oldmandon 1 Posted October 12, 2010 Report Share Posted October 12, 2010 Hey all,I know I've posted a thread about lumpy tickover, but now I'm finding the running is starting to get irratic. when I accelerate the car splutters until 1500 rpm then it clears, well that was what was happening, now its doing it higher up the rev range. however if I drive steady, the car runs relatively smoothly. Also, I had a go at revving it and driving it hard to see if it would clear anything, and it felt as though it was running on 4??!!I've changed the plugs, changed the air filter. Ive cleaned all the contacts with wd40 inc ht leads etcstill have the fuel filter to change.Any other suggestions would be gratefully accepted...... Link to post Share on other sites
p0u1 14 Posted October 12, 2010 Report Share Posted October 12, 2010 sounds like your coil pack Link to post Share on other sites
richgti97 0 Posted October 12, 2010 Report Share Posted October 12, 2010 I had exactly same problem after doing my vr conversion.. changed plugs and leads and sorted it out. Link to post Share on other sites
kebster 0 Posted October 13, 2010 Report Share Posted October 13, 2010 im going for the coil pack i have had this on mine recently. I have changed plugs, leads, temp sensor and now i have sourced a brand new coil pack for £80 so trying that Link to post Share on other sites
VR6Pete 1,455 Posted October 13, 2010 Report Share Posted October 13, 2010 Can you see any arching? At night, spray a light mist of water over the coilpack. If your car runs better on warm days than it does on cool days, it's probably your coilpack cracked and letting moisture into unit. They are prone to cracking - usually have loads of these types of problems this time of year Link to post Share on other sites
oldmandon 1 Posted October 15, 2010 Author Report Share Posted October 15, 2010 Can you see any arching? At night' date=' spray a light mist of water over the coilpack. If your car runs better on warm days than it does on cool days, it's probably your coilpack cracked and letting moisture into unit. They are prone to cracking - usually have loads of these types of problems this time of year [/quote']I had a look this morning (5.30 am) and couldn't see any arching from the coilpack. However I could see some arching from the front left plug lead (nearest air intake)...???!!!!!! My car runs worse when it's warm.Will any vr6 coilpack fit (provided the plug is the same shape) or does it HAVE to be a golf one? Link to post Share on other sites
dalevr6 0 Posted October 19, 2010 Report Share Posted October 19, 2010 I had a look this morning (5.30 am) and couldn't see any arching from the coilpack. However I could see some arching from the front left plug lead (nearest air intake)...???!!!!!! My car runs worse when it's warm.Will any vr6 coilpack fit (provided the plug is the same shape) or does it HAVE to be a golf one?I've noticed one of my HT leads arcing onto the head, rear left, anyone know why? Link to post Share on other sites
