Days Won
1
SankysVR6 last won the day on September 26 2022
SankysVR6 had the most liked content!
About SankysVR6
Bradford
Gelly reacted to a post in a topic: Correct Engine oil for my VR6
Driled airbox with a K&N air filter. Saves drilling yours and you also get a performance air filter with it, to get you going with that additive induction sound from a VR6. http://www.ebay.co.uk/itm/Mk3-Golf-VR6-Airbox-Highline-K-N-Air-Filter-GTI-Drilled-Airbox-/281350751871?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4181cfc67f
Could be the earth strap on the starter motor has corroded off. One way to eliminate the starter motor, would by bump starting the car. Don't do this to often, as I don't think it's very good for the engine.
where can i get genuine ht leads
SankysVR6 replied to rsweeney's topic in Engine Maintenance and Problems
Agree, buy it right first time. -
You could try and make an attempt at reselling, not sure how long it would last. I would just buy a new one, to save the hassle. It might be a good idea to change the spring clips to normal jubilee clips, for easier removal.
Has anyone got a picture of the goodridge brake hoses. For 1997 VR6. I want to see what the fittings are like
VR6 Highline Updated 18/05/10 Ext/Int
SankysVR6 replied to SankysVR6's topic in Members Rides and Event Photos
Update time. Finally found some wheels that took my fancy, they wasn't in the best colour choice. So had them stripped and started the polishing process, couldn't get them to come up as bright as the TT wheels. Must have been something to do with the metal. Trial fitted Was having second thoughts with them, but once they were fitted to the car i was more then happy. -
I will be there
BUMP means Bring Up My Post
Have a look here http://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?106391
Mine is a 1997 R, and it has a cover on it. But saying that, i have seen many others without as well. Before i bought my VR, i saw a lot of VR's without them and it sort of put me off them. As the pedal made it look like they've been ragged quite a lot.
Hi, have you tried Schmidt it self. There website is partly in English. Just fire an email off to them, and see what they come back with.
quick answers - MOT tomorrow, VAGCOM fault codes
SankysVR6 replied to Timah89's topic in Engine Maintenance and Problems
The first one is, more likely that the battery has been disconnected at some time. Just make a note of it, clear the faults and check again in a few days. -
There is no rubber seal around the window, it should be bonded. Check your rear lights and the foam type gasket on the back of them is okay.
