vr6turbo 27 Posted August 25, 2009 Report Share Posted August 25, 2009 i have looked hi and low for a suitable bonnet scoop to keep the underbonnet temperatures down and think it would help when running a turbobut i just cannot find one i think suits the carany ideasand comments Link to post Share on other sites
craggsy 91 Posted August 25, 2009 Report Share Posted August 25, 2009 To me scoops do not suit the mk3 at all. How about putting vents like the sprinter wing vents on bonnet Link to post Share on other sites
vr6turbo 27 Posted August 25, 2009 Author Report Share Posted August 25, 2009 i am looking to have a good airflow over the turbo then down under the car past the coreit has not been necessary in the past when i had an intercooler but since using a charge cooler ( stealthmode )the intake temps have been higher than i wantedso i plan to uprate the charge cooler rad with a cinquicento radiator with a fan and switch or temp controllerits just a feeler i know from the past general opinion has been against fitting a scoop for the reasons you mentionedthe vents will release some heat but will they be as effective as a scoopany pictures of vr6's with vents scoops lets have a look!!! Link to post Share on other sites
matty.vrt 120 Posted August 25, 2009 Report Share Posted August 25, 2009 what about raising the back of the bonnet to let air into the back. Link to post Share on other sites
legvw 0 Posted August 25, 2009 Report Share Posted August 25, 2009 Yeah as mat said above, its the old rs turbo trick (bin there done that jobbie!) as was thinking of doing some thing like that on mine Link to post Share on other sites
CALICO 130 Posted August 25, 2009 Report Share Posted August 25, 2009 i may be wrong but i think raising the back of the bonnet sucks the air out as airflow goes over it air wont go in unless you raise the front surely Link to post Share on other sites
vr6turbo 27 Posted August 26, 2009 Author Report Share Posted August 26, 2009 sounds like a plan does that mean i have to sign up to a ford site to understand how its done? Link to post Share on other sites
legvw 0 Posted August 26, 2009 Report Share Posted August 26, 2009 i may be wrong but i think raising the back of the bonnet sucks the air out as airflow goes over it air wont go in unless you raise the front surelyYeah it just helps release the heat around the back of the engine, should help de-ice in the winter too!(don't join a ford forum!)You just need to raise the bonnet hinges 20mm or so. Link to post Share on other sites
jesterwalker69 0 Posted August 26, 2009 Report Share Posted August 26, 2009 Yer a couple of washers on the bottom of the hinges should see you right Link to post Share on other sites
vr6turbo 27 Posted August 26, 2009 Author Report Share Posted August 26, 2009 its a great idea never heard of it beforei will defo give it a trythanks for all input Link to post Share on other sites
dieseldave 0 Posted August 26, 2009 Report Share Posted August 26, 2009 check with mot first, as i have heard of cars failing on this before Link to post Share on other sites
