jamesw6810 80 Posted March 1, 2014 Report Share Posted March 1, 2014 Fitted my newly polished manifold today, all hunky dory until I the realised the nipple from the fuel pressure regulator into the manifold is missing, as in sheared off.....anyone any thoughts on reattachment of the vacuum line? It's sheared near enough flat with the manifold, slight lip left but not enough to attach the hose. Was thinking some h&b weld or similar? Link to post Share on other sites
jamesw6810 80 Posted March 1, 2014 Author Report Share Posted March 1, 2014 Jb weld not h&b weld!!! Damn iphone Link to post Share on other sites
jamesw6810 80 Posted March 1, 2014 Author Report Share Posted March 1, 2014 And as luck would have it I have some jb weld in my box! Link to post Share on other sites
VR6Pete 1,455 Posted March 1, 2014 Report Share Posted March 1, 2014 Either that, or tap a new nipple in Club Chairman jamesw6810 and Vince12v 2 Link to post Share on other sites
jamesw6810 80 Posted March 1, 2014 Author Report Share Posted March 1, 2014 Tap a new nipple......snigger snigger!! isobarboy and Vince12v 2 Link to post Share on other sites
VR6Pete 1,455 Posted March 2, 2014 Report Share Posted March 2, 2014 Fnar fnar lolClub Chairman Link to post Share on other sites
jamesw6810 80 Posted March 2, 2014 Author Report Share Posted March 2, 2014 (edited) So, the plan is to remove the manifold i spent time putting on yesterday, fix the nipple back on with jb weld, once that is dry ill then coat it in some hight temp rtv sealent to stop any vac leaks through the welds, ill also probably lengthen the vac pipe so it sits at a deeper angle to put less stress on the welded joint, sound like a plan? Edited March 2, 2014 by jamesw6810 Link to post Share on other sites
EnthusiastOwned 7 Posted March 2, 2014 Report Share Posted March 2, 2014 Sounds like it'll just fall off in use.Tap a new one in. Link to post Share on other sites
jamesw6810 80 Posted March 2, 2014 Author Report Share Posted March 2, 2014 (edited) any ideas where i can get a new nipple......? or what thread it is would help alot, also a suggestion how to get the piece left back out.... http://www.seatcupra.net/forums/showthread.php?t=375211 looks like this in the first post. Edited March 2, 2014 by jamesw6810 Link to post Share on other sites
jamesw6810 80 Posted March 2, 2014 Author Report Share Posted March 2, 2014 anyone any ideas on the thread of the vac nipple? Link to post Share on other sites
Lukey. 381 Posted March 2, 2014 Report Share Posted March 2, 2014 Surely you're going to need to get a replacement in whatever thread before you know what thread to tap it to Link to post Share on other sites
VR6Pete 1,455 Posted March 3, 2014 Report Share Posted March 3, 2014 Id be inclined to drill what's left out and then find a bigger nipple and tap it in using PTFEE tape to create a good seal. Link to post Share on other sites
GordonC 20 Posted March 3, 2014 Report Share Posted March 3, 2014 As above mate your best bet is to just get another bit of pipe slightly bigger and drill out whats left in the manifold then chap the new pipe in lightly with a hammer but it will need to be a nice snug fitVR6 Loonibuggy Santa Pod 2014 ! Link to post Share on other sites
MK4motionVR6 41 Posted March 11, 2014 Report Share Posted March 11, 2014 All this talk of nipples has got me wanting to tweek my misses nips... LolMk4motionVR6 Link to post Share on other sites
CALICO 130 Posted March 11, 2014 Report Share Posted March 11, 2014 You don't wanna be doing that youll only get a slap. MK4motionVR6 1 Link to post Share on other sites
jamesw6810 80 Posted March 11, 2014 Author Report Share Posted March 11, 2014 i can just see the above sat in front of his pc with nothing on but his pants tweaking his nipples now whilst on vr6oc.......wrong on a lot of levels MK4motionVR6, Lukey., VR6Pete and 2 others 5 Link to post Share on other sites
VR6Pete 1,455 Posted March 11, 2014 Report Share Posted March 11, 2014 Warning: vr6oc does not condone tweaking your own nipples. daveyboy, MK4motionVR6 and PeteVRT 3 Link to post Share on other sites
Daverse 175 Posted March 11, 2014 Report Share Posted March 11, 2014 Nor condemnSent from my GT-I9300 using Tapatalk Link to post Share on other sites
jamesw6810 80 Posted March 11, 2014 Author Report Share Posted March 11, 2014 some sort of forum porn going on here guys? VR6Pete 1 Link to post Share on other sites
MK4motionVR6 41 Posted March 13, 2014 Report Share Posted March 13, 2014 The word nipple was mentioned, next thing.....Mk4motionVR6 Link to post Share on other sites
