FAO- People with TT comps.
Neither. All you will be doing is flattening them slightly so that the centre caps fit flush. If you have Solitudes then I have been told that you can use the VW centre caps from them without having to take a hammer to the bearing covers. I've left the Audi centres on mine. Just personal preferance ;)
Kevin
just offer one up and bolt it on, lower the car gently and check the clearance, it will be obvious if it gonna touch, anyway if its already dented just use the same hammer you cave your grease caps in to "modify" the arch back out a bit, if its only the outer skin of the arch i doubt its shifted enough to touch anyway?
