The Monk 50 Posted May 17, 2011 Report Share Posted May 17, 2011 Right, basically, I've got the VR6 back on the road but I also have the Passat.Both have issues and this is where I'm tearing my bald hair out.VR6.1) 4 new tyres needed soon.2) Inner CV joint on N/S driveshaft kaput.3) Both Wishbones and balljoints need replacing.4) Suspension needs replacing (I own a new set but will struggle to remove old set).5) LOUD tapping "clank" coming from above cylinders 1 & 2 that seems to have become worse today.6) Welding needed on O/S sill for MOT.7) ? New HT leads, coilpack, Lambda, MAF.....Passat1) Hot starting issue2) Front link of wishbone needs replacing (£30 more expensive than both balljoints and wishbones for VR6).3) Crank pulley for auxiliary belt needs looking at and probably replacing.4) Both cam sensors need replacing... £££'s5) 3 of the 4 lambdas need replacing...£££'s6) Powersteering pipe at the pump has split and will cost to replace.7) 3 new tyres needed.The VR6 is cheaper to repair and costs less to insure but drinks fuel.Passat is more expensive to fix, insure BUT gives me double my VR6's milage.Both put a smile on my face in different ways, just the VR is rapid after 10 months in the Passat.What do you guys n girls think? Link to post Share on other sites
BADOIR 2 Posted May 17, 2011 Report Share Posted May 17, 2011 unbiassed..lol.. for me it,s a no baller mate the vr. Link to post Share on other sites
bungy 2 Posted May 17, 2011 Report Share Posted May 17, 2011 There are loads of spares available for the VR's and fewer available for the Passat making it more expensive. I'd concentrate on the VR unless you have other considerations aswell. Link to post Share on other sites
craggsy 91 Posted May 17, 2011 Report Share Posted May 17, 2011 Neither.....get a vauxhall astra Link to post Share on other sites
BADOIR 2 Posted May 17, 2011 Report Share Posted May 17, 2011 Neither.....get a vauxhall astra shows what you know lol...Corsa (h) Link to post Share on other sites
The Monk 50 Posted May 17, 2011 Author Report Share Posted May 17, 2011 There's always one. To be fair though, I always allow for one wise guy.... always craig lol. The thing that is bugging me the most, is the tapping and the welding.No point spending crud loads of money if the tapping is an underlying issue that damages the engine. Link to post Share on other sites
VR6Pete 1,455 Posted May 17, 2011 Report Share Posted May 17, 2011 Any chance of a sound clip / video of the knocking noise? Get your self to billing and put your name down for the welding tuition bungy is doing Link to post Share on other sites
veedubjunky 0 Posted May 18, 2011 Report Share Posted May 18, 2011 Put the vr lump into the 'ssat happy days Link to post Share on other sites
spadam 7 Posted May 18, 2011 Report Share Posted May 18, 2011 Sell both and buy my Vr6 problem solved Link to post Share on other sites
jims13 6 Posted May 18, 2011 Report Share Posted May 18, 2011 yep what he said ^^^^ Link to post Share on other sites
spadam 7 Posted May 18, 2011 Report Share Posted May 18, 2011 Plus you would have some change left over. Link to post Share on other sites
Saunders82 0 Posted May 19, 2011 Report Share Posted May 19, 2011 Agreed sell the passat either how it is. I'm sure by the sounds of it you could get a better vr for the money considering how much vr's have dropped in value over the last year. Break the black one for spares for the new one or some extra money. It would be the tapping putting me of fixing the black one vr engines aren't cheap to fix and getting a good engine second hand is always a risk. Link to post Share on other sites
The Monk 50 Posted May 20, 2011 Author Report Share Posted May 20, 2011 Any chance of a sound clip / video of the knocking noise? Many apologies for the crud quality. Best I can get though.x5q9rwYX4Fc Link to post Share on other sites
bungy 2 Posted May 20, 2011 Report Share Posted May 20, 2011 Does the sound disappear or quieten as you rev it? Link to post Share on other sites
The Monk 50 Posted May 20, 2011 Author Report Share Posted May 20, 2011 Nope, clunk/scrape/tap speeds up as the revs increase.I do need to check under the rocker..... a job for later on this evening with some beers. Link to post Share on other sites
BADOIR 2 Posted May 20, 2011 Report Share Posted May 20, 2011 that dont sound good mate :-( Link to post Share on other sites
Dave Lea 4 Posted May 20, 2011 Report Share Posted May 20, 2011 keep the vr fella i will help u sort it all out and see if liam will mot it for ya Link to post Share on other sites
BADOIR 2 Posted May 20, 2011 Report Share Posted May 20, 2011 Good shout .. Link to post Share on other sites
The Monk 50 Posted May 20, 2011 Author Report Share Posted May 20, 2011 No Martin, it doesn't.Dave, thanks matey. I know it seems daft but, I've forgotten so much about the VR. Link to post Share on other sites
