last summer so they can fix the issue. Thansk to all! Link to post Share on other sites
