clarkie 1 Posted December 29, 2006 Report Share Posted December 29, 2006 last night my car just died on me. tried 2 start it and it starts then dies. checked all wires to see if anythink was loose or broke but no. kept turning the key on and off and got it 2 start. got home turned of and same again wont go. do the key on of few times and it goes. went to my bro in laws workshop 2 day 2 put on vag com but wont comunicate with ecu. had all ecu off , checked all wires , fuses , relays but all seems ok. after tried to start it starts then dies again. try 2 do the key on and off again but now wont keep goin at all. please can some 1 help me as its really getting to me. soz for the long post. stu (ps have tries a search 2 see if any 1 else has had this but cnt find anythink. ) Link to post Share on other sites
mk3anni 0 Posted December 29, 2006 Report Share Posted December 29, 2006 I'd say immobiliser or crank position sensor from the first part of your post, but the fact you cant talk to the ecu confuses me. Link to post Share on other sites
jims13 6 Posted December 29, 2006 Report Share Posted December 29, 2006 maybe relucter ring around the ignition switch, or the ign switch itself, as that what mine as doing, would start sometimes then not other's, try puting a bit of pressure on the switch and giving it a turn. i ended up replacing the key and switch, and glueing the immobiser chip out of the key to the ring in the steering coloum, makes life easier if i have any problems in the future.hth jim Link to post Share on other sites
clarkie 1 Posted December 29, 2006 Author Report Share Posted December 29, 2006 soz forgot to say we changed the ignition switch first as we was 99% sure it would be that but that made no difference. stu Link to post Share on other sites
Jk* 0 Posted December 29, 2006 Report Share Posted December 29, 2006 I say this everytime a problem like this comes up, but thats only because its happened to me. Try testing the MAF or seeing if you can get a mate to swap them over. Just a thought. Link to post Share on other sites
clarkie 1 Posted December 29, 2006 Author Report Share Posted December 29, 2006 have also tested the maf previously when i has probs and that seems ok. just cnt see why vag com cant comunicate with the car. Link to post Share on other sites
Russ_vr6 12 Posted December 29, 2006 Report Share Posted December 29, 2006 id say crank position sensor as a guess mate Link to post Share on other sites
gav_113 0 Posted December 29, 2006 Report Share Posted December 29, 2006 u tried that code reader i sold u? Link to post Share on other sites
clarkie 1 Posted December 30, 2006 Author Report Share Posted December 30, 2006 yep keeps coming up as error. and vag com says cannot comunicate to control unit Link to post Share on other sites
Andi 0 Posted December 30, 2006 Report Share Posted December 30, 2006 Does sound like imobiliser prob, but.Sorry to stick my nose in as a newbie and all but have you checked all the basics like is the fuel pump working ? Link to post Share on other sites
Backo 0 Posted December 30, 2006 Report Share Posted December 30, 2006 Maybe worth disconnecting battery for half an hour and letting the ecu reset itself and checking on vag-com again???,does the car run fine when its eventually started? Link to post Share on other sites
clarkie 1 Posted December 30, 2006 Author Report Share Posted December 30, 2006 checked the fuel pump. that works fine. it did run fine once started but wont start at al now. we did disconnect the battery for a couple of mins , how lojng should it be left to reset its self? thanks. stu Link to post Share on other sites
Backo 0 Posted December 30, 2006 Report Share Posted December 30, 2006 a good half hour stu.this also might reset your alarm,does the car turn over and is it trying to fire?,ive got a code reader and if the immobiliser is on you get the error code!,good luck Link to post Share on other sites
ingham 5 Posted December 30, 2006 Report Share Posted December 30, 2006 sounds like imobiliser prob.mine did similar only vws computer could recode it Link to post Share on other sites
Russ_vr6 12 Posted December 30, 2006 Report Share Posted December 30, 2006 has it an aftermarket immob or just the transponder in the key? could be the reader coil Link to post Share on other sites
clarkie 1 Posted December 30, 2006 Author Report Share Posted December 30, 2006 yeh it wil fire up then die.. its just the standard vw alarm and imob. think im goin 2 have to take it to vw . Link to post Share on other sites
clarkie 1 Posted December 30, 2006 Author Report Share Posted December 30, 2006 sounds like imobiliser prob.mine did similar only vws computer could recode itdid you try puttin it on vag com or any other code reader? if so what was coming up on the screen? thanks . stu Link to post Share on other sites
Russ_vr6 12 Posted December 30, 2006 Report Share Posted December 30, 2006 if it runs for a sec then dies mate i would say def immob coz thats what happens when we order keys,before the key is coded,it will start the car but the car cuts out straight away Link to post Share on other sites
gav_113 0 Posted December 30, 2006 Report Share Posted December 30, 2006 when we tried that code reader at rolling road day it worked fine? if vag com doesn't work then i say that there is a communication problem with the ECU..and that is ur problem? Link to post Share on other sites
jims13 6 Posted December 30, 2006 Report Share Posted December 30, 2006 immobiliser coil, grab one from another car , as they are not car specific, and bung it on , 20 min job and will cost you next to nothing. Link to post Share on other sites
clarkie 1 Posted December 30, 2006 Author Report Share Posted December 30, 2006 if it runs for a sec then dies mate i would say def immob coz thats what happens when we order keys' date='before the key is coded,it will start the car but the car cuts out straight away[/quote']this is exactly what its doin. jim i will try what you said and see what happens. Link to post Share on other sites
VR6_Absy 0 Posted December 30, 2006 Report Share Posted December 30, 2006 You should still be able to run Vagcom with an uncoded key as it will turn to the ignition lights position but just won't start. Have you done the Autoscan with Vagcom to identify all the controllers yet ? Link to post Share on other sites
clarkie 1 Posted December 31, 2006 Author Report Share Posted December 31, 2006 disconnected the battery for well over half hour and stil the same. Link to post Share on other sites
Russ_vr6 12 Posted December 31, 2006 Report Share Posted December 31, 2006 poss the reader coil,chip in the key wont be the prob coz they chip eitheer works or doesnt,is it getting fuel through? Link to post Share on other sites
clarkie 1 Posted January 2, 2007 Author Report Share Posted January 2, 2007 yep getin fuel through coz when ignit is on ya can see ful pipes twitching and wen i turn the key off and on it backfires. Link to post Share on other sites
