Pete's OBD2 Corrado VR6 - On The Road
  • Replies 509
Popular Posts
It's alive!!!
Went to my local pirtek branch to make up my oil lines as didn't have correct tools here to do the job and wanted peace of mind 🏻 They have done a great job and only £38 - I supplied the li
I went to Stealth yesterday, feeling quite apprehensive! I am the 3rd car that has used their new strapping system, so they can run higher power cars without needing to use glue all of the time, and a
Posted Images
Next Update!
Well, a cold / snowy weekend didnt put us off!
First of all, applied some rust prevention as it was a little rusty!
Engine back in with little issue now the rear engine mount was sorted.
Few more bits connected up! :)
Attempt one at fitting intake stuff... really need to get some samco hose to couple it all together and chop some hose off the BMC CDA.
Tony filling her up!
Also fitted new fuel filter...
Shiney stuff...
76651_467051069131_512334131_5756282_3432699_n.jpgp
Not quite on the ground yet. had some issues with the brake lines that I need to resolve by way of fitting the banjo bolts and new lines as the nut has rounded off one of them (any suggestions?)
  • 2 months later...
Here we go for round 3! Tony and the lads are coming down this weekend to help finish her off! (the car that is lol)
If anyone wants to come around lend a hand your more than welcome!
Here's a quick list of jobs to do for those interested;
Fit heater motor
Clip Bowden cable - lower blue
Fit heater controls (be careful)
Fit internal trimmings
Fit new brake line + reuse old grommet
Fit goodridge hoses
Grind callipers down / fit wheels
Water pump pulley / refit tensioner pulley + BMC
Check aux water pump now works
Sort air lock
Fit Bonnet cable
Remove bonnet foam
Solder fog light wire + fit bulbs
Fit crank pulley
Oil cooler seals
Sump gasket
Fit new rear VW badge
So what ever your skill level, there's jobs for everyone :)
Bring it on!!
Pete
