Jk* 0 Posted December 10, 2006 Report Share Posted December 10, 2006 Is there anything i should know before i try and fit them to my mk3? The car is lowered 40mm as far as i know. Thanks in advance. Link to post Share on other sites
SankysVR6 1 Posted December 10, 2006 Report Share Posted December 10, 2006 I haven't fitted mine as yet.But there was some talk about the center caps on the rear wheel might not sit flush, and might stick out by 2mm or so. Link to post Share on other sites
binliner 0 Posted December 10, 2006 Report Share Posted December 10, 2006 yeah they do but I flattened my wheel bearing covers with a hammer to get them to fit Only other thing you need to know (if you dont already) is that you'll need to bin the 225/45 tyres as theyre the wrong size for a mk3 Link to post Share on other sites
Jk* 0 Posted December 10, 2006 Author Report Share Posted December 10, 2006 Yeah, as you both mentioned ive heard the same. The 225 will be going for 205/40 rubber. Does it not damage the wheel bearing covers, or make it more difficult to remove them if necessary?? Link to post Share on other sites
spindat45 0 Posted December 11, 2006 Report Share Posted December 11, 2006 Neither. All you will be doing is flattening them slightly so that the centre caps fit flush. If you have Solitudes then I have been told that you can use the VW centre caps from them without having to take a hammer to the bearing covers. I've left the Audi centres on mine. Just personal preferance Kevin Link to post Share on other sites
binliner 0 Posted December 12, 2006 Report Share Posted December 12, 2006 you can use the vw centre caps but they still dont fit Link to post Share on other sites
kalv 0 Posted December 12, 2006 Report Share Posted December 12, 2006 No problems in mine - went straight on...? Link to post Share on other sites
Jk* 0 Posted December 12, 2006 Author Report Share Posted December 12, 2006 You dont have TT Comps though Link to post Share on other sites
kalv 0 Posted December 13, 2006 Report Share Posted December 13, 2006 oopss... saw TT and made assumptions.. need to re-educate myself...! Link to post Share on other sites
MJ Vr6 79 Posted December 16, 2006 Report Share Posted December 16, 2006 Its piss easy dude, hammer the bearing caps a little so the caps sit inn nicely, with your arches i suggest you roll them, tyre size would be 205/40/17 84r... got these wheels on my ride and the mrs ColourConcept Link to post Share on other sites
Jk* 0 Posted December 18, 2006 Author Report Share Posted December 18, 2006 I may have a slight problem fitting them then, as my n/s rear quarter is dented in abit. The current 7x17 i have on there @ the moment are fine, but will i come across problems with the TT's? Link to post Share on other sites
purple highline monster 0 Posted December 23, 2006 Report Share Posted December 23, 2006 just offer one up and bolt it on, lower the car gently and check the clearance, it will be obvious if it gonna touch, anyway if its already dented just use the same hammer you cave your grease caps in to "modify" the arch back out a bit, if its only the outer skin of the arch i doubt its shifted enough to touch anyway? Link to post Share on other sites
