  • Replies 213
  • Created
  • Last Reply
Top Posters In This Topic
Enough you fools!
Tomorrows action plan should see us fitting the oil feed, water pipes and boost hoses.
Front end back on and fuel tank wiring
Once thats done, the interior can go back in and then its just welding and fabrication works..
Coffee and croissants will be ready from 8!
Update from saturday....
Thanks to Parkie, Russ and Bungy for offering services for the morning..
so we managed to get:
the fuel tank pump and wiring sorted
Fuel pump and filter in position
Up rate the vr fuel lines
Installed the brake line extensions
Mounted the intercooler
Fitted the rad and water hoses
Fitted the boost hoses
Got the carpets back in and the seats in position.
Sorted the boot out as now finished!
Started to template the exhaust pipework
Since then I have now ordered new 76 nd 63mm boost hoses and pipework, and sourced an amazingly cheap turbo replacement or the old t3/t4!
And sourced exhaust bits to modify tonys 3"er ;)
Plan for this saturday is:
Swap wheels for audi peperpots
Bleed brake lines
Install new boost hoses and re-route pipework
Fit new turbo
Make up / modify exhaust (have ordered a 2.5"-3" adaptor and a 20degree angle for downpipe)
Cut and shut seat runners for buckets..
Wire up fuel pump
Install dash board and associated bits
Fit battery
Fill up with petrol and turn key!
Scratch head.......... :)
