  • 2 months later...
yeah got mine from Halfords, pack of 3 - they are classed as aerial hole gromets - i believe it was the largest of the 3 that fit perfectly. I just gaffer taped the inside of the hole too just incase of any leaks but never had a problem with it, like Nat says it was only 70p or something too
Yeah, 5 min job, its pretty self explainatory, but take the plastic off the inside of the boot door, then remove the plug and water pipe that goes to the motor, there is a couple of screws holding the motor on, remove those and you can take the motor out, then put a screw in the end of the water pipe and remember not to try and use it!!
Then stick in the bung n job done! :) :)
