Couple of little jobs done over the past week....
Painting the new rear calipers...
Doing a bit of tweaking on the map and adding in timing up the top of the rev range while fine tuning the VE table..
I changed the view from kPa to PSI as I think this tends to make it a little more relatable so as you can see I am currently running a mere 16psi... the reported power is a little unbelievable tbh, it really doesn't feel like 560hp but I plan to get the car back on the dyno for another few runs so I can check my changes and make any further tweaks to get the engine where I want it
Further to preparing for the DSG swap I have sorted a panel for the fuses and relays I will need...
This will attach to the car using a couple of rivnuts...
...thusly...
...and clears the filter nicely...
...of course the panel was painted :)
Waiting on some crimp terminals then I will start wiring everything in including the DSG gearbox loom and all the other bits I need to drive the starter inhibit and reverse light etc..
<tuffty/>
  • 3 weeks later...
  • Replies 52
Popular Posts
top job
So by now the head has returned back... the guides were perfect by all accounts which was a nice surprise as every 20v head over 50k seems to need at least exhaust guides (turbo + heat etc) and only n
Awesome work!
Posted Images
Reply to this topic...
