There a lot more expensive at ECS pal. Haha. I've emailed them mate. Let's see what they come back with. They've also go brembo rotors on offer for $45. Bargain.
Yes they sure are, i guess i got real lucky when i bought them at partsgeek.com, but do they? I am going tk check that out right now
Hi, tried looking for these from GSF and Euro's and i assume they are the double calipers?
checking the parts geek they also fit\come on the Cabrio 94-98
i have found these
 Girling g60 brake calipers
Left: VWicon1.png# 447 615 123
Right: VW# 447 615 124
Seal rebuild kit for Girling calipers: VW# 447 698 471
Girling g60 brake carriers VW# 447 615 125
are these
good link here as well
http://www.myturbodiesel.com/1000q/a3b4/girling-g60-brake-caliper-swap.htm
cheers
s
Edited by ssaunders
Hi, tried looking for these from GSF and Euro's cant see a 60mm piston its either 54 or a double? any pointers?
checking the parts geek they also fit\come on the Cabrio 94-98 also cant see these at either shop? or are the US only?
cheers
s
I had the same problem, could only find them on US sites, would be awesome if we could get them from over here, saves £130 on shipping lol!!!
If you can find them I should be able to get them shipped 'cheap' the guy who runs the brokevw site sent me my schrick import duty was £30 quid. Post has been updated with VW part numbers and it looks like you can get them here.
Think they are 280mm I need 288's
Gsf http://www.gsfcarparts.com/parts/braking/brake-hydraulics/brake-caliper 88 each
Will update if I find cheaper, not sure if they come with carriers?
S
Edited by ssaunders
For 288's has anyone seen this? http://www.ecstuning.com/Volkswagen-Golf_III--VR6_12v/Braking/Big_Brake_OEM/ES518/
If I read it correctly all you need are TT carriers and a spacer!
Can someone let me know if I'm not going mad?
Cheers
Steve
Answered my own question!
http://www.vr6oc.com/forum/topic/17732-312mm-brake-conversion-tt-setup-write-up-diy/
Edited by ssaunders
Cheers
Steve
I used 6mm washers as spacers worked well enough for the time I had them on mine all for sale now will get a for sale thread up soon.
